Showing results for tags 'Dawn of Justice'.
Here's a quick mod I came up with. I felt the front end of the Batmobile from 76045 was unfinished, so I rebuilt most of the front section to include wheel covers, spinning turret, and smoother front end.
Hello everyone !!! So after some on and off work designing this thing both IRL & LDD i am very proud and happy to show you my Batmobile as it appears on Batman V Superman. I tried to make this model as accurate as i could and the recent images,game DLC´s & toys helped a lot,not only that but the model is very stable and i know this is a small detail that´s pretty much standard with other Batmobiles but... i managed to make the wheels roll with all the armor on it !!! :D So let´s start with the front,definetly a challenging part to do as at first i had no idea how to pull off the shapes & angles, not only that but belive it or not i had trouble doing the turret Things got difficult on the sides, as the actual car has a lot of angles and shapes that are almost impossible to make a 100 % acurate representation on this scale.... however i think i did a fairly decent job doing those The back was fairly simple to do... it took me a while to find a correct size of tires but once i did everything went smoothly.... BTW Credit to JANGBRICKS for the idea of using that motor piece for the Turbine/engine/exaust pipe... So that´s pretty much it guys i hope you like this build as much as i do and if you do want to build this yourself here´s a link were you can buy the instructions : http://www.ebay.com/itm/-/222084491318? Happy building !! -Prime
