Showing results for tags 'missouri river'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Description from the Museum of Transportation's website on the real vessel I based the towboat off of: The H.T. Pott was the first Missouri River towboat with a welded steel hull instead of a riveted hull. The vessel operated out of Kansas City, Missouri on the Missouri River. It is named for Herman T. Pott (1895-1982), a distinguished river transportation executive and entrepreneur. The groups of barges that are moved on the nation’s rivers are called “tows." The boats that propel the barges are “towboats” even though they push the barges from the back instead of pulling them. The H.T. Pott is 58 feet long and 15 feet wide, and it has a “draft” the amount of the hull below the water line of 6 feet. You can walk the decks of the H.T. Pott. You can see a picture of the real towboat on the Museum's website here. Notes on the LEGO model: The name of the vessel, HT Pott, will go on the studs just below the roofline on the bridge. Besides the lettering, two white brackets and four black curved plates are missing from the digital model. Also, a printed-cloth American flag will fly at the rear of the craft off the second level. The rear of the vessel, with flagpole and ladder to upper deck visible. I plan on putting this 1930's towboat and my 1880's Proud Mary steamboat on the depressed-height table holding my Eads bridge, to give a stereotypical view of life on the Missouri / Mississippi Rivers, both distant past, and more recently. (as the towboat worked the Missouri river traffic from '33 up until the middle 1980's.) Now, you may be asking yourself "What good is a towboat without something for to to push up / down the river?" This was the existential question I asked myself today, and the answer I came up with shortly thereafter was "not very good". So, I set about building something quite commonplace if you live near any of the major rivers of the mid-western USA: a pair of un-powered barges! (I think they usually use them for grain and silica, among other bulk goods, but here they are empty, mostly because like the towboat model I made, they have open bottoms.) These type I see a lot here in Saint Louis, and are of the modern variety... although I'm unsure how long they've been using this design, to be honest. It seems to be two barges next to each other, but in actuality, they are one big barge. I did this because less parts are used this way. I will eventually have two of these ancillary models hooked onto my tugboat / each other with 5-long LEGO chains. (these are not in the picture) The HT Pott is few bricks less in height (and more than a few studs shorter in length) than my 2019 sternwheeler steamboat MOC, the Proud Mary (link to it's topic). Side note: The two being near each other like this isn't exactly an anachronism, as there were a scant few steamboats still plying the rivers when the HT Pott was built in 1933. (Granted, most steamboats had seen better days and were on the way out or retrofitted for cruising duties by then, but it's still accurate!) Thoughts? EDIT 6/2/22: added real world pictures.
