Showing results for tags '3368'.
Get ready to blast off into the unknown vastness of outer space! This model was inspired by set 3831, (Rocket Ride, from the 2008 Spongebob line) albeit with a pointier nose cone, and gray color scheme. The model now has a enlarged engine section with longer tail fins and four more engines, along with a crew of two humans and a robot helper. One of the human astronauts can even be seated in the fold-open cockpit. (The below story line is 100% fiction.) This ship is the forerunner for all of the other Lego space ships: in 1969, this crucial piece of history launched from LegoLand Space Port for a mission to the moon. This was very soon after the failed 1965 launch of 801-series Space Rocket, which killed the the brave crew of Kat Aclysm: female rocket science genius and designer of the experimental ship, and Abraham "Abe" Normal, the best test pilot in the academy. Their deaths at the Samsonite launch pad were not in vain though, as the newly founded LegoLand Aero-Space Authority (renamed Classic Space Command in 1978) rebuilt their reputation as the premier brick-built space agency by launching the "Innovator", also known as LL002 which in early August 1969 made history as the first mini figure - built object on the moon! This rocket and it's crew (Bill Fold, Penny Wise, and S1L-V3R the robot) made history with their two days on the moon's surface, providing the foundations for the Classic Space Moon-base series of missions. The model without the figures The model now has a enlarged engine section with longer tail fins and four more engines. The rocket features an opening section to get at the interior which now only consists of the cockpit. The model was too weak in real life when the whole thing opened up, so I was forced to solidify every section to keep it from falling apart. The trans-clear windscreen part should have this print. The crew of this fateful mission was commander Bill Fold and scientist Penny Wise, along with their robot helper S1L-V3R. (nicknamed Silver) The robot is inspired by the robot customer in the 2007 set number 4981 (another Spongebob set called The Chum Bucket), while the astronauts were inspired by the Sandy Cheeks mini-figure in set 3831. The mini-figures should feature this torso print. MISSION NOTES: Here is the inspirational set 3831, courtesy of Brickset... ...and here is the original real life version of the rocket. The LDD file for the updated rocket itself is here. As usual, comments, questions, complaints and suggestions are welcome! EDIT 6/24/17: LDD file and pictures updated for the larger and now multi-engine rocket.
