Showing results for tags 'Great Ball Contraption'.
Back in 2013, I built and posted about my first NXT ball machine (you can view the original post at http://www.eurobrick...topic=87788&hl= if you are interested). While that machine worked, I learned a lot while building it, so I wanted to create an entirely new machine that incorporated what I learned. I also wanted to make it bigger. Now, in 2015, I have completed my second NXT ball machine. This one is almost 6 feet tall, and over 7 feet wide. The longest span is over 4 feet. It uses simpler lift mechanisms that are more reliable (though they do still jam occasionally -- I have an idea about how to fix that which I am planning to incorporate if I ever build a third one). This machine is also much less sensitive to how level the surface is that it is sitting on. As a result, this machine is a lot nicer to set up and display at a show. It is also much more open, giving people a better view of the balls as they move through the machine. Here's a YouTube video showing the machine in action: There are two possible paths through the machine. The path splits at the top of the left tower with some balls following the gray track that crosses the width of the machine several times. The other half of the balls follow the silver track that spirals down the left tower. Let me know what you think! Ben
This LEGO ball machine was constructed using 10 motors and thousands of bricks. Its 14 balls move continually through the machine, taking approximately two minutes to complete a lap. Two Mindstorms NXT bricks control the green lift, blue lift and ball counter. A combination of Power Functions and traditional 9V motors drive the remaining lifts. The machine is built entirely from LEGO -- even the balls are LEGO parts. Width: 63.5 inches Depth: 24 inches Height: 30 inches A video showing the machine in action is available on YouTube: Let me know what you think! Ben
- 5 replies
- MindstormsNXT
- Ball Machine
- (and 6 more)
We are here to pump you up. Presenting a simple ball pump GBC module. LEGO GBC Ball Pump Module by dr_spock_888, on Flickr YouTube video: (no music to avoid DRM issues in some regions) Enjoy.
- 2 replies
- GBC
- Great Ball Contraption
(and 1 more)
Tagged with:
