Showing results for tags '42094'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 5 results
  1. REVIEW - 42094 - TRACKED LOADER INTRODUCTION Looking at the entire range of 1H 2019 models, this model seems to be the one packing the most functions. Your milage may vary, but yellow "construction-ish" vehicles are always welcome to me. And this one looks particularly unusual and interesting. Let's find out what it is all about. This review might be less detailed than usual, but time was limited. Sorry about that. I do hope you enjoy it anyway! PICTURES Pictures can be clicked to view hi-res versions. More pictures can be found in my Flickr album. DISCLAIMER This set has been provided by the CEE Team of TLG. It's not my goal to promote this set. It's my goal to give you an honest opinion about it. Therefore, the opinion in this review is my own and is in no way linked to TLG. SET INFORMATION Number: 42094 Title: Tracked Loader Theme: Technic Released: 2019 Part Count: 827 Box Weight: 1095 gram Box Dimensions: 38,0 cm x 26,0 cm x 7,0 cm Set Price (RRP): € 59,99 Price per Part: € 0,073 Links: Brickset, Bricklink THE BOX CONTENTS OF THE BOX The box contains: 1x Booklet 1x Sticker sheet 8x Unnumbered bags BOOKLET STICKER SHEET BAGS HIGHLIGHTED PARTS PANELS These panels are new in dark bluish grey. The also appear in the Getaway Truck. 20T DOUBLE BEVEL GEAR WITH CLUTCH This gear first appeared in the Bugatti Chiron and it's good to see it pop-up in another set. Quote from the Chiron review; it's basically the same as the regular 20T bevel gear, but it has a pin hole, instead of axle hole. And it has clutches on both sides. PART LIST The part list for the 827 parts. THE BUILD The chassis already shows some of the functionality in this set. One of the rear axles is connected to the mini linear actuator and the other is connected to the large turntable. The axles are extended to outside the bodywork. You can also see the manually operated winch. The cabin is placed on top of the big turntable and can be rotated 360 degrees. That is one mean looking grabber on the boom. The undercarriage for the treads. You can see two springs, but they are not used as conventional suspension. They are used to put pressure on the sprockets. COMPLETED MODEL After adding the treads and connecting the chassis to the undercarriage, here's the final model. Two logs are included. Brutalis does look brutal. What I like most, is the design of the cabin. And I love that it can rotate freely, without any limits. This picture shows the cabin 180 degrees rotated. At the rear you can see the lever to switch between "Rabbit" and "Turtle" winch modes. Not that there is much difference between the two modes, but I like this added detail. After all, that's what Technic is all about. The bottom view of the undercarriage and chassis. Here you can see the front of the cabin, which looks stunning. As I said before, the vehicle doen't have suspension. It simply looks that way because of the springs. The rear view showing the winch, and the locking mechanism at the bottom right. The winch is operated by the 12T bevel gear on the right. B-MODEL The B-model looks promising. Could have been the main model. SUMMARY This medium sized set perfectly shows what the Technic theme is all about. It combines the looks with a handful of nice features. It does not have interesting new parts, but the features and aesthetics make up for this. This set definitely gets my nod of approval PROS Great aesthetics Rotating cabin via 12T gear (360 degrees) Raising and lowering boom via 12T gear Manually operated grabber Operating the winch via 12T gear Switching between two winch modes CONS Nothing really, maybe lack of actual suspension SCORE How do I rate this set? 8 DESIGN I love the cabin and overall aesthetics. 8 BUILDING EXPERIENCE Enough functions to provide a fun building experience. 8 FEATURES Packs enough features to make it interesting. 7 PLAYABILITY The treads limit playability on smooth surfaces. 7 PARTS Not too many interesting parts. 8 VALUE FOR MONEY Genuine Technic set for a reasonable price 7,7 GENUINE TECHNIC SET FINAL WORDS Thanks you for reading this review. All pictures can be found here.
  2. Functions: - One knob lifts the arm - One knob rotates the cab - One knob controls the winch. There's a switch in the back that controls the speed of the winch. Two stickers on both sides. The sticker in the left is a turtle, while the one in the right is a rabbit. So witty. Blue 20z clutch gear detected in the back wooohoooo. B model: Tracked dumper. This thing is so fxxking cool I'm defintely gonna get two of them. Name: Tracked Loader Set Number: 42094 Number of Pieces: 827 Age: 10+ Start: January 2019 Features a working boom and claw, 2-speed winch, rotatable cab and rugged ground-gripping tracks. Comes with a classic yellow and black color scheme and a sticker sheet for additional detailing Open the cab doors and rotate it through 360 °. Lift and lower the boom and the claw to grab and move the included tree trunk elements. This LEGO Technic set is designed to provide an immersive and rewarding building experience. Discover the building blocks of real-life mechanical machines with realistic LEGO Technic gear mechanisms. 2-in-1 model: rebuilds into a tracked dump truck. Tracked Loader measures over 6 "(17cm) high, 13" (35cm) long and 5 "(15cm) wide. Tracked Dumper measures over 5 "(14cm) high, 9" (25cm) long and 5 "(13cm) wide.
  3. Long time no see! Some of You maybe remember my love for excavators and alternate models - 5 years ago I participated in the TC5 challange for alternate builds with an excavator and thanks to Your support I won the competition. Recently decided to challange myself again with the same task of creating an alternate model of the excavator using a middle sized set. 42094 was a no brainer as the best choice - tracks, turntable, some gears, mini actuator - most of the major components necessary for a successful build. The biggest problem was the lack of the wormgear - it would increase control and strength of the extended arm. Nevertheless, I found a solution, and in the end I'm pleasntly surprised how the MOC turned out. Functions: Working tracks (duhh) no suspension, no boogeys, more stable that way Upper structure rotates, sadly didn't manage to attach a knob, so it's done by grabbing the upper part Working boom similar to my previous build Possible to change the height of the whole boom Bucket and the second section of the arm works together - If You reach further, bucket opens, and vice versa - if the arm is getting closer the bucket closes Arm and boom function is operated by a black knob made from small sprocket pieces, to gain easier access, the rear can be opened. Both of the functions can be switched using a LBG connector that switches the clutch piece. So guys, what do You think? Also, what other alternates You would like to see made from this set? And If You want to get the LDD file than check Rebrickable or link below: MODEL INSTRUCTIONS Cheers!
  4. I'm a LEGO technic lover and so i deciced to start my own speed-build & review videos. Last week, i bought two sets: 42094 Tracked Racer and 42092 Rescue Helicopter. Thank you for watching!
  5. Hi! I'm glad to present my motorized modification of 42094 set. It has six remote controlled functions with two S-bricks. Here is exemplary part list: And here is short review and functions demonstration: Photos in high resolution: https://www.flickr.com/photos/141718063@N06/albums/72157705982003774 Thanks for watching!
