Showing results for tags '45'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 2 results
  1. Hello all fellow train folks, today I have another MOC but it isn't a train, it is a track piece that we haven't been able to get in 10 years. Here it is more info to follow. 1). It has to be the same size as previous tracks. 2). It would need to use minimal parts and be easy to construct. 3). It would need to be as quiet as possible or be as quiet as standard Lego tracks when the train rolls over it. 4). It would have to be stable and would not fall apart in use. I hope you all enjoy my MOC and this track piece. I you feel inclined constructive criticism is always welcome! If you thought It was brilliant you can support it here: https://ideas.lego.com/projects/131973
  2. Hi everybody If been playing around with constructing at 45 degrees in technic and found the following techniques: The first one is using an axle through some connectors thus giving you 45 degrees and of course you can now start mounting or building of the axle: I also played around with the Pythagoras theorem and found the two practical values to use: 5 ( 6L in LEGO the first L is the 0 position ) and 7.071 { 5.sqrt(2) } rounded to 7 ( 8L in LEGO the first L is the 0 position ) 7 ( 8L in LEGO the first L is the 0 position ) and 9.899 { 7.sqrt(2) } rounded to 10 ( 11L in LEGO the first L is the 0 position ) The first Pythagoras pair used is the top left with the 6L black axle and the two no. 4 connectors. Not a fan of this method as it is a bit over sized and if you build the parts rigid into you construction with support from the top and the back of the no. 4 connector it might ever so slightly bend the axle or damage your parts. The second pair method one is the 11L beam again not a fan of this method as it will pull ever so slightly as it is actually a bit under sized. The second pair method two and most favoured by me personal is the one I like most yes there will be a small 0.1mm gap in the gray axle but it is really small. I like this method better because I can brace the no 4 connectors from the back and from the tops. I wanted to share this but also I would like to know if you guys have any other techniques you would like sharing? I would like to keep it stud less if possible. Of course using the new A plate with some technic bricks would also be a possibility: http://alpha.brickli...lor=11#T=C&C=11 Anton Edit 1:Used flickr deaplinks instead of attachments
