Showing results for tags 'fighter jet'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Alternative Brick Brands
    • The Brick Frontier
    • CaDA
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 6 results
  1. Hi, After a few years of procrastinating, but pushed into action by the new technic Jet, I have decided to try to build my F14A Tomcat again, studless... Here is a first shot: The ambition in terms of functionality: 6 motorized functions (one motor with a manual switch gearbox): - Landing gear - Landing gear bay doors (2 for the front landing gear, 2x3 for the main landing gear) - Canopy - Swing wings - Pneumatic pump - Gatling gun 6 pneumatic functions: - Arrester hook - Brakeflaps (2 in the tail + 2 on the main wings) - Canard wing - Inlet deflector shields - Leading flaps & trailing slats on the main wings - Main landing gear lock (when landing gear is down) The aircraft is controlled with differentially controlled wings at the back so that they act as tailerons and rudders on the vertical tail wings. The whole set can be operated manually with two gears at the bottom, one to control pitch and one to control roll. I hope to be able to connect the control surfaces to the joystick in the cockpit, but space is a little tighter in the version than in my old version (I try to build to scale this time, the previous version had a too high cockpit). The front landing gear is suspended. When completely compressed the hook for the catapult on the aircraft carrier is deployed. The landing gear can also be steered with the roll control when it is deployed. The main landing gear will swivel around it's own axis when it retracts. A 3D linkage system will guide it, just like the real thing. I don't think I will add suspension to it. With the weight of the plane the suspension will always be compressed, so it is a bit useless. I'd rather use the space to make a good connection for the pneumatic lock. One thing I am not sure about whether or not I will be able to fit is the ejection seats. My previous studfull version did have ejection seats, but because the space is more limited I fear I will not be able to fit those in. The biggest question I have now is which colour to build it in (that's why the surface elements are all darkblue at this moment, I can easily select that colour and change it to the final livery)... The obvious colour choice would be LBG. Unfortunately there are hardly any panels available in LBG on BL and some panels don't even exist in that colour. For instance I expect to be using a lot of 11x3 curved panels with 10 pinholes, since the paneling will have to provide a lot of the rigidity of the structure. But these panels are only available in red, blue, yellow, black, dark blue medium azure and medium blue and not in LBG. Black is a colour that will have all parts, but it will make the plane look very, erh..., black. A white and red combo can maybe work, but will look quite stuntplane-ish I'm afraid. All red maybe? Thoughts are appreciated. I'll keep you posted on the progress, Leg godt Jeroen
  2. Hi, It has been a while since I posted a MOC, but I have not been sitting idle. Here is my latest creation, a LEGO Technic replica of the infamous F14A Tomcat: It is as densily packed as I possibly could with features. It has seven electrified functions (driven by one M-motor), six pneumatic functions and four manual functions. Driven by one M-motor and using a manual gearbox the following functions are electrified: - The engine turbines (directly coupled to the M-motor) - The rotating Gatling gun on the port side - A small pneumatic pump - The canopy - The landing gear - The eight landing gear bay doors - The main adjustable wings (in the picture above they are in the low speed, extended position) Next to that there are six pneumatic valves controlling the following functions: - Switch between the internal small vacuum pump and the external large vacuum pump - The bleed doors in the air-intakes of the engines - The delta wings at the side of the air-intakes - The arresting hook - The front and rear flaps on the main wings - The two air brakes on the main wings and the three air brakes at the end of the fuselage The plane also features a couple of manual functions: - A knob to control the pitch of the aircraft. The rear horizontal wings and the joystick are controlled with this knob. - A knob to control the roll & jaw of the aircraft. The rear horizontal wing, the vertical control surfaces and the joystick are controlled with this knob. If the landing gear is down, the front landing gear is steered with this knob as well. A special differential control mechanism is used to combine both pitch and roll control and feed only one signal to each wing. - The nacelles that contain the turbo engines can be opened and the engines can be taken out. - A double lever to activate the ejection seats. The canopy is ejected at the same time as well. This model is available as a limited edition exclusive set on my website. Finally some fun facts: The model weighs around 4 kilograms and is just shy of 4000 parts It is 87 cm long, 101 / 66 cm wide (main wings open / swept back) and 33.5 cm high when put on its stand It has ten small pneumatic cylinders and nine shock absorbers It has 549 axles, 110 gears and 111 panels Most of the functions are color coded so that you can distinguish them during the building process Comments and questions are welcome as always. Leg godt, Jeroen Ottens
  3. Enter the Eagle at Singapore Airshow 2014! This brick F-15SG comprises more than 150 parts and took more than half a year to design. It was quite a challenge to get it true to scale at this size. I’ve added in details like the airbrake and missiles, and built the wings sideways to make them as smooth as possible. The new 1x2 slope (part 11477) worked really well here. Hope you like it. Cheers! http://www.facebook....cksbencreations http://www.flickr.com/photos/bricksben http://www.bricksben.com
  4. Hi guys! Long time to see. Today I show you my new moc, the Lego NGF-1 "ArrowHead" 6th Generation Fighter Jet. The ArrowHead is a sixth generation fighter jet that has just entered service in the military aviation of Plighia, which is the first country of the PSIC Coalition to equip itself with an aircraft of this type. The ArrowHead is a compact jet, slightly larger than an F-16, with advanced stealth technology, a particular aerodynamic profile, with raider and patrol capabilities. This jet is equipped with the latest technologies in the field of avionics, sensors and armaments. Two powerful jet engines that guarantee a cruising speed of Mach 2.7 and a range of 2300 km (which can be extended with the addition of external tanks). The ArrowHead has three internal weapons bays: a large main bay on the bottom of the fuselage, and two smaller bays on the sides of the fuselage, aft of the engine inlets; a small bay for countermeasures such as flares is located behind each side bay, with the capacity to accommodate a total of 6 to 8 missiles in different configurations; the jet is also equipped with two cannons mounted under the attachment of the wings. Furthermore, the wings of the jet are equipped with 2 hardpoints each, to be able to attach other armaments or external tanks. Finally, the NGF-1 features a spacious cockpit with all-digital flight instruments, afterburners that incorporate pitch-axis thrust vectoring nozzles.
  5. An update to my 5th gen fighter: IMG_5536 by Nom Carver, en Flickr IMG_5538 by Nom Carver, en Flickr IMG_5537 by Nom Carver, en Flickr IMG_5539 by Nom Carver, en Flickr IMG_5542 by Nom Carver, en Flickr
