Showing results for tags 'ecto-1'.
My latest MOC is finally complete, the Ecto-1 from the original 1984 Ghostbusters movie. This is a theme I haven't done anything before from and I was actually a bit surprised myself also that I got an inspiration to do this one. I always liked the Ectomobile and probably played around with the idea on some level but I never had any concrete plans. I think the build was mostly triggered by a random idea to try out a front end design using the fairly new 1x1 slope pieces for the hood corners. Once I had a decent version of the front end laid out, I decided to continue with the rest and see what happens. As usual there were many versions on the way and everything was changed many times over to arrive at the final design. The build takes some inspiration from the Lego Ideas 21108 set, obviously there are some similarities in part usage and the size in particular, but other than that I have made it fully from ground up. I had to use quite a few different techniques here and there to achieve the shapes I was looking for, and the car is actually made out of a few differently built sections. The base is a brick-built with the side skirts facing out, the front section has bricks facing more or less every possible way; up, down, front and sides, and the side and back panels are plate-built, sitting on top of the base. But with some useful new pieces (like the 3386 1x1x2/3 modified brick with a stud on top and side) it was possible to "bolt" everything together quite sturdily. Some more pictures: As usual in my cars, no opening doors or windows but the roof is fairly easy to take out to reveal the interior. I added the main interior details and there is room for 4 minifigures, sitting in the same arrangement as the original (2 in front and 2 in the back but on right side facing each other). The Ecto-1 is fairly large vehicle to begin with, and with all the associated details the part count is also almost double to a "standard" Speed Champions style car at around 600, but that's how it is for the official sets as well. It was a fairly big project overall, but I'm quite happy about how it came out so I made the instructions for this one as well. More information can be found on Rebrickable: https://rebrickable.com/mocs/MOC-168757/firefabric/1959-cadillac-ecto-1/
- 10 replies
- ghostbusters
- ecto-1
(and 2 more)
Tagged with:
This model was heavily inspired by the 2014 original eight-studs wide Ghostbusters Ecto-1 (set 21108) and a MOD of that set I found on Rebrickable. Instead of a late-50's Cadillac Miller-Meteor ambulance, it's now based on the (very similar) '59 Cadillac Eldorado. In the changeover, I added a hardtop (removable) roof, different mirrors, 1/2-stud offset side-by-side seating for two, and opening doors. I also changed around the wheels to be less stressful to assemble compared to the original 2014 set. Rear view, with driver's side door opened up. The opening doors were taken from the Ecto-1 and 2 (set 75828) from 2016. The roof is only connected by two studs, making it easily removable. The car seats two figures easily. I plan on getting one of these in real life in a different color sometime in the near future, probably soon after Emmet's house parts arrive from Bricklink. Got any thoughts comments, or questions? Leave 'em below!
full life scale PKE-meter (psychokinetic energy meter) from Ghostbusters Building Instructions on rebrickable: https://rebrickable.com/mocs/MOC-97668 My version of the psychokinetic energy meter as it apeared in Ghostbusters I (1984), Ghostbusters II (1989) and Ghostbusters Afterlife (aka Legacy, 2020/2021) Yup it's that strange detector, that Phoebe finds. from ghostbusters wiki Next to the Proton Packs and the Ghost Traps this is probably the most iconic of Ray's and Egon's devices from Ghostbusters (I don't count Ecto and the Condamnent Unit). I have been making a lot of MOCs lately including some motorized 76204 Batman Tumbler. And as a kid I was such a Ghostbusters nerd that I just have to MOC some of their equipment. I started with the PKE because it's the smallest. Maybe I will do the ghost trap next (maybe even the new RTV). Feature The wings (antennas or whatever they may be) can be flipped out by pulling a small lever at the back. I was done with the handheld scanner and proudly presented it to my wife. Her very first question: "Is there some mechanic to flip out the antennas?" so I had to figure out a way, which was quite complicated because this build is so weired already with studs going in every direction, and the inside looking like knitted rather than plugged. Anyway I found a stable solution. You have to build very carefully and make sure, no bricks are twisted but then it works. I dont yet have all the parts but I did build a test prototype (look at the left half and ignore the colours) to make sure it works while developing the instructions in bricklink studio. LED-light-ready: I developed this, keeping in mind the option to add those tiny LED lights. So I left some spaces behind the clear bricks, for you to be able to add LEDS, and there is a 15% dicount for gameofbricks.eu as usual. AND have a look at my Invisible 10274 Ecto-1 Motorization (Ghostbusters 3 Legacy / Afterlife)
- ghostbusters
- ecto-1
(and 2 more)
Tagged with:
I got the Ecto for christmas and I felt the urge to squeeze in some remote controlled Motors. The new Powered Up have just the thing (although they are badly documented) One month after christmas I had it up and running. Tell me what you think. • quasi invisible • minimal invasive - all gadgets work • Battery replacement with no dissambling • light and sound kit still fits in • Lego POWERED UP Bluetooth Remote Control • no discontinued Power Functions • complete Instructions on rebrickable I made my first video about that: For this motorization I used LEGO's Powered Up Large Technic Motor for steering. That thing is just made to be used for the steering. It can act like a servo, because it has an internal position sensor. It is slim and dark bluish gray so it replaces that kardan drive below the front seat perfectly. Aditionally I didn't want to take it appart every time I change the batteries, so you can reacht it from the bottom.
From days of long ago, from the uncharted regions of the nerdy-verse, comes a legend, the legend of Nerdtron: Defender of the 80's! A mighty robot loved by good, feared by evil! This totally tubular titan is comprised of some of the most iconic pop culture vehicles of the 80's, such as the Ecto-1, Delorean time machine, A-Team Van, and the Teenage Mutant Ninja Turtles Party Wagon, and Nerdly forms the head. Sporting a glorious mullet, shoulder pads, and a walkman, our heroic 80's icons are ready to take on the Shredder, Biff, ghosts, or any other evil foe that threatens our nostalgia! This is my entry for the Nerdvember contest on Bricknerd. It was inspired by an illustration that I came across in an image search. If this isn't the nerdiest, most 80's thing you've ever seen, I don't know what is! Nerdtron: Defender of the 80's by Okay Yaramanoglu, on Flickr Here he is, ready to spring into action! Nerdtron action pose by Okay Yaramanoglu, on Flickr Behold the glory of the back of Nerdly's mullet! Nerdtron back by Okay Yaramanoglu, on Flickr When he's not fighting crime, Nerdtron likes to relax and listen to some rad 80's tunes on his walkman. Even giant robots need a break sometimes. Nerdtron resting by Okay Yaramanoglu, on Flickr Here are Nerdly and the vehicles when they haven't formed Nerdtron. Some assembly required. Nerdtron disassembled by Okay Yaramanoglu, on Flickr I had a lot of fun designing 6-wide versions of these iconic vehicles, so let's take a closer look at them. First up we have the DeLorean time machine from Back to the Future. Nerdtron DeLorean front by Okay Yaramanoglu, on Flickr Nerdtron Delorean back by Okay Yaramanoglu, on Flickr When there's something strange in your neighborhood, who ya gonna call? The 6-wide Ghostbusters Ecto-1 of course! This one was the most detailed and most challenging one to build at this scale. Nerdtron Ecto-1 front by Okay Yaramanoglu, on Flickr Nerdtron Ecto-1 back by Okay Yaramanoglu, on Flickr Cowabunga! Here come the Teenage Mutant Ninja Turtles in their Party Wagon! Nerdtron TMNT Party Wagon front by Okay Yaramanoglu, on Flickr The two Technic holes in the back are where the legs slot into. Nerdtron TMNT Party Wagon back by Okay Yaramanoglu, on Flickr I love it when a MOC comes together. Such as this A-Team van. Nerdtron A-Team Van front by Okay Yaramanoglu, on Flickr Nerdtron A-Team Van back by Okay Yaramanoglu, on Flickr I apologize for the poor quality of the pictures as I had to take them last minute. I hope you like it nonetheless.
- 7 replies
- nerdvember
- moc
- (and 9 more)
This is my version of the ecto-1a. I bought a second ecto-1 from lego ideas, I changed the roof and put sticker on it. The result is very nice. Now I have the ecto's from the three movies. I really like the result. Please tell me what you think of it. Do you like it or not?
- 4 replies
- ghostbusters
- ecto-1
- (and 4 more)
Hi, First and foremost, i'm French. I do my best to avoid grammatical and spelling error but some (a lot in fact) may subsist. I'm sorry for that by advance. Second, it's my first post here! Hopefully not the last. So here is my mod based on the set 21108 Ghostbusters Ecto-1 car. It's a fully custom made light mod. Key feature of this is: - NO modification of ANY Lego bricks. - NO kragle or drilling or any other funky stuff. - Everything must fit inside. - Hide the mod as much as it can be. - All should work as expected (the strobes strobe, the rotating beacon rotate, etc). The mod is made of 28 LEDs, all controlled by an Arduino board. All wire are INSIDE the car. // All images are clickable for a bigger version. Here is the exterior shots, everything is exactly like every set: The roof portion is still detachable without any hanging wire, it's also clean underneath. Nothing cheap to hide a messy mod: Everything is controlled by an Arduino Pro Mini (Not really a choice, it was the smallest Arduino board I had in home) that is hidden under a 4x2 plates: Same apply for the battery, that was what I had at the time of building. A smaller lipo can be fit so it's not a choice. Run time is... Well I don't know. It fit in the trunk of the car and it's the ideal size to be held by the window mounting point after a small change in the design. Neat! The roof is attached by a very thin wire and connectedto it via a small 45° home made adapter: To start the Arduino, there's a hidden Reed sensor which is (for who don't know) triggered by a magnet. I put a neodyme magnet in a small Lego round piece and when it's in place underneath, the controller is powered on. Yup, the Ecto-1 keyfob is a Lego piece with a magnet in it. Then the magic begin: Pictures don't do justice for the lighting sequence so here is a small video: For those of you where Youtube cry for a copyright infringement (soundtrack to match the car....), here is one that work (it was an earlier version without the embedded electronique like on these photos: If you have question, i'll be glad to answer them. Troll included.
- 79 replies
- 21108
- ghostbusters
- (and 4 more)
I felt this warranted a separate topic since I have completed my Ecto-1 modification. When I first bought Ecto-1 I was excited that it became an official set, but lacked many of the qualities I remember from the film. Flails did a beautiful rendition of the car in June 2014 and gave away the LDD file on his site. I rebuilt the interior and heavily modified his file to suite my needs. From his interior appearance I would say its about 70% his design, but I wanted several things shown from the film inside this car. Major Improvements: 1. Roof rack. I used Brickarms' Monopod, two U-Clips, Brick Train's 1-N Ladder, and a cut down LEGO bar to achieve a more accurate depiction. I wish the Ladder was smoother and not 3d Printed. Maybe I will find time to cut LEGO Ladders and glue them together to make this better. 2. The front driver's seat includes a nice slope bench seat as did the old cadillac. 3. I also reworked the floor and computer terminal in the back seat area to fit the actual echo-1. 4. All new front headlights build. I wanted the tires and lights sit the way you see them in the film. Closer to the front. 5. The structure inside the car underneath the seats and trunk were completely reworked so it was stronger. 6. One of the most notable differences are on the rear tail fins. I am quite proud of making these 4 studs long instead of 3 studs. I understand why LEGO did it since there are tires behind them, but with slight changes on the structure, the 4 stud wedge plates look much closer to the sleek ambulance. 7. Blue hose modification. I use two white Brickarms U-Clips and a cut down flex cable. 8. Everything is now Chromed What I may do now that I have all my parts, cut down the red bars on the roof and make it 2 studs long. You can download the final LDD file here http://www.chrisehno...cto1_051016.lxf You can see the rest of the album here on my new flickr page: https://flic.kr/s/aHskDhtzJT LEGO Echo-1 Mod by Chris Ehnot, on Flickr LEGO Echo-1 Mod by Chris Ehnot, on Flickr LEGO Echo-1 Mod by Chris Ehnot, on Flickr LEGO Echo-1 Mod by Chris Ehnot, on Flickr LEGO Echo-1 Mod by Chris Ehnot, on Flickr LEGO Echo-1 Mod by Chris Ehnot, on Flickr LEGO Echo-1 Mod by Chris Ehnot, on Flickr LEGO Echo-1 Mod by Chris Ehnot, on Flickr
- 3 replies
- ecto-1
- ghostbusters
(and 1 more)
Tagged with:
