Showing results for tags 'front loader'.
Hi guys and gals, today I'd like to present my MOC based on an old Volvo LM 841 Front Loader: The main goal was to achieve the mechanism used for the bucket with the oddly placed hydraulic/pneumatic cylinder. Due to stability, I used a 3x11 panel and could get the right mounting point for the small cylinders. Also, the narrow 1x11 cylinders I intended to use for the lift weren't strong enough, so I went with the stronger 2x7. This sadly led to a lower lift height. Pneumatic pump is placed in the cabin like in the 8455, while I rather place a fake 6 cylinder engine in the hood. In this size I went with front driven engine, although the real thing is 4WD. Main functions are: - steering with pendular rear axle - lift of the bucket - tilt of the bucket - fake inline 6 driven by front wheels I just love older equipment, which gives more a feel of old Lege technic also :-)
Finnaly found some time and inpsiration to build a proper alternate for this amazing set - Front loader. Functions: HOG steering - whole front section pivots Pendular rear axle Working 2 cylinder inline engine at the back Fully operating front boom - uses ratched mechanism to keep the desired height Angle of the shovel can be changed Opening doors As there are no access to worm gear or linear actuators, the lifting capacity is limited, but still it's possible to lift some lighter cargo. Rear axle can move freely without any suspension, therfore it's easy to overcome smaller obstacles. Whole front section is steering and is connected via the small turntable to the rest of the superstructure that enables easy and smooth steering using gear on top of the front loader. Just like with other alternates, it's possible to buy the instructions on REBRICKABLE. Cheers, TGBDZ
Here is my TC9 Entry. It is skid steer and front loader based on the real thing by JCB. A Model JCB Skid Steer: Functions: - Mini Linear Actuator Raise/Lower Boom - Manual Bucket Dump - Working Fake 3 Cylinder Diesel Engine - Four Wheel Drive (All wheels turn when any one wheel turns) - Left/Right wheels can turn in same or opposite directions to turn - Quick Detach Bucket Attachment Dimensions: - Length: 25 studs - Width: 11 studs - Height: 16 studs - Box Volume: 4400 studs B Model: JCB Front Loader: Functions: - Mini Linear Actuator To Raise/Lower Bucket - Manual Bucket Dump - Working Fake Three Cylinder Engine - Rear Wheel Drive With Differential - Rear Perpendicular Suspension - Articulated Steering Dimensions: - Length: 35 Studs - Width: 12 Studs - Height: 16 Studs - Box Volume: 6720 Studs Video: Parts left from A Model after building B Model:
- 4 replies
- tc9
- skid steer
(and 3 more)
Tagged with:
Hello All! Today I want to present small but funny model. It is reduced prototype of my future project – Rock Loader Mk II (first version was built in 2011, and I was short of parts at that time - http://www.doublebri...2/rock-loader-0). All functions have manual control. - rotation - boom rising - boom extension - bucket unloading (with lock for heavy weights) - outriggers Control, counterweights, exhaust Extended boom, Bucket lock Extended outriggers Video with functions demonstration: Thanks for watching!
I think it is about time for me to show what i have build for this contest. Please let me introduce the Volvo BM LM 620 front loader, a great old school front loader from the late seven tees. These pictures is only early wip, the entire machine is already finished. The rest will be uploaded as soon as possible... Plase feel free to comment and tell me what you think. Just added some more WIP pictures.. http://www.moc-pages.../moc.php/432762
- 12 replies
- Volvo
- front loader
(and 1 more)
Tagged with:
