Showing results for tags '6951'.
The Robot Command Center is a controversial Classic Space set and in some senses was a pioneer set. It was the first classic Space set which wasn´t neither a Vehicle, nor a Spaceship and even a proper Base. The design pushed the limits of 1984 Lego pieces and yet the structure was solid. Making aside the fact this set had many cool features, as many 80s space sets, it had some problems. The awkward "feet", the too low grabbing arms, the unreachable boxes, but many CS fans consider its worst flaw the two large canopies on each side of the robot. I´ve seen for years several updated versions of this set as Neo Classic Mocs and either remove the "beaks" or leave them as a mere adorn. In either case the problem wasn’t confronted. Following this logic, the solution would be leaving the canopies, but making them useful. Give them a purpose, to make them more than just a decorative feature. Some examples would be making them tool boxes, containers for equipment like jetpacks or drones, covers for hi tech sensors, an extra pair of arms inside the covers or defensive mechanisms. I focused on the last option and designed modern weapons which fit inside the canopies and leaving intact the rest of the original design as much as possible. Giving the RCC a worthy upgrade for this retro set. Link https://www.facebook.com/astronautagris/posts/508673584111677
- 4 replies
- classic space
- neo classic space
(and 8 more)
Tagged with:
Hi! Take a look on strange space set 6951. I used 14 lights to light up as many bicks as it was possible. I hope you will enjoy it I also published a movie to show you special light effects
