ord Posted April 16, 2022 Posted April 16, 2022 There's some info about it here: I think it's not compatible with the powered up app but it has a rechargeable battery and quite a small volume (and maybe on-board storage?). Could have some niche uses I think. Quote
howitzer Posted April 16, 2022 Posted April 16, 2022 On 4/16/2022 at 10:26 AM, ord said: There's some info about it here: I think it's not compatible with the powered up app but it has a rechargeable battery and quite a small volume (and maybe on-board storage?). Could have some niche uses I think. Expand Thanks for the link! Niche applications was what I was also thinking, like a small car. People have been asking a replacement for the PF rechargeable battery for years, so I wonder if this could be used. Very expensive though. Quote
gyenesvi Posted April 16, 2022 Posted April 16, 2022 On 4/16/2022 at 11:44 AM, howitzer said: Niche applications was what I was also thinking, like a small car. Expand Could be pretty useful even though it has only two ports, if it wasn't soooo expensive. I have already designed (virtually) a small car chassis where this would fit really nice.. But haven't yet convinced myself to actually buy it. Quote
Jundis Posted April 17, 2022 Posted April 17, 2022 Just discovered another great video showing the potential of the Vespas tires :-) Quote
artemisovsky Posted April 20, 2022 Posted April 20, 2022 If anyone wonders that problem with cross in new elements has been fixed the answer is no. Unless I got some elements from old storage. After reporting got a second set of elements with the same faults. I also bought a few technic beams 2x5 L-shape and it seems that this problem happily does not exist in them. Quote
1gor Posted April 20, 2022 Posted April 20, 2022 That is why I don't use them with axles...and no worries about that Quote
howitzer Posted April 20, 2022 Posted April 20, 2022 On 4/20/2022 at 12:24 PM, artemisovsky said: If anyone wonders that problem with cross in new elements has been fixed the answer is no. Unless I got some elements from old storage. After reporting got a second set of elements with the same faults. I also bought a few technic beams 2x5 L-shape and it seems that this problem happily does not exist in them. Expand Yes, this problem has been discussed extensively in the earlier pages. Initially when first released, those axleholes tended to be really wonky in these elements, but later it appears that the problem has been fixed. Last year I bought the 42120 Hovercraft, and the misalignment of axleholes was strongly present while the 42121 Excavator which I bought only recently has these parts aligned as perfectly as they should. I guess you were unlucky to get a batch of old ones. Quote
shroomzofdoom Posted April 21, 2022 Posted April 21, 2022 Ok, I guess I spend too much time on lego.com buying parts. Quote
SNIPE Posted April 21, 2022 Posted April 21, 2022 (edited) Awesome idea with the sian tyres and the vespa rims and 6x8 dishes - YUM :) Edited April 21, 2022 by SNIPE Quote
artemisovsky Posted April 21, 2022 Posted April 21, 2022 On 4/20/2022 at 12:39 PM, 1gor said: That is why I don't use them with axles...and no worries about that Expand The problem starts when you need to use 2 or 3 holes - like in my bucket wheel excavator for TC22. I had to pair these elements which was a bit of pain, but still possible. On 4/20/2022 at 2:09 PM, howitzer said: Yes, this problem has been discussed extensively in the earlier pages. Initially when first released, those axleholes tended to be really wonky in these elements, but later it appears that the problem has been fixed. Last year I bought the 42120 Hovercraft, and the misalignment of axleholes was strongly present while the 42121 Excavator which I bought only recently has these parts aligned as perfectly as they should. I guess you were unlucky to get a batch of old ones. Expand In my 42120 (I bought it on March last year) axle holes orientation was correct. I saw this discussion before and one user said that the problem already looks resolved, which is why I was surprised with my order from this year. So you are right, I was just unlucky. Quote
1gor Posted April 21, 2022 Posted April 21, 2022 @artemisovsky that is why (except frames) I try to use conventional liftarms in my builds... Quote
Johnny1360 Posted April 21, 2022 Posted April 21, 2022 I have found that even though those parts don't line up perfectly, they can be easily forced into compliance, by simply utilizing a second connection point, likely stresses the parts no doubt. I have also noticed they are mismatched in pairs, hard to explain but the mismatched ones generally match each other. So if two together don't match then try one of the other ones. So although they need to get it right the pieces are still quite usable. To be honest I am more disturbed by all the new black pins being bent, than this, regardless I still hope they remedy the situation soon. Quote
mpj Posted April 27, 2022 Posted April 27, 2022 (edited) I spot half pins in dark bluish grey in the new train set. Not sure if they are the friction or frictionless version. Edited April 27, 2022 by mpj Quote
astyanax Posted April 27, 2022 Posted April 27, 2022 On 4/27/2022 at 4:55 AM, mpj said: I spot half pins in dark bluish grey in the new training set. Not sure if they are the friction or frictionless version. Expand Had noticed that too. But it might just be an illusion, that they're actually LBG. I'm not gonna draw conclusions till I see the inventory... Quote
Jurss Posted April 27, 2022 Posted April 27, 2022 On 4/27/2022 at 4:55 AM, mpj said: training set Expand Which one is that? Quote
mpj Posted April 27, 2022 Posted April 27, 2022 On 4/27/2022 at 6:51 AM, astyanax said: Had noticed that too. But it might just be an illusion, that they're actually LBG. I'm not gonna draw conclusions till I see the inventory... Expand They are inserted in LBG connectors (ar at least they look LBG connectors) and they are darker... On 4/27/2022 at 7:11 AM, Jurss said: Which one is that? Expand Sorry I meant "train" set. 60336. Quote
LvdH Posted April 27, 2022 Posted April 27, 2022 On 4/27/2022 at 10:58 AM, mpj said: They are inserted in LBG connectors (ar at least they look LBG connectors) and they are darker... Expand Those connectors look more like white than LBG. Quote
mpj Posted April 27, 2022 Posted April 27, 2022 The pins look very dark anyway, same color as the 6x6 plate below the load of the container handler. Quote
Void_S Posted April 28, 2022 Posted April 28, 2022 I saw the same photos, they are over-contrasted, with the darkest black color, DBG (under the container and rails) is slightly lighter than black, and LBG looks like DBG "under normal light". The half-pins here are equal in color to 2L axle connectors at the container handler "hand", and they are LBG, as seen at the box images... Quote
astyanax Posted May 2, 2022 Posted May 2, 2022 Is that tall structure standing on trans-pink Technic liftarms or what? (new set 71771) Quote
howitzer Posted May 2, 2022 Posted May 2, 2022 On 5/2/2022 at 2:39 PM, astyanax said: Is that tall structure standing on trans-pink Technic liftarms or what? (new set 71771) Expand So it would seem. Pretty funky one, though I can't think of a good place to use one outside of something similar to this set. Quote
astyanax Posted May 2, 2022 Posted May 2, 2022 On 5/2/2022 at 5:12 PM, howitzer said: So it would seem. Pretty funky one, though I can't think of a good place to use one outside of something similar to this set. Expand In my collection I have a bunch of transparent bent liftarms: Sometimes they're nice for making extreme head- or taillights on cars. Although the last one (in trans-neon green) I've never used... But still cool to have Quote
