Showing results for tags '42048'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 3 results
  1. Hi guys.... Here is my full Rc MOD of the Race Kart in white. 2 L motors for driving Servomotor for steering Rechargeable battery SBrick control Smaller turning radius White painted panels All pictures: http://www.technic-dialog.de/Homepage/index.php?page=24&album=2404 Video:
  2. REVIEW - 42048 - RACE KART INTRODUCTION If you are old, like me, there's a pretty good chance the 854 Go-Kart (or 948 Go-Kart for the US) was the first Technic set in your collection. I remember my dad had to help me building this set. Actually, I think he did most of the building and I watched in awe. If you are a dad and have a son (or daughter) this might very well be the set to introduce your kid to LEGO Technic. Is it interesting for us AFOLs too? Let's find out. 854/948 GO-KART FROM 1978 Here you can see a picture of the kart I am referring to. One of the first LEGO Technic sets, although it wasn't called Technical LEGO back in the days. Wikipedia: The concept was introduced as the Expert Builder series and originally Technical Sets in 1977,[1] and was renamed Technic in 1984.. Note: All images can be clicked for hi-res versions. SET INFORMATION Number: 42048 Title: Race Kart Theme: Technic Released: 2016 Part Count: 345 Box Weight: 558 gr Box Dimensions: 15,4 cm x 13,8 cm x 5,9 cm Set Price (MSRP): € 26,99 Price per Part: € 0,078 Links: Brickset, Bricklink THE BOX The box shows the Race Kart on the starting grid and in the lower right corner you see the piston moving. There's also an arrow near the lever, going two ways, so there's probably a gear box of some sorts. BACKSIDE The backside shows the alternate model and a reference to the digital building instructions apps. The instructions weren't available in the app when I built the model, so I can't tell whether they are any good. They are probably up to par with the other instructions in the app, which are quite good. CONTENT OF THE BOX The box contains: 2 Instruction Booklets (A- and B-model) 1 Sticker Sheet 5 Bags INSTRUCTION BOOKLET A-MODEL The instruction booklet for the main model. INSTRUCTION BOOKLET B-MODEL Noteworthy is the inclusion of an additional booklet for the B-model. This is common in smaller sets, but I didn't expect it in a set this size. STICKER SHEET One look at the sticker sheets and it's obvious where these stickers need to be applied. The small round sticker is for the tank cap. The purple and orange color scheme is clearly present in the sticker sheet as well. BAGS Five bags containing all the parts for the model. No unbagged parts in this set. HIGHLIGHTED PARTS This section describes the new or highlighted parts. YELLOW 5L AXLE The 5L Axle has never been released in yellow. As far as I can tell, this is the only 1H 2016 set with a yellow 5L axle. RED 4L AXLE The Axle 4L in Red hasn't been released since 2005. It has only been released in 4 sets in red, so it's not a very common part. SILVER 3L TECHNIC LIFTARM The 3L Technic Lifarm has only been released in Silver in the 10242 - MINI Cooper. DARK BLUISH GREY 3x11 TECHNIC PANEL PLATE Also unique to this set is the 3x11 Panel Plate in Dark Bluish Grey. 3x13 CURVED PANEL The 3x13 Curved Panel, which was introduced in Bright Green in last year's 24 Hours Race Car, is being used in Purple. WHEELS AND TIRES The model uses 37 x 22 ZR Tires and 30.4mm D. x 20mm Wheels. Both are very common, but I mention them for easy reference. PART LIST The Race Kart consists of 345 parts. Here's the complete part list. THE BUILD The build is pretty straightforward, although the rear side with gearbox can be a bit tricky for the younger builders. The picture below shows the model halfway of the build. You can see the steering mechanism and lever for switching gears. The finished model looks quite good. The purple orange scheme makes the model standout. I like it a lot. Now that TLG introduced Purple panels, I hope that TLG will release more parts in Purple. Purple will also work very well with White. Steering is actually done via the steering wheel, something most car models lack nowadays. Of course the steering is easily accessible which facilitates the steering. The turning radius is quite big, which slightly reduces playability. This is clearly visible in the second video. The rear of the vehicle looks great too. One can criticize that using a big panel lacks ingenuity, but I think the panel is perfect solution. Admittedly, I am a big fan of the 3x13 Curved Panel! Hopefully this panel will be introduced in White in the near future. The next picture shows the chassis of the vehicle. As you can see, the White Driving Ring Connector is used multiple times as a 3L connector, where you normally might use a 180 Degree Axle and Pin Connector Angled #2. This is something you will find in the other new sets as well. To be honest; I can't stop looking at the Kart! I also imagine a Bright Green and White version, using the panel from the 24 Hours Race Car. Actually, I have built the Kart in Bright Green and White. You can see the result and comparison at the end of this review. The front and rear view of the Kart. VIDEO PARTS LEFT FEATURES AND FUNCTIONS This model has the following features: Steering Gearbox STEERING The steering wheel actually steers the Kart, which is a plus. On the other hand, the Kart from 1978 already featured steering like this, so it's not very special. Hand of God (HoG) steering wouldn't make any sense on this model. The Kart does have a pretty big turning radius, which does affect playability. I know the options are limited on a small model, but I would have liked some ingenious way of steering that would result in a smaller turning radius. GEARBOX The Kart has a 2-speed gearbox, and a neutral. The gearbox is operated by the red lever. VIDEO OF FUNCTIONS The video below demonstrates the features of the Kart. B-MODEL Since this set includes instructions for the alternate model, I decided to build it. Apparently this is a Track Car, although that is a broad concept. I can't really tell by the image on the back of the box what kind of Track Car this is supposed to be. There's only one way to find out I still can't pinpoint exactly what kind of Track Car it is, but it is a pretty decent B-model. Unlike the main model, it does have Hand of God steering. And it features an opening bonnet/hood. The steering wheel is for decoration purposes. It doesn't steer the model. For a B-model the design is more than sufficient. The next picture shows the chassis of the car. All things considered, this is a high quality B-model. VIDEO B-MODEL The video below shows a short demonstration of the Track Car. PARTS LEFT This image shows the parts left after building the alternate model. The leftover parts from the A-model are shown on the left. As you can see the B-model uses one red Technic Bush from the extra parts. SUMMARY Besides the rather large turning radius, there are no real downsides to this model. I love the looks and color scheme. It also it contains various unique and rare parts. It even features a working gearbox and working steering wheel. The set comes with printed instructions for the B-model, so it's basically a real 2-in-1 set. For around 25 euros you really can't go wrong with this set. Given the price, this also makes for a perfect gift. A gift for someone else, or gift for yourself?! You decide! I'd say this is definitely a worthy successor of me first Technic set ever!! SCORE How do I grade the good guy in this year's duo. 9 DESIGN Purple and orange work great together in this set. And it does look like a real Kart. 8 BUILDING EXPERIENCE Fun to build. Great introduction to gearboxes and steering. 7 FEATURES Working steering wheel and gear box on a relatively small set. 7 PLAYABILITY Limited turning radius slightly limits playability. 8 PARTS Some new parts and parts in new (rare) colors. 9 VALUE FOR MONEY Totally worth the money. 8,0 THE PERFECT GIFT As a bonus here are some picture of the Kart where the orange and purple color scheme has been changed to bright green and white. Not too bad, not too bad at all. It would probably look even better when the panels at the front could be replaced by bright green as well. My favorite picture of the Green Kart! The green fender works really well. COMPARISON Here you can see a comparison between the Purple/Orange and Green/White kart. I personally like the Purple/Orange better, but it's fun to have options. More image can be found on my Flickr page. Thank you for reading. I hope you enjoyed it.
  3. Hi, I made a C-Model for the 42048 Kart :) It features a Formula 1 with working direction (controlled by HOG) and a fake engine with two gears (which can be switched from the back). The hood can be opened. There are also two exhausts and a position light in the back. It is quite fun to play with and the steering radius is much better than the one of A-model :) Here are a few pictures: The HOG is in place of the steering wheel (small yellow part). Steering mechanism is similar to B-Model, but more flat (it is only 1 stud high). The gear box is taken from A-Model and features the same ratios. The switch is on the back however (could not really put it in the cockpit :p ). Any comment welcome ! Will post instructions on rebrickable as soon as possible.
