Showing results for tags 'garbage truck'.
Hi all, My son and I have been working on a minifig/city scale automated side-loading garbage truck build for the last year or so. We've finally gotten it to the point where we'd like to share it and get feedback. The bin arm is operated by a knob and reaches out and grabs and dumps standard LEGO dust bins with a plate on the bottom. There is also a ram in the hopper that is operated by a second knob. It pushes the trash into the dumper: The inside of the dumper is smooth to allow the trash to dump out: We also made a video that shows the truck and functions in action. The video may show the functions of the truck more clearly than the pictures can: We're interested to get feedback on the build. Getting the bin arm to smoothly and reliably dump trash and integrating that and the ram into a compact build was definitely one of the big challenges. The truck with some "waste" bricks is about 450 pieces. This design was created and refined with bricks on hand over the course of more than a year and at least a dozen different design iterations. We then created a model in LEGO Digital Designer and used digital renders to visualize different colors. The custom printed tiles were created digitally using LDPatternCreator, using Bricklink's Studio tool and Blender with some custom lighting for the final digital renders and some animations. The video is partly digital rendering and partly live filming. For creating actual custom printed bricks, we made color laser prints of the designs, covered them with scotch tape and then gently washed the paper off using water, leaving enough stickiness on the tape to stick to the bricks. This was quick and easy and the tiles were durable enough to play/build with, so that worked very well for our purposes. The cab holds a minifig comfortably, and there is a a hand rail and ladder for another minfig to ride along. There are clips to hold tools for cleaning up as well. There are more photos on our Flickr album: https://flic.kr/s/aHsmu32GeG We have also submitted the truck as a LEGO Ideas project. If you like the model we'd be grateful for your support. You can see our Ideas page at https://bit.ly/LegoGarbageTruck. Thanks!
Hello everyone, This is going to be (hopefully) my entry for TC10: Front Loader Garbage Truck Functions to be included: Two rear axle with differentials V4 or V6 engine Steering of course with HOG Independent suspension in front Rear axle suspension similar to AROCS Pneumatic pump via M motor or manual pump Pneumatic fork container lift Pneumatic container lift Pneumatic ejector Pneumatic door cover Pneumatic tailgate The picture below shows all the functions. Only the body raise will not be implemented (I'm out of cylinders). It will be a combination of V1 and V2 pneumatics. The scale will be similar to the AROCS, same wheels. And here is a quick prototype to check the feasibility of the front loader. I will post further progress once I get some time to work on it. Any recommendation welcome. Thank you.
- 32 replies
- tc10
- garbage truck
(and 1 more)
Tagged with:
One of my favorite Eurobricks builds over the past couple of years was the Garbage Truck @steph77 completed in 2017. It's been a while since I have made a Garbage Truck, so after Thirdwigg Jr. Jr. (6) asked if I could make one, I jumped at the opportunity. I asked if he would be willing to test it as I built it. He said yes, so we were off. First, I wanted to make the truck fully manual with the following functions: Three axle, two steering Fake engine Removable garbage container Opening compactor Extractor plate Two stage compaction cycle Bin lift/tip Everything had to work smooth enough for a child to process the smallest of LEGO parts, particularly the 1x1 plate round. Nothing could get stuck in any movement, as this would frustrate a child (and me, frankly). Back in March, I finally figured out a little design that would be the first step of the compaction function. It wasn't perfect, but it was enough to proceed. The arch part at the bottom will be where the trash is dumped into the compactor. Back of the truck is to the right. I decided to model the truck after the Dennis Olympus garbage truck/bin lorry/refuse truck, in the colors represented by this stunning little build by Jonathan Elliot. So after another build session, I created this simple bodywork. I built a draft of the compactor, and put the two parts together and came up with this. Test one with Thirdwigg Jr. Jr. identified some problems with the compaction. Currently the bottom plate does not pull up far enough, so I'll need to turn the gear mechanism around. Here you can see how it processes from one gear on the side. It's not perfect yet, but I think I may be able to get there. See the video here. We'll see where this goes, but I like what I have so far. It's been almost a year since my last large project, the Ionos Sedan, so it's time for something bigger again. Questions, Comments, Laments, and Insults always welcome...
- 25 replies
- recycling
- garbage truck
(and 3 more)
Tagged with:
Hey Guys,i need some Advice on this one. I`m planning this futuristic Garbage Truck for my imaginative Lego City-Future Theme. The Bodywork is pretty much done and i think it is recognizeale as a Garbage Truck.The two large orange Pieces are already in my Parts Bin and all the little Bits might be in there too.Maybe some Bricks need to be bricklinked or i need to buy them in the little Lego Shop in my Hometown. I`m still not sure how to make this Big Boy hover above the Ground.I would love to use something that fits in the Wheel Wells and only sticks out a little bit, you know,classic sci fi Hovercar Stuff. Maybe some shiftable Dishes or Pods. Feel free to share any Ideas.I also added the lxf File so you can poke around a little bit.Maybe you might have some Ideas to improve the whole Thing.I like it very much,but i still think something is missing.Something catchy....like a Push Bar or Guard Rails.... Any Idea would be much apprechiated. The rounded Rearend calls for a Nickname...Hunchback maybe?Still not happy with the lower rear End (behind the rear Fenders) Scifi-Garbage Hauler.lxf
Hello, I want to share my latest MOC with you guys. My creation is the common garbage truck in Taiwan street! Thanks for watching!!!
