Showing results for tags '42141'.
I know it’s a bit early But while we wait for the set to be released… I don’t like the cylinder parts much anymore, so I intend to modify the engine. Judging from the photos we’ve seen, the engine is connected through the two connector blocks and apparently nowhere else. I’ve tried to make a new engine of the same size but of the kind I prefer, and with an attempt at a fake split turbo. Assuming there is a bit of space above where one connector block would be, the spinning ‘compressor wheel’ would be visible from the slot in the bodywork. Depending on the clearance beneath the engine, there’s a geared solution that would make the ‘compressor’ spin faster, and a rubber band solution that takes up less space. How bad it it? Suggestions?
Hi folks, I'm happy to present my 42141 alternate build, which seems to be the first alternate model of McLaren Formula 1 released so far. Instructions can be found as usual on rebrickable. This Crash Team Racer Fun-Kart is an alternate build of set 42141 McLaren Formula 1 from 2022. No other parts are required to build this model. The model uses 3 spare parts that are included in the set 42141, with a total parts count of 1257. Keep in mind that the set 42141 McLaren Formula 1 comes in different versions with different sticker sheets that do not affect the build of this alternate model. If you own any of the set 42141 McLaren Formula 1, you can completely build this Crash Team Racer alternate model without any restriction. What is a Crash Team Racer? This Kart is driven by the character Crash Bandicoot in the 1999 video game Crash Team Racing and Crash Nitro Kart as competitor to the very popular Mario-Kart games. In 2019, the game Crash Team Racing Nitro Fueled was released as remastered version for next-gen consoles, where this Kart appears again in better quality. You'll find renderings from the video game at the end of this article. Functions & Features smooth independent suspension in front and back steering with working steering wheel piston engine driven by differential through rear axle custom built engine block detailed design with many fun to play 39cm x 29cm x 19cm Impressions Testdriver Schorch seems very happy with the finished model... The giant exhaust pipes with flames are easy removable for a more common look... Custom built engine Because the standard engine parts won't fit at the scale of this alternate model, the highlight of this build is the custom made engine block, which works pretty well with a nice sound. Instructions The premium instructions for this Crash Team Racer comes with 258 pages of high quality images and steps to ensure a challenging but satisfying building experience with many cool building solutions. Instructions can be found on rebrickable. Following are some example pages of the instructions: Racer from the video game Have fun with this Crash Team Racer alternate build.
From promobricks.de: All Formula 1 fans can look forward to a new car in March. This consists of 1431 parts and should cost 179.99 euros. It is not yet known which racing team the car comes from. It seems most likely to us that LEGO will enter into a partnership with the current all-time favorite Mercedes or the no less legendary Ferrari. Due to the release date, however, it should be certain that the bolide will be based on the design of the coming 2022 season. Set number: 42141 Number of parts: 1431 Release date: March 01, 2022 Recommended age: 18+ RRP: 179.99 euros
