Showing results for tags 'mercedes benz'.
Hello everyone, I am quite new here as well as Lego world, but I am very happy to introduce my first MOC which spent more than 2 months to complete - Mercedes Benz Arcos Tractor Truck. At first let's check some parameters of this MOC: Length: 36cm Width: 18cm Height: 25cm Parts: around 2500, 100% Lego genius PF: XL motor x1, Servo motor x1, IR receiver x1, IR controller x1, Big Battery box x1 Pneumatics: 1x6 Pump x1, 1x5 Cylinder x1, 2x11 Cylinder x1, Switch x2 I was inspired by building Muuss's MOC based on 42043 B mode. After that I thought why don't I improve something to make it more powerful and beautiful, that's why this MOC could happens. I didn't use too many rare parts, most of the parts(approx 90%) can be found from 42043 and 42029. The truck body has 19 studs width and 29 studs height, so I used 81.6x38mm wheels to compare the size. Rear axle has driving by XL motor and front axle has steering by Servo motor. There are 4 yellow absorbers in front axle and 2 in rear. The head of truck is controlled by pneumatic to open and close. The trailer locker is controlled by pneumatic as well. I didn't use PF to control the pneumatic pump because lacking of the PF You may have to manually do the pumping and switching. I put pneumatic hoses, switches and pump into black box at the back of head together with IR receiver. One switch is controlling switch cylinder on head and trailer, another is controlling cylinder open and close. It looks pretty tidy and easy to control. Some details from different position. There are not so many gear drives inside the truck so I guess you can easily build your own truck like this. I didn't have chance to make any instruction on it, but you can refer the photos as inspiration for your own build, I believe it will not be too difficult. I used my 4 years old son to have a real size comparison so you might have an idea on how big it is Check the video below for more information of this build. Hope you like it. https://www.youtube.com/embed/TfpBNqm2QJk Edit: I am not familiar on how to insert video on youtube, can only attach the URL...
- 11 replies
- truck
- mercedes benz
(and 3 more)
Tagged with:
Hi everybody. last month I started a new project, while my 42043-C Unimog U4000 is on standby. I kinda like the Mercedes Benz team. so this one will be another Zetros. while my 42043-C Zetros was a C-model, this Zetros 3643 AS 6x6, will be way bigger, and not a C-model. Below is the blueprint I'm actually building from. been during a lot of research, blueprints and calculated a proper scale many times..... so by basing the scale on the wheels I figured out that a 1:12.5 scale would fit very well. I got some RC wheels 108mm, which kinda looks like the Zetros tires, but the Claas Tractor tires will fit the model very well too. Now let me show some pictures of my actual model so far. This one was my first atempt to build a proper fitting chassis for the Zetros But after a month with rebuilds and testing, I got to scrap that design, as the gearbox wasn't strong enough to power 3-4 kg of lego. also was the chassis a bit to flexible. so during january I ended up with this design: And by now I have finished most of the chassis, on moved on to the cab. As told it is the CrewCab model I'm building, mostly because it is the one I like most, and think it fits the size of the truck very well. By finishing the Chassis, it also means that bumbers and headlights are done. I'm not quite sure about the headlights yet, but it will work for now. The picture above, is the current prgress. More will follow. more pictures at: https://flic.kr/s/aHskRFHEQB
- 21 replies
- mercedes benz
- tractor truck
(and 5 more)
Tagged with:
