Showing results for tags '4 speed'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 3 results
  1. I've been starting on the bodywork and have added a quick clip of a flush mounted door mechanism. I'll periodically add bits until it's done, enjoy (Above pic is a link to video) This is my current supercar WIP. It has fully independent suspension, torsion bar, cantilevered front, typical rear, and sway bars. steering with attached steering wheel one servo, drive 2x XL, custom miniature V12 engine on an AWD chassis with a remote driven four speed sequential gearbox powered by an M motor. Race jacks with remote compressor, adjustable rear wing, tilt steering wheel, pedals with feedback, adjustable with single lever tilt and slide seats. Photos: https://flic.kr/s/aHskUraaNt Flush mounted door hinge operation by Dugald Cameron, on Flickr Let me know what you think! Video edit and teardown to follow!
  2. Hi Fellas, I've built a gearbox for 4x4 vehicles and it is rather space efficient. Hope you find it usefull. As usual, I'm being lazy and copy-paste the video description as it has all the basic info. Please feel free to ask, judge, or comment and I try to give my best in the reply It is rather small, I'd love to claim that it is the smallest of it's kind. (but I'm not sure, so I don't say that yet.) Help me find out. Dimensions: L: 7 studs W: 9 studs H: 5 studs Comes with the usual gear ratios: 1st gear 8/24 x 16/24 2nd gear 8/24 x 16/16 3rd gear 16/24 4th gear 16/16 The selector lever required some attention as the upper axles are 5 stud apart. I've been using some rare parts there: -Technic Ball Joint with Through Axle Hole http://www.bricklink.com/v2/catalog/catalogitem.page?P=53585#T=C -Bar 4L (Lightsaber Blade / Wand) http://www.bricklink.com/v2/catalog/catalogitem.page?P=30374&idColor=16#T=C&C=16 However this lever mechanism can do the shifting quite well, it still not "stupidproof" and need some attention while changing gears. The frame (housing) First. It is made so colorfull to help you dear watcher separate the parts on the video. For motorized version I recommend to rebuild the housing using studded technic parts. Input/Output Outputs are self-explanatory, two red axle ends sticking out from the differential. The input in the other hand is the axle with the 8tooth gear on the front. It is offset by 2 studs, but using a pair of gears it can be transfered to the center too. Whats more, it can be done on the front as well as on the rear side. Thank for your attention
  3. Hi Everyone! I just created this, and thought I would share, as it might give someone an idea for a us in a Moc or something. I'm thinking a car perhaps with seats on top. It could only be 3 studs high. It basically gears around the stationary motors and I'm guessing creates the following ratios. 1 motor equals 4:1 2 motors equals 2:1 3 motors equals 4:3 And 4 motors equal 1:1 output. Now if you could create a level on the remotes that engages 1 channel at a time, you would have silky smooth gear changes! Sorry if this has been done before!
