Showing results for tags 'attack helicopter'.
This model was the result of a choice I had to make. I could either come up with an entry for the Eurobricks small car contest, or I could enter the TLCB Lockdown Competition. I really didn't feel inspired to make a small car, so I went with making a C model. I chose 42098, largely because of the fact that it was the only set I hadn't started to mix into my large collection. Initially, I was going to build some kind of wheeled vehicle, but then I hit a real builder's block. At that point, I was looking at the small wheel arches, and thought that it looked kind of like the bottom parts of an attack helicopter cockpit. After I realized that, I made the cockpit section, and got going from there. This helicopter is ultimately a nonesuch, and combines design elements from a number of real and fictional helicopters, including the Hellhound helicopter from Patlabor 2, and a design I found on Deviantart called the Fujin, which was designed by MeganeRid, The rotors spin, obviously, but they also have collective pitch control, which was very hard to implement given the parts available in the set. 42098 includes a shockingly small selection of gears and other technical bits, so I had to get very creative. The rotors are at their lowest position in this picture. The collective does not use a turntable, but instead uses a brick built solution that hearkens back to the very first Technic helicopter, set 852. The actual control for this function is a lever with a red bushing, on the right of the photo. This is the blades at maximum pitch, which better shows the collar that is used to simulate a swash plate. The second most major function is the complex landing gear. A 12z gear at the end of both wings controls this function, which uses worm gears to prevent the gear from collapsing. The first pic shows the gear retracted for flight, the second and third show the gear down for landing. The last set of functions relate to the gun pod, mounted under the fuselage. The pod can be traversed 90 degrees to either side, and will clear the landing gear towers. This is controlled by a 12z gear located behind the air intakes. The gun will also elevate from horizontal to almost vertical, using a knob on the back of the pod. An underbelly view, showing the gun pod, as well as part of the rotor drivetrain. The rotor is spun by the 2 12z gears on the tail. The gun pod, up close. The rubber connectors on the forward fuselage are actually a travel lock, and can hold the gun in place when not in use. Maximum elevation. Or is this depression? I can't decide how you'd define this. On the tarmac. The landing gear do work, but I also built a stand so that this heli can be posed as if in flight, with the gear retracted. Some up close pictures: This detail is actually important. As most of you have probably noticed, this helicopter has no tail rotor, and is not coaxial, so what gives? My vision is that a real version of this helicopter would use a NOTAR system, which uses a ducted fan to effectively replace a tail rotor. That's what the large vents on the tail are supposed to be for. Now, in terms of scale, this model is quite large. CamelHog the hedgehog and Spam for scale. One last beauty shot: The color scheme may not be very military, but I'd chalk that up to this being an airshow/display team livery. All in all, I am quite happy with this model, it was a real challenge to make in the limits of the parts I had, so much so was actually running out of 3L pins, but it came together nicely, and the color scheme actually worked out a lot better than I expected it to. Now, on to the contest. Stay safe out there, folks. P.S. I'll give a shout out to the first person who is able to guess where the manufacturer's name of this heli came from.
Hi guys! I'm back with another of my moc, this time it's the AH-64E attack helicopter. The AH-64E "Guardian" attack helicopter is the latest version of the AH-64, used by the US Army. This helicopter is fitted with more powerful General Electric T700-GE-701D engines. This gunship comes with new sensors, avionics and has improved night operation capabilities. Furthermore the AH-64E helicopter can control a couple of UAVs. The AH-64E has infra-red suppressing exhaust system and is equipped with chaff and flare dispensers. The AH-64E comes with a 30 mm M230 cannon with 1 200 rounds of ammunition. It has 4 hardpoint on stub wings and can carry various missiles such as Hellfires, Mistrals, Sidewinders and Hydras.
Hi guys! I'm back with a new model, the Leonardo AW249 Attack Helicopter, the future military chopper of the Italian Army, currently being tested. The Leonardo AW249 is a next generation attack helicopter in development for the Italian Army, as replacement for a replacement for the Agusta A129 Mangusta. It is to be larger, more survivable, and have greater autonomy than the Mangusta, incorporating stealth technologies and mission systems to control unmanned aerial vehicles (UAV)s. It has 20 mm chin-mounted cannon, Rafael Advanced Defense Systems Toplite targeting system and Spike missiles and/or Sidewinder missiles and/or Stinger missiles and/or Hydra missiles pods, everything on 6 hardpoints (3 for each wing), powerful jet engines, latest available digital communications and battlefield management systems, electro-optical countermeasures and other self-defence systems, such as the DIRCM (Direct InfraRed Counter Measures) ELT\577 QUIRIS and the ELT\162 radar warning receiver. It can lift a greater payload, has more accurate radar, a larger fuel tank (with the possibility of external fuel tanks on the wings), anti-air/anti-personnel/anti-tank capabilities.
The AH-64E features improved digital connectivity, the JTIDS, more powerful T700-GE-701D engines with upgraded face gear transmission to accommodate more power, capability to control UAVs, full IFR capability, and improved landinggear. New composite rotor blades, which successfully completed testing in 2004, increase cruise speed, climb rate, and payload capacity.
Lego Technic MOC - Attack Helicopter Building Instructions: https://play.google.com/store/apps/details?id=max.moc.technic.instructions.prime Lego Technic MOC - Attack Helicopter Lego Technic MOC - Attack Helicopter
- attack helicopter
- helicopter
(and 3 more)
Tagged with:
