Showing results for tags 'jedi interceptor'.
As my exploration of Prequel ships continues, I'm trying to shift my focus to Minifig-scale more, and decided to give a crack at Obi-Wan's sleek Delta-7 from Episode II: Attack of the Clones. At exactly 400 pieces, this compact and angular ship was full of technical challenges, especially with the constraint of making a proper interior that could accommodate a full Obi-Wan Minifigure without ending up with a bulky design. Following my "wings must be as thin as possible" philosophy (like the Eta-2), I used a combination of plates & tiles for the outline of the wings, and bricks on their sides for the rest: this resulted in 2-plate thick wings, which give the ship all its slenderness, especially seen from lower angles. At this scale, and given how compact the ship is in-universe, I wanted to respect the slim and sharp look of the original design. Making a functional cockpit with comfortable space was the most daunting task as I needed to securely attach the fin section and both angled fuselage parts that surround the cockpit without using any vertical space, where Obi-Wan sits. I also managed to incorporate a dashboard that doesn't obstruct the pilot's view and depicts the screen fairly well. The model features detachable landing gear to be displayed on the ground, as well as a canted stand for a more dynamic pose. The model is very stable overall and perfectly swooshable. ► Instructions for the Delta-7 are available on Rebrickable! More pictures on my Flickr page.
Hello there! Here is my second iteration of one of my favorite ships of Star Wars -- the Delta-7 Aethersprite Delta-7 Jedi Starfighter. @khatmorg & @atlas_er are big influences on this design -- especially the cockpit area of @khatmorg's, and the wings by @atlas_er. Biggest difference in mine is the overall length; it's shorter by two studs (which I think is more accurate). Making it a little smaller in comparison, but still has a lot of detail. Overall I'm really happy with how it came out. I tried my best to eliminate all gaps, and make it smooth as possible. I've very proud of the green accent on the back wings, and how I was able to keep the front wing/hood area smooth. The only thing I'm bummed about is that I couldn't squeeze in rear landing gear, but I love how the smooth underside came out. And the little bit of stickering on the back section to better convey the curve of the green. It's quite sturdy, but it does have some weakish points in the design. Thanks for checking it out! Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr
- 22 replies
- starfighter
- aethersprite
- (and 5 more)
