Showing results for tags '42053'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 4 results
  1. I' ve decided to make an alternative model for 42053 Volvo EW 160E set. Finally made a telehandler. Video: Functions: - 4 wheel steering - front outdiggers - pneumatics with manual pump: arm lifting arm extension tilting fork Please watch the video to see this machine in action and for more details. I hope you liked this model.
  2. EDIT: Finished pictures and video: Finished model Finished model Finished model Finished model Finished model Finished model 42053 is very nice set but I cannot justify buying it when I have all the necessary parts in my collection. In the end I tend to be dissapointed by the official sets due to my overexpectations. So I decided to build by own Volvo wheeled excavator. As usually I build in scale to blueprints, this time the setter wasn't wheels as usually, but length of the main cylinders. This is primary to achieve the best movement range of the arm. In the end the wheels 49,5mm fit precisely and the scale is (my usual) 21,5:1. Width is 15 studs like in the set, wheelbase is 15 studs as opposed to 17 studs in set. I want it to have 7 pneumatic features: 1) bucket emptying 2) arm movement 3) + 4) two piece boom 5) cabin lift 6) front blade 7) rear outridges Additional features: 8) front pendular axle, steered by HOG 9) superstructure rotation by knob I started with the arm and 2-piece boom. The bucket is by far the biggest drawback of the build with its poor shape and mounting points. I have considered other buckets (I have all TLG produced) but this is the best out of bad. Maybe I will try to build better one from bricks in the end. Everything in real machine is very thin when translated to my scale so the arm is build from technic bricks, arm is 1 stud wide with some plating on sides for looks. The two section boom was quite a challenge due to width. I started with dual thin cylinders at the base but they struggled to lift the boom when it was in full reach. The whole boom had to fit within 5 studs so the first section is actually 2 studs wide and second section is 3 studs wide. Fortunatelly it is not very visible because it is covered by cylinders. The arm movement range is very similar to real machine, the only angle that is smaller is between booms due to the length of the old pneumatic cylinder. The next step was undercarringe. This was quite difficult as well, mostly rear outridges. The range of movement for small cylinders is very low and it had to fit in very little space. The reach is not perfect but it is acceptable. They are weak as kitten of course, fron blade as well, but I wanted them operated with pneumatics. There is also drawball connector to mount trailer behind the excavator. The front wheels use my usual setup with small hubs for great turning radius and ackerman geometry. The disadvantage in this case is that the wheels are mounted "wrong" way, with the shallow part facing outwards as opposed to rear. I can live with that however, I just cannot build without ackerman anymore. Last thing I have is the cabin. It is also 6 studs wide as in the set and it is quite similar to that one but more detailed. I have added brick build front lights and some greeblings. The roof is supposed to be yellow of course, I don't have the bricks yet. I'm now working on body. WIP - Arm reach WIP Arm folded WIP - Arm reach upper WIP - Arm reach lower WIP - Cabin WIP - Cabin
  3. Here are a few examples of what you can do with the Volvo EW160E (when it's in stores within the next few weeks!) A trailer: Forklift: Broader/Twin Tyres (preferably those from 8235 Front End Loader for example!) Grappling Claw Small Bucket Scoop Anything else you could imagine? Regards, Ryan J Smith.
  4. And much, much more here: Want more? Check my full report with a ton of photos: http://www.eurobricks.com/forum/index.php?showtopic=134111
