R0Sch Posted April 19 Posted April 19 F&F Dodge Charger R/T Set nr.: 42231 Age rating: 18+ Piece count: 1516 Release date: ~06/2026 Price: 149,99 € (9,89 ct/part) New parts: 2x2 corner panels used for the grille. Quote
Stereo Posted April 19 Posted April 19 I wonder what the balls in the corners of the trunk are for. Maybe it lines up the panels the brakelights are on? Quote
Auroralampinen Posted April 19 Posted April 19 (edited) 9 minutes ago, Jurss said: What are the parts behind air intake, at back of it? Maybe the new mysterious element which gives the 42242 the 4x4 drivetrain with steering:). One more picture maybe now you can see betterly the new part:). Ok, the rear wheels seems to be new. They are apparently a wider version of the 42213 Ford Bronco wheel which this model uses in the front:). Edited April 19 by Auroralampinen Quote
Timorzelorzworz Posted April 19 Posted April 19 Boring set. It's difficult to follow in the footsteps of 42111 from 2020. 42111 has more functions in smaller scale. Quote
Jundis Posted April 19 Posted April 19 (edited) Front is nice, new tires are always welcomed. The design of the rest would have been better in normal bricks. I don't get why this has to be a technic model. Edit: What did they do with this front section? I mean: Why? Edited April 19 by Jundis Quote
Stereo Posted April 19 Posted April 19 (edited) 2 hours ago, Jurss said: What are the parts behind air intake, at back of it? I'm seeing it as a 2 x 2.5 x 1.5 stud block, with a curve the same as the cam piece & small panels: I think probably it just has the 2 axle holes visible at the top, and is decorative, cause the curves mean it can't have more connections on-grid with the 2 visible ones. But it's possible it has another axle hole where the cam piece in my picture does, that starts at a half-depth offset. Otherwise same functionality as piece 42135, but meant to look like an engine part. Edited April 19 by Stereo Quote
2GodBDGlory Posted April 19 Posted April 19 You know, I like this set! It's a legitimately cool car real-world, and I think they got the styling (realistically the most important part for a set like this) right. Functions look like independent front suspension, a live rear axle, RWD with a V8, and steering, so it has pretty well everything you'd expect. I was quite skeptical that they'd actually make wider rear tires for the rear, since I don't think it needs them, and Lego is usually pretty cheap about that kind of thing. It does seem to have a different tread pattern, though, so I guess it might be! I haven't seen the movies, but was this Charger ever outfitted with off-road tires in them? It seems like a somewhat strange tread to use here if not, though I think it mostly looks fine. The huge sidewall on those well-suited rims does look really menacing. 1 hour ago, Timorzelorzworz said: Boring set. It's difficult to follow in the footsteps of 42111 from 2020. 42111 has more functions in smaller scale. Are you sure this one is in a larger scale? My rough count has this one at 21 studs wide, and the old one at 23. And yes, it does have fewer functions, but is the only thing it's lacking the wheelie stand? That particular function was never worth much to me anyways. I can agree that it's boring in that it's repeating a topic, but I do think it's significantly improved from the last one Quote
Stereo Posted April 19 Posted April 19 3 minutes ago, 2GodBDGlory said: I haven't seen the movies, but was this Charger ever outfitted with off-road tires in them? It seems like a somewhat strange tread to use here if not, though I think it mostly looks fine. There's enough movies that you could say yes and no. Dom's original charger was most similar to this wheel+tire setup (classic small wheel muscle car), then got bigger wheels, then in the 7th movie there's a Charger-body trophy truck. Quote
2GodBDGlory Posted April 19 Posted April 19 1 minute ago, Stereo said: There's enough movies that you could say yes and no. Dom's original charger was most similar to this wheel+tire setup (classic small wheel muscle car), then got bigger wheels, then in the 7th movie there's a Charger-body trophy truck. Thanks, so probably they're going for the original movie look here? This is no full trophy truck build. I guess the off-road tread is unnecessary then, but I don't really mind; the overall wheel proportion setup looks great to me! Quote
Auroralampinen Posted April 19 Posted April 19 3 minutes ago, 2GodBDGlory said: This is no full trophy truck build. I guess the off-road tread is unnecessary then, but I don't really mind; the overall wheel proportion setup looks great to me! Well, i don't mind the "off road" tire pattern because some old school tires had very similar pattern but not excatly same. Glad this model didn't come with giant wheel hubs compared to the scale with really skinny tires like in the previous charger model:). Quote
2GodBDGlory Posted April 19 Posted April 19 4 minutes ago, Auroralampinen said: Well, i don't mind the "off road" tire pattern because some old school tires had very similar pattern but not excatly same. Glad this model didn't come with giant wheel hubs compared to the scale with really skinny tires like in the previous charger model:). Maybe for some old cars, but I don't think it would have been for a performance car like this.--I think the one in your picture is a rather unusually modified one. Jundis' post above has a nice shot of what I would want the tread to look like. Still, I don't particularly mind, and I definitely agree that this is better than the skinny tires in the last one! I wonder how it would look with the rear tires from the latest Ford GT. 49.5mm vs the 55.9 here. Probably not as good, but I'd be curious to see. That's a minor complaint, though, and I like the tires overall! Quote
Oh_Hi_Mao Posted April 19 Posted April 19 1 hour ago, 2GodBDGlory said: You know, I like this set! It's a legitimately cool car real-world, and I think they got the styling (realistically the most important part for a set like this) right. Sorry, Styling should not be the most important part for TECHNIC set... Quote
Timorzelorzworz Posted April 19 Posted April 19 2 hours ago, 2GodBDGlory said: Are you sure this one is in a larger scale? My rough count has this one at 21 studs wide, and the old one at 23. And yes, it does have fewer functions, but is the only thing it's lacking the wheelie stand? That particular function was never worth much to me anyways. I can agree that it's boring in that it's repeating a topic, but I do think it's significantly improved from the last one You are right. It is taller than 42111 but simply looks bigger on the box with more parts. Quote
2GodBDGlory Posted April 19 Posted April 19 53 minutes ago, Oh_Hi_Mao said: Sorry, Styling should not be the most important part for TECHNIC set... Oh, I never said it should be, just that realistically it is for this type of set in the market Quote
SAM1626 Posted April 20 Posted April 20 I'm sorry to say, I am very disappointed, it kinda sucks. I mean some of the body looks better than 42111 but the amount of stickers used is a huge turn off the hood styling is wacky and I don't see a wheelie stand. I will admit I do find the wheelie stand on 42111 useless but its the thought that counts, right? and the front barrette on 42111 is really annoying because of how brittle it is, but it still looks better. Overall I feel disappointed in this model. P.S. When did we get those new cylinders? Have I been living under a rock and just not noticed them before now? Quote
Auroralampinen Posted April 20 Posted April 20 (edited) 5 minutes ago, SAM1626 said: P.S. When did we get those new cylinders? Have I been living under a rock and just not noticed them before now? The engine parts were introduced in 2025 in Ferrari and Red bull cars. This is the first non F1 car to have those and first V8 made with these pieces. (The F1 sets were V6) :). Edited April 20 by Auroralampinen Quote
SAM1626 Posted April 20 Posted April 20 1 minute ago, Auroralampinen said: 6 minutes ago, SAM1626 said: P.S. When did we get those new cylinders? Have I been living under a rock and just not noticed them before now? The engine parts were introduced in 2025 in Ferrari and Red bull cars. This is the first non F1 car to have those and first V6 made bu these pieces. (The F1 sets were V6) :). Thanks I haven't paid enough attention to the F1 cars, though I need to as I just ordered one finally. Quote
Satisfied Posted April 20 Posted April 20 Does this model not have the front end tilting up function like the 42111? It looks way better than the 42111 aesthetically though. Quote
SAM1626 Posted April 20 Posted April 20 1 hour ago, Satisfied said: Does this model not have the front end tilting up function like the 42111? It looks way better than the 42111 aesthetically though. Do you mean a wheelie stand? If so no it does not appear to but after people start getting their hands on it, I am sure someone will make one. Quote
thekoRngear Posted April 20 Posted April 20 Look's authenticity-wise I like this set. Hope the whole package turns out as good as it can get, I am positive. Quote
Divitis Posted April 20 Posted April 20 4 hours ago, SAM1626 said: Do you mean a wheelie stand? If so no it does not appear to but after people start getting their hands on it, I am sure someone will make one. The suspension of the rear axle was also interesting, solid axle with ball joint and links. Quote
Aleh Posted April 20 Posted April 20 The question of taste obviously but for me this is so boring - another Charger.. another car with imitated lights with stickers. Where is technic? And I unerstand why this is 18+ - because only people which were born before let's say 2000 remebmer that film. Quote
msk6003 Posted April 20 Posted April 20 (edited) Introducing new corner panel is good but it make to much gap between light and body. New parts Panel 2x2x3 corner in black is new Some strange looking piece on top of engine 2x2x2.5 in LBG is new Tire looks like 55.9x26 in black is new 42716 wheel 30x20 5 spoke in metallic silver is new 6618 mudguard 9x1x3 in black is new 7684 Beam 1x6x2 angled in LBG is new 7654 cylinder round 2x2x3 in blue is new Rare parts I can't find any rare parts. Edited April 21 by msk6003 Quote
