Showing results for tags 'brushed motor'.
A creative video of RC modification from @Kenneth Klapper, using high-performance RC components from ZENE Bricks。 Two 3S batteries, Two ZENE motors with 1:4 planetary reducers, Two ZENE metal differentials, and other accessories. Based on the modification of Lego's 42177 Mercedes G500 6x6, it has perfect power and off-road capabilities, can be driven in various terrains, and has extremely high playability. You can see that it is easy to drive on the grass without using high-power. Designer @K4enneth7 video: Lego MOC Brabus G900
Hi folks, Most LEGO boats have out-board motors. Not very elegant, not very fast. I felt a strong urge to find out if in-board was possible. And, if the LEGO hulls could handle some speed. Although it did require a 3D-printed part (a so called stuffing tube), it worked out well. Built in some 2.4GHz RC components to make sure the boat could be controlled from a distance. And included a modest brushed elektromotor. Please have a look at the result hereunder. Leave a comment if you wish to see more details. Happy to share. Currently working on a optimized version: The prop behind the boat, not under the boat. Less resistance, more speed, more control.
- 21 replies
