Sign in to follow this
Saberwing40k
Saberwing40k's WIP and Ideas thread.
Well, I've got a bunch of ideas and other random things, as I am building more often, so rather than make a dedicated thread for every off the cuff thing or proof of concept I turn out, I'm just going to compile it here.
The first item is a proof of concept chassis for a Gottwald crane, which I meant to be an AK-912, but there are many different models that have a similar chassis, including the AMK-1000, and the AK-680. It's a WIP, but I have other projects I want to finish first, so I made this, and am currently working on an LDD file. Once that file is finished, this thing will be taken apart, so I can use the pieces for other projects, and once I am ready to give this my all, I will use the LDD file to rebuild it.
26215092061_e9b4a3ce4e.jpgGottwald AK-912 chassis. by Saberwing007, on Flickr
The model is meant to be like an official set, like 42043, meaning one motor, and no RC. The chassi has a V-12 engine, like the real thing, and 8 wheel drive, with a single middle differential. I found that given how far apart the axles are, a differential is required between the 2 sets of driven axles. The different angle between the steering axles is achieved by a diagonal beam, which is very effective. There is almost no backlash, and the axles are in sync automatically. Also, due to how it works, the axles are set to the correct angle relative to each other automatically, due to how it is built, without any calculations.
Another picture of the front unit:
26188906602_cfc151e639.jpgGottwald AK-912 chassis. by Saberwing007, on Flickr
In addition, the chassis can be separated into three parts, like the real thing.
26215291971_a8f243cd63.jpgSeperate by Saberwing007, on Flickr
Although the steering on the front and rear units works well, it's connecting the two that has proven problematic. I blame lack of stiffness in the middle reversing linkage, and using friction pins for every steering connection. But, for now, this is finished. I will get back to it later, I don't know how much later, though.
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
