31 minutes ago, Ngoc Nguyen said:
In the set up with one motor and no linear clutch, there is not enough torque so the gears would skip instead.
Again, this is not necessarily true. If the motor does not have enough torque, it could just stall, without skipping the gears. Depends on whether it's easier to skip the gears or stall the motor.
I think the weakest link is the linear clutch you introduced, and the LAs have a stronger clutch (they have to lift heavy weights, so a weak clutch would make them useless).
1 minute ago, Ngoc Nguyen said:
I'll try the hard coupled motors with no linear clutch to see how they perform then.
They should perform better, the question is how do you know that? If the single motor was struggling with the boom, the two motors should be able to lift it with no (or less) struggle. But if the single motor was not struggling, only slow, then you won't see the difference.
I'll remove the linear clutch and test 1 motor vs 2 hard coupled motors.
You were right. I rebuilt the 42215 gearbox with two hard-coupled motors, this time without the linear clutch to the base LAs.
The two motors showed sufficient torque to lift the arm at playable speed.
Good to hear that there's improvement!
2 minutes ago, howitzer said:
Quite a few important Technic pieces are being discontinued at the PaB store, so now's the last chance to get them. Full list here:
https://www.newelementary.com/p/lego-pick-brick-retiring-parts.html
Ok, why the planetary gear wheel hub is getting discontinued. And most of the liebherr crane parts(weights and spools) also were single use apparently because they are also being discontinued
I guess that means none of the 2026 sets is using any of the listed parts? I'm also worried about planetary and portal hubs being discountinied, they have been one of the most versatile parts ever released. But we have seen the PU L motor being discountinied and return in the past, so I'm staying hopeful.
Maybee we could be optimistic and hope that planetary hubs will be in Audi hub housing.
Oh wow, they are phasing out a bunch of parts that were only introduced lately. But I hope that's in favor of releasing new parts! I guess they are thinking that Bricklink will take care of storing all the older parts..
I hope so too! I mean the planetary hub is surely the part that makes much of the bigger RC models possible, so why would they get rid of it completely? I really hope a new version will be introduced, and not that they would be toning down RC stuff..
Wow! Most of those losses aren't unexpected, but the planetary hub would certainly be a blow. I suppose if Lego isn't releasing real Control+ sets anymore, they might not need them? Hopefully it's just going to be a recolor or a mold change, though.
That being said, planetary hubs were really expensive on there, and I think I've now bought 4 off Bricklink and 8 clones off AliExpress, so there will still be places to get them
Unfortunatelly if they will be discontinued prices would raise since people have speculative nature...
...but lets hope for better...
Frictionless 3 module long pin is now yet again available in light bluish grey, it appears in the Gameboy switch detail.
Edited by Zerobricks
Ok, interesting. I did start developing a new tracked moc. And the left track feeled really weird, left track was really incredibly hard to connect and disconnect. And they feeled kind of brittle. Until i noticed, oh the left track is the older style(which were included in the 42055). And apparently the newer one(included in the volvo fmx) is much easier to connect. And it doesn't feel brittly anymore. I have no clue which is better terms of durability. But the newer one feels much better. And connectes and disconnectes better than the older one
Hello. I hope this is the right topic for this question.
The old 2L driving ring may slide around a 2L axle connector with ridges so that it mantains its position once shifted. The 3L driving ring can also be used around a specially designed ridged 3L axle connector that works even better, as it has only three detents (center, and either extreme) and they are more pronounced that those in the old 2L driving ring. Is there any part that works with the new 2L driving ring (2473) so that it can stay "locked" in its different positions? Or are we limited to using it with rotary changeover catches? I don't own the part yet and would like to know if it could work in "old style" gearboxes.
Many thanks!
Many thanks!
Hi, it cannot be locked. It only works with rotary catchover catches. But lucky for you my newest moc does use the new clutch, to enable the motorized pump. And i did use a friction axle pin with the red gearbox piece. And it does have enough friction to keep the newer clutch in place. Atleast in the electric compressor scenario. But i don't think heavier loads will be possible unfortunately:(.
And also, the newer clutch dont have those moving plastic begs inside which enables the locking feature. The newer clutch is completely smooth:/.
On 10/20/2025 at 9:18 PM, R0Sch said:
New Technic parts this month:
Is it possible to share the image not using imgur or PM me? As imgur refuse to add age verification to there site so can't be viewed in the UK :sad:
Yeah I get the same problem too.
