Showing results for tags 'circuit cubes'.
Hi, After just finishing the S-130 Project I´ve already decided to start a new one. In this case this is going to be the Renfe Class 309, a small 3 axle shunting locomotive from the 1980s. This quite a big contrast with the S-130 but I think is a perfect little project. This is the train in question: The main challenge on this project is how to power it, in this case I´m thinking about using Circuit Cubes to power the three axles. For the running gear design I decided to based it in the one made by @jtlan for his TP56 Switcher Locomotive as is one of the only examples of a 3 axle shunter that I found. Even with this base as a starting point is not easy to do this as my design is just 7 stud wide so I need to offset everything. This is a rough assembly that I have done for now: As it can be seen, the motor will be placed on the front and the battery is going to be right behind, the idea is to use them as counterweight for the heavier cab which is located on the rear just behind the last axle. And now it comes the part in which I ask for some help: Even though I have the design mostly figured out (I might need to make a prototype to see if it can work through R40 curves) my main concern is with the Circuit Cubes Motor and their power output and speed. This is a shunting locomotive so it´s not going to be as fast as the S-130 but even then, it seems that they are quite slow and might require a 1:2 gear ratio which can be simply added onto this design. My concern with this is that is going to become severly underpowered and wont be able to pull any load. I´m not expecting to pull something as massive as the S-130 cars but I would love for it to be able to maybe pull at least one of the passenger train cars that I´ve already designed (although I´m not planning on building them any time soon). This cars are massive with a weight of 1kg each, but those were the real load for this locomotive on the past. I´ve already tinkered with the idea of adding two motors but that will require a much complex redesign as I need to keep the middle axle powered through a worm screw to make it able to work through R40 curves. In this case I think there is enough interior space for me to not worry about it: I would like to know if anyone has done a proper test of the Circuit Cubes motors and knows their maximum load and speed. For now I´m going to continue working on the one motor design and make plans to order pieces for a small prototype. Imanol
Dear All, one of my favorite themes (in many regards) is Steam Punk. Steam-propelled futuristic technology, in shiny brass, gold and silver, leaning towards Jules Verne's "fiction". Not the dirty dark, maybe original punk. I am not sure whether the shiny stuff is Steam Punk at all; this genre has taken on so many forms and interpretations … Whatever, it may well be that my affection for Steam Punk comes from my admiration for Thermodynamics – in chemistry of course So guess what happened, when in late 2023 I became aware of the #85007 set “Steam Punk Railway Station” from Pantasy/China? Yes, I got sort of positively nervous. It quickly turned out that the title of the set is misleading: They use the railway station shown on the front of the box and the two instruction booklets simply to hide the Steam Punk locomotive along with one carriage. I almost freaked out, when I saw the train. And finally I passed out when I saw that the train is of the suspended monorail type … for more than two decades I was dreaming of a suspended LEGO monorail train – read more about that here: https://www.eurobricks.com/forum/index.php?/forums/topic/150261-wip-lego-monorails-custom-rail-systems-crs/&do=findComment&comment=3680627. With respect to the Dark Side: Pantasy is using GoBricks pieces (as per advertisement on the box) – and these have reached the 100%(+) LEGO quality level, no doubts. OK, as expected, has been discussed on EB. Very small injections points (barely visible), perfect colors, perfect clutch, same “softness” as the latest LEGO bricks and plates have, metal gold and silver pieces all over the place. On their website (https://pantasy.com/blogs/news), they talk about their approach, which is a quite nice read. Building that set was pure and utter fun. It was as if the Pantasy management said to the designers: “Folks, go Steam Punk nuts – no restrictions, just freak out and have fun. When you need more pieces to make it even more glitzy and punky – just do it”. 2723 pieces, BlueBrixx asks for €140, you can get it much cheaper – it is currently almost everywhere sold out, though. No surprise. This set is a blast in every regard. Motorization of the engine From day one, I wanted to motorize this model – it appears to be designed for display only. There are a couple of challenges to do so, though: For one, any propulsion system needs to turn the wheels on any of the four roller brackets the locomotive and the carriage are attached to. Second, available space is rather restricted, as the locomotive is essentially one “solid” piece of snotted ABS – except for the magic glass boiler: (At first, I thought: OK, TLG's well known color vomit coding here as well – but then was told that I was totally wrong: It is right here, where the Steam Punk magic generates the power to propel the locomotive: Inside the glass boiler. Attached is a 10 cylinder V-motor connected to the 8 blade pearl gold propeller on its back side – which actually propels the train. Well, there is no color coding at all in the entire set, except for the boiler brackets. So yes, these colors very well may represent the Steam Punk magic). Third, the elevated track Pantasy used is of the roller coaster type, JK Brickworks also employed for their suspended train (https://jkbrickworks.com/suspended-train/) and thus may be no good choice for motorizing a 700+ g heavy Steam Punk train; this will certainly will fail in roller coaster curves. The original (four individual) roller brackets look like this (Stud.io render) In conclusion, there wasn’t any space other than within the boiler for motorization, but I had no clue how to get any gears, axles, rubber bands to the wheels of the roller brackets. A medium PUp motor may fit in there, but the next challenge would have been PUp cabling and powering. The carriage also provides some space, but no LEGO hub fits in there, even after hefty modding, at least in the lower league I do my builds. But then I remembered a post not mentioning the elephant in the room, a thread @zephyr1934 created back in early 2021 on EB (https://www.eurobricks.com/forum/index.php?/forums/topic/184036-a-review-of-circuit-cubes-without-mentioning-the-elephant-in-the-room/), which deals – in addition to the Elephant in the room – also with the Circuit Cube BLE hub and Cubic motors from Tenka (https://circuitcubes.com/). Furthermore, @Asper reported on using these (@HoMa called “critters” ) for train automation of his four wide trains, whereas @Ts__ showed a prototype truck for train displays. I looked at the dimensions of the motors (the Cubic motor is 2x 2x4) and the hub (2x 4x4) – and … BOOM – brain currents got ballistic. Furthermore, the wiring between the motors and hub is done with Dupont connectors. Tenka uses 2-wire sockets receiving the corresponding two pins of the hub outputs and motor inputs; however, these sockets are too large to fit through a Technic hole. One can easily make single socket wire ends, which then do fit very well. After some tinkering, MLCad suggested: It may work. My plan was to a) motorize the 10 cylinder V-engine from “within” the boiler section, b) propel the entire train with a motor mounted on a 2-axle monorail bracket assembly, c) route the cables somehow to the hub, which is to be mounted in the carriage in a way that one can easily turn it on and off – and d) easily recharge the hub … so far, a) to c) have been accomplished; d) is on the to-do list, see below. Here we go: New roller brackets for the locomotive and the carriage, and the entire driving motor assembly (render and photographs below). I used two stacked 9V train wheels arranged in the same direction – this way, the (custom) rubber band on the driving wheel has good grip. The rubber O-ring on the powered axle for enhanced traction is one I found in the lab – the white LEGO O-rings do not provide sufficient grip, even on the 12V rails “with teeth”. Here is what I use as my monorail track (no Dark Side elements to be seen, all pure LEGO): https://www.eurobricks.com/forum/index.php?/forums/topic/150261-wip-lego-monorails-custom-rail-systems-crs/&do=findComment&comment=3680627. Photograph below: One Tenka Cubic motor “inside” the boiler, with an attached axle extending all the way to the front, rubber band connecting to the 10-cylinder motor driving axle. (Custom) cables attaching to the motor are routed through Technic holes in the boiler bracket and locomotive frame. They extend to the Circuit Cube hub mounted in the carriage. Pantasy designed the boiler essentially as an all-four-side-studded central structural element. All other parts attach to this element and, at the same time, the “side panels” secure the whole model from falling apart when lifted through snotted connections. You can remove the two large “side panels” - and are left with this when they are put together (and yes, good clutch power really shows): This is the entire engine … ... and the lightly modded carriage: The photographs below are showing the Pantasy railway station, designed as a terminal station. Some folks were complaining that the four platforms (labeled 2 to 5, prints of course - there are no stickers in this set) don’t make any sense, as the monorail runs perpendicularly to the apparent platforms. Of course this makes sense : Below are four tracks terminating at the station: (track 2) 4.5V track – coal delivery for steam locomotives on track 4 and maintenance; (track 3) 9V track – passenger and freight trains; (track 4) 9V track – real steam passenger trains; (track 5) 9V track – freight trains. The monorail is of course floating above all that; when the suspended train is leaving, all these tracks can be serviced ... duh. I thought this is the whole point … The Pantasy Railway Station … Station “unfolded”: Have a look inside: Ticket counter (right) and barista coffee stand (left) … when you push the 3-elements revolving door, the golden (Technic break) disc and the clock hands are spinning as well – this calls for additional motorization … Train 85-007 ready to depart … no surprise, should James Bond be on board … After arrival at the other terminal station: This is the Circuit Cube doing all the work; charging is from the top (see below, though), the on/off switch is easily accessible from the back of the car. To-Do list: I need to find a way of controlling the Circuit Cube hub with an ESP32. This has been demonstrated by @Asper; he has provided his code on GitHub (https://github.com/asperka/LEGORemoteCircuitCube). Steffen used a tiny M5Stack Atom and used the Visual Studio Code IDE with the Platform.IO extension described by him here: https://www.eurobricks.com/forum/index.php?/forums/topic/184878-controlling-two-circuit-cubes-with-one-lego-remote/. I’d like to use the same program I wrote for my Crocodile; this was done using the Arduino IDE and Cornelius Munz’ Legoino code (https://github.com/corneliusmunz/legoino). The reason is simple: It works with 4 optical sensors I want to use again for stopping at both terminals and acceleration/deceleration phases. We will see how that shakes out For charging the Circuit Cube, I need to make a custom USB cable (space … need a flat top USB-B plug). Make a longer video showing how powerful the Circuit Cube stuff really is. It is simply amazing. Video wise, I only have this less than 30 sec clip: First, the 10-cylinder engine fires up, then the train departs, totally loses focus, stops somewhere , V10 stops as well as it needs to kick into reverse (yes, the motor goes into reverse, this is a Steam Punk motor, no gear box here – you can see that by carefully looking at the pistons, they go down and up upon return, not up and down when it started), train reappears, totally out of focus, stops and gains focus, motor shuts down. I suck at taking videos, I know. https://bricksafe.com/files/Toastie/pantasy-steam-punk-railway-/Pantasy Steam Punk Train.mp4 (Updates will go into this thread) All the best, Thorsten
- 15 replies
- circuit cubes
- tenka
(and 3 more)
Tagged with:
Hi all, since it's now published on Brick Model Railroader group, I can finally present also here in EuroBricks my second entry, this time in "MOW vehicle" section: You already know it from the WIP thread - it's a small little patchwork of two Fiat 600T/850T vans and a FIAT 500 499,5cc (21HP) motor. Here's the full story! And here's some bonus content!!! Presentation for Octrainber ends here , but there are some other photos: Transmission is on only one axle, as in the prototype, and it's using (again!!! ) the twisted rubber band transmission. The battery is a 200Mah Li-Po, connected to a small circuit in order to charge-discharge and manage the output to the motor. It can be recharged with an USB Adapter (in this case a serial to USB adapted I had at home). And two videos, showing the rubber band transmission and a small track with the 500 in action! https://www.flickr.com/photos/138174786@N04/51670350725/in/album-72157720126403108/ https://www.flickr.com/photos/138174786@N04/51673059120/in/album-72157720126403108/ I hope you like it! Ciao! Davide P.S. for reference! For more information, please refer to this site (it can be translated) https://scalaenne.wordpress.com/2017/07/29/draisina-fiat/ and to this video, showing a restoration of the Fiat 500 Draisina - which inspired the Giovanni and Giorgio story (Italian only, sorry, maybe it can work with subtitles) https://www.youtube.com/watch?v=X7vwRs0Akkk&t=211s
- 26 replies
- mow
- maintenance of way
(and 10 more)
Tagged with:
