Showing results for tags 'grand prix racer'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Hi, On the 26th of December I got the Lego 42000 from a local store after being informed that it is available in a certain store. I got it for £79.99 which I think is fair as today I finished building it and decided to do A review so without further do: General info: The set box is quite good with the images as it captures the whole car with good detail in a smallish box size, it also demonstrates its features, its ad-dons using PF and other usual information such as dimensions, it has a total of 1135 parts (26 spare from A model) and it is 58cm long by25cm wide by 13.6 cm tall, the B model is not available in the set but maybe online as PDF. The instructions are in three books its features are independent suspension, HOG steering, rear diff and working engine, tilting rear spoiler and engine body cover with a hinge. The engine cover and rear wing can either by adjusted manually or electronically. Mechanisms/construction: The mechanisms feature: linear actuators, gears+differentials, springs, motors, linkages on either beams or ball joints. they are either controlled by motor, by hand, the switch between rear wing and engine cover is done with a clutch that is hooked up to a selector switch, if you have the motor with it it only reveres whatever is selected. like that the linear actuators have build in slip clutches so you cant overdrive it and break it however when it goes off with lifting the engine cover is is quite wobbly and noisy, also when the engine cover lifts up it goes get slightly obstructed by a body panel and the mount of the actuator which does slow it down opening and closing half way though but it isn't a huge problem for me, after all it is still a set of standardized parts, nothing custom designed. The rear diff and engine work very well as usually when you spin the wheels they don't run for very long but these ones do so the parts have little friction, the rear spoiler is also good and I don't have any issues with it, its design is clever and a bit different maybe which is what lego is about. The suspension is smooth but I was hoping for more travel than this even if it is an F1 car, the fact that they can be seen operating is good too. The steering is also a bit of a problem as it has quite a poor turning circle, with these new steering parts which came out in this set first but it is even worse than other lego F1 cars. Since it is quite big and looks good this is a + but I don't think much of the stickers and they generally get damaged anyhow so I left them off but they do match with the shape and colour of the parts. The new parts are good , larger tires which I long for since the tires from the power puller and Williams f1 car are hard to get and expensive these new ones are better for sets about as large as the 42000 , I even think these tires will fit with other rims too. Another nice part is the 5L lift rm thin with cross holes both ends as trying to have a lift arm and support it that is 5l and thin is not easy, I used to use the triangular lift arm (old or new) before this part came out, and that is important because it will help get over problems and limits in future sets. This model is compatible with the power pullers battery box and M motor and you don't need to add or remove any other Technic parts to change it so the PF parts fit but I was expecting the clutch and sleeve to drive the rear wheels when it was in the middle position but it doesn't do anything which is odd, and there is plenty of space in the car too. I would also have liked to have the servo motor in the large space in the cockpit as that only requires the steering wheel to be taken off, I suppose for the price it's OK that you don't get any PF parts Pricing of this set is OK/slightly steep and I say this because of the above points and because it doesn't take that long to build which isn't too good for me as I like spending days building like with the Unimog U800 and that has PF too The design is good, I particularly like how the body contours match on either side of the air intake/grills on either side and the back engine cover is nice too as the back does have to go up on an angle slightly and when reading the instructions it looked like the back end was white tall but its fine. The colours are nice too kind of looks like a Honda/McLaren, the new body panels looks really sleek and will help with other models, my favourite is the 1.4x4 body panel in red The conclusion: My conclusion is that I give this car 7.5/ out of 10, you get three new linear actuators, newish tires (appeared in 1 other set I read),new steering/wheel hubs, body panels but it could be more complicated and have more features and have the 'new price' follow this perhaps, however there is a lot of good body work and some clever features and mechanisms so that's where i put it. For good measures here are some videos and images of the set: :), feel free to ask for any other information or photos of this model. https://www.dropbox....12 20 01 18.mov
