2GodBDGlory Posted January 14, 2023 Posted January 14, 2023 (edited) Just saw this newish part in Brickset's Random Part of the Day, and it looks like the part I always wanted to make compact 4-way steppers, without the 45 degree offset that knob wheels give you! It's even essentially only one stud in width (two plates plus studs) Â Edited January 14, 2023 by 2GodBDGlory Quote
SNIPE Posted January 14, 2023 Posted January 14, 2023 1 hour ago, 2GodBDGlory said: Just saw this newish part in Brickset's Random Part of the Day, and it looks like the part I always wanted to make compact 4-way steppers, without the 45 degree offset that knob wheels give you! It's even essentially only one stud in width (two plates plus studs) Â I tried this part in the sians paddle shifter as an alterative to the 24T gear and the four pin+1L beams. It didn't work however :/ Quote
2GodBDGlory Posted January 15, 2023 Posted January 15, 2023 (edited) I was just looking through a new Lego catalog, and noticed this new wheelchair wheel part, part 80441, which looks to be a half stud thick with a pinhole. I wonder what uses it might have for Technic, being so small and skinny! Edited January 15, 2023 by 2GodBDGlory Quote
Milan Posted January 15, 2023 Posted January 15, 2023 26 minutes ago, 2GodBDGlory said: I wonder what uses it might have Headlight? Quote
msk6003 Posted January 16, 2023 Posted January 16, 2023 3 hours ago, 2GodBDGlory said: I wonder what uses it might have for Technic Wheel for classic car which is polybag scale? Anyway I want that. Quote
Johnny1360 Posted January 16, 2023 Posted January 16, 2023 I have three, they work great on a half pin. Quote
Moz Posted January 16, 2023 Posted January 16, 2023 If the tyre is removable they would make great pulleys for small cranes. With the usual problem that you can't ever let them lose tension, but it's still a heap better than the alternatives. Quote
Void_S Posted January 16, 2023 Posted January 16, 2023 6 hours ago, Moz said: If the tyre is removable they would make great pulleys for small cranes. With the usual problem that you can't ever let them lose tension, but it's still a heap better than the alternatives. It is molded/glued on. Only if you remove it with some sharp tool... Quote
shroomzofdoom Posted January 20, 2023 Posted January 20, 2023 (edited) FYI, hundred+ new parts were added to Pick a Brick on the US site today. Including these little beauties and all the vibrant yellow parts from 42145! Â Â Â Edited January 20, 2023 by shroomzofdoom Quote
2GodBDGlory Posted January 20, 2023 Posted January 20, 2023 1 hour ago, shroomzofdoom said: FYI, hundred+ new parts were added to Pick a Brick on the US site today. Including these little beauties and all the vibrant yellow parts from 42145! Sweet, thanks for the heads-up! The blue 12T/20T gears were both back in stock as well, along with some other cool stuff, so I'll finally get to try some of the new gears and pins out thanks to $20 in VIP points! Quote
howitzer Posted January 21, 2023 Posted January 21, 2023 Nice, a lot of new-ish parts available, though of course nothing new from the most recent sets. Still I just put in an order of about 150€, fixing a lot of gaps in my inventory... Quote
TechnicRCRacer Posted January 21, 2023 Posted January 21, 2023 Thanks so much for the heads up! I was finally able to stock up on the small pneumatic cylinders (5 USD each!) and some other parts from 42145. Quote
shroomzofdoom Posted January 22, 2023 Posted January 22, 2023 My psychiatrist: "What makes you think you're obsessed with Lego?"Â Me: "uhhhh...."Â Quote
Takanuinuva Posted January 22, 2023 Posted January 22, 2023 On 1/20/2023 at 2:58 PM, shroomzofdoom said: FYI, hundred+ new parts were added to Pick a Brick on the US site today. Including these little beauties and all the vibrant yellow parts from 42145! Â Â Â I hope that Balljoint pin part becomes more common. It's useful Quote
SNIPE Posted January 30, 2023 Posted January 30, 2023 (edited) Anyone know if these two parts fit together? Also the upcoming stuntz sets have the small hoop pieces {77107}Â in lime, in purple and in orange, I thought the orange was bigger but I think its just photo editing trickery on lego's image(s). Â Edited January 30, 2023 by SNIPE Quote
TechnicRCRacer Posted January 30, 2023 Posted January 30, 2023 36 minutes ago, SNIPE said: he upcoming stuntz sets have the small hoop pieces {77107} in lime, in purple and in orange, I These actually appear to be a new, larger hoop piece! Quote
Mr Ogel Posted February 1, 2023 Posted February 1, 2023 On 1/31/2023 at 12:50 AM, TechnicRCRacer said: These actually appear to be a new, larger hoop piece! yep, looking at 60359 these should be 15*15, not 11*11 Quote
aeh5040 Posted February 2, 2023 Posted February 2, 2023 The pin with ball looks interesting. Any ideas what to use it for? Quote
gyenesvi Posted February 3, 2023 Posted February 3, 2023 On 2/2/2023 at 1:40 PM, aeh5040 said: The pin with ball looks interesting. Any ideas what to use it for? I find them pretty useful in linkage based steering mechanisms for example. But basically anywhere where the linkage moves and needs space, so it is good to have the mounting point of the ball pin further away from the ball so that the link does not hit the scaffold structure. Quote
shroomzofdoom Posted February 6, 2023 Posted February 6, 2023 (edited) Just started seeing my Standard PAB orders placed just after the Christmas rush start flowing in (a tad under 5 weeks to the US). I was happy to see 27940 in black and 65249 in MSG. 72008 looked interesting and fits axles so I bought a few. Not sure what I'll use them for...   Edited February 6, 2023 by shroomzofdoom Quote
SNIPE Posted February 15, 2023 Posted February 15, 2023 (edited) New curved technic panel in trans light blue:Â Â Edited February 15, 2023 by SNIPE Quote
karmadrome Posted February 16, 2023 Posted February 16, 2023 It just occured to me that one of my favourite childhood town sets, 6361 Mobile crane introduced a part that is technically the first proper liftarm ever, waaay before liftarms became a thing in Technic: https://www.bricklink.com/v2/catalog/catalogitem.page?P=2351&idColor=11#T=C&C=11 Since it is basically a 15L Liftarm with modified end with studs on both sides, I wonder if anyone ever considered using this piece in a Technic MOC. I checked Rebrickable, and there's no Technic MOC using this part. I feel it might be really useful for combining brick-built elements with technic structures. So, has anyone of you every used this piece in a Technic MOC? And speaking of liftarms, does anyone know why the technic beams are called "liftarms" after all? Quote
howitzer Posted February 16, 2023 Posted February 16, 2023 1 hour ago, karmadrome said: It just occured to me that one of my favourite childhood town sets, 6361 Mobile crane introduced a part that is technically the first proper liftarm ever, waaay before liftarms became a thing in Technic: https://www.bricklink.com/v2/catalog/catalogitem.page?P=2351&idColor=11#T=C&C=11 Since it is basically a 15L Liftarm with modified end with studs on both sides, I wonder if anyone ever considered using this piece in a Technic MOC. I checked Rebrickable, and there's no Technic MOC using this part. I feel it might be really useful for combining brick-built elements with technic structures. So, has anyone of you every used this piece in a Technic MOC? And speaking of liftarms, does anyone know why the technic beams are called "liftarms" after all? I think it's a kind of too general and too specialized part at the same time. With the length of 15 has to be a part of the structure of whatever it's used in, but in those cases normal 15L (or whatever length is suitable) is probably usually used. On the other hand, the studs on the end make it useful only on rare circumstances, and most builders probably would try to find another solution first anyway. It's also probably not that common, being used only in 16 sets over the 18 years of its production, so I don't think many people have more than one or two of those, which makes it unlikely to be considered useful in Technic builds. Also, I'm not sure if pins fit into the holes properly, the normal liftarms have an expanded recess for pin to snap into, which this doesn't seem to have. It could work if it was thinner overall, but I don't think that is the case (can't verify though, as I don't have that part at hand). Quote
SNIPE Posted February 16, 2023 Posted February 16, 2023 I have one of these parts and they are not 1L unfortunatley, but around 0.8 or 0.9L thick which makes it pretty much useless to be incorporated into a technic moc Quote
TechnicRCRacer Posted February 17, 2023 Posted February 17, 2023 I finally got around to fixing my 32181 shock absorber with a broken cap. I designed and 3D printed it, and I wanted to share the file in case anyone else also has a broken part. https://www.printables.com/model/400829-replacement-cap-for-lego-32181-damped-shock-absorb Quote
