Showing results for tags '4-6-4'.
Before we get to the real model pictures, first, let's set the scene: It's Friday, January 13th 1939: The Civil War in Spain is raging, Neville Chamberlain (British Prime Minster) has just started conferencing with Pope Pius XI after talking with Mussolini for the past few days, and the film 'Son of Frankenstein' is released into theaters. In a rural area west of New York on the NYC Railroad's four track water level route, a J-3 streamlined Hudson is pulling a passenger train through a picturesque snowy landscape of the early morning while heading for the Grand Central Terminal of the Big Apple. ...And now, onto the finished real-world MOC! The entire train in real bricks. This Dreyfuss-style streamlined 4-6-4 steam loco is numbered 5448 and is mostly modeled after a real, long-scrapped New York Central engine. The loco's tender really should say the railroad's full name of New York Central instead of its initials, but I don't want to shell out the money for all those 1 x 1 tiles, so I'm using fewer 2x2 tiles instead to spell out NYC, as it's much cheaper that way! the combine three coaches the observation car. I was originally going to use the new 3x3 macaroni bricks in trans-clear for the rear window, but I couldn't obtain them. Frustrated, I gave up and made my own version. Note: As some of you might be able to guess, this loco with matching coaches were inspired by pictures of Anthony Sava's original streamlined Tequila Sunrise train from 2007... however, no instructions were used to build the engine or cars. Oh, and all the historical things stated in the intro actually happened on the stated day in 1939 according to Wikipedia... and I'll bet the train bit happened too! Thoughts?
- 1930s
- new york central
(and 8 more)
Tagged with:
NOTE: As some of you might be able to guess, the loco was inspired by pictures of @SavaTheAggie's original streamlined Hudson locomotive from 2007... no instructions were used to build this engine. See the inspiration here on Flickr. So you think I'm building a streamlined passenger train too, right? After all, it's a streamlined locomotive... ..WRONG! Yes, I know the streamlined Hudson's never pulled freight in the real world. HOWEVER: The Iron Giant animated film has a New York Central streamlined Hudson pulling a coal train that is badly wrecked (accidentally) by the robot. As I have the Iron Giant model already built, this was a no-brainer to make. Along with the engine and tender, there are going to be four coal hoppers, as you will see. Front view of the loco. This Dreyfuss-style streamlined 4-6-4 steam loco is numbered 5448 and is mostly modeled after a real, long-scrapped New York Central engine. The tender really should say the railroad's full name of New York Central instead of its initials, but I don't want to shell out the money for all those 1 x 1 tiles, so I'm using fewer 2x2 tiles instead to spell out NYC, as it's much cheaper that way! The cab of the loco is actually unable to fit a mini figure inside. (It's a brick too short.) These four heavily modified copies of the 1991 set 4536. (Blue Hopper Car) They lack the drop--bottom dumping feature of the set, as I made it much simpler (and cheaper!) by removing the playability from the cars. As you can see, I also had to shorten the train by one car from the original five down to four. This was because I ran out of room in the box to store them with some other freight cars. Now, if the train gets wrecked by a big metal man, I obviously need to add him to the post too! This is not my MOC: I bought the instructions for the model from B3 customs back in 2021. I found them on my hard drive again in late July 2023 and decided to build him in LDD. Then, in mid-August, I built him in real life... and promptly forgot to take photos of the completed model for over four months until November of last year. (whoops!) The rear of the robot. The original models' rotating hip joints (as used in the Build Better Bricks instructions) were removed from this version of the model because it was not strong enough. If the parts were worn even slightly, then the robot would not stand up under his own weight, breaking at the hip. Thoughts, comments or questions welcome! Updates: 1/30/24 real world photos added of everything, including Iron Giant!
- 33 replies
- coal
- locomotive
(and 10 more)
Tagged with:
Hello I like to share the result of Spark Industries' new side project. The company produces modern locos and cars, but wants to salute the old times. So designed a steam engine with enthusiasm and love. She is a 4-6-4 Hudson type loco: There wasn't a particular real loco for modelling, but the main shape based on Canadian Pacific 2816 and Union Pacific 844. She looks best on bigger turning radius, but deals with the standart lego curve and switch. The built width is 7..8 studs. The loco is 54 long, and with the tender it's 83. The Big Ben Bricks' XL wheels fitted mostly for the desired scale. Some curiosity: The steam valve is a built in little pneumatic cylinder. PF cable used for pipeline imitation: The handrails on the boiler's two side made of the very old technic flex system's inner cable. Electric side: 2 PF train motor 1 PF L motor 1 PF IR receiver (v2) 1 PF battery box 1 PF extension cable (50cm) 1 PF polarity switch The tender contains all the PF elements, except the L motor and the extension cable. Two train motors are attached to one output of the IR receiver (of course, one of them with the polarity switch). The L motor is in the loco, connected to the other IR receiver out. That way, it's possibble to start the loco with full voltage, the big wheels slipping, and then turn on the main drivers in the tender. Some more pics: Hope You like it!
- 26 replies
- steam loco
- moc
(and 4 more)
Tagged with:
