Lego-Freak_1996 Posted April 24, 2014 Posted April 24, 2014 (edited) Hello guys I'm a fan of 'The Lego Movie' and there is a gear used which doesn't exist! It's a 56 or 60 Teeth Technic gear which is used for the big back wheel of Wildstyles Supercycle. I bought the product and was very disappointed of the looking of it, so I rebuild the model and now it's a 1:1 copy of the movie version. But still one brick is missing and it's the Technic gear. Can some one help me or give me a tip for it? Please answer me! See you later, Lego Freak Edited April 24, 2014 by Lego-Freak_1996 Quote
technicfan Posted April 24, 2014 Posted April 24, 2014 (edited) The official Lego movie set of the bike (70808) uses a 40 tooth gear: http://brickset.com/...per-Cycle-Chase and on Bricklink looks like the biggest gear you can get is the 40 tooth gear: http://www.bricklink...P&catString=136 You might have to custom make something, hope this helps. Edited April 24, 2014 by technicfan Quote
efferman Posted April 24, 2014 Posted April 24, 2014 your links are private ond not visible for us. have you a picture of the gear do you want? Quote
Lego-Freak_1996 Posted April 24, 2014 Author Posted April 24, 2014 The official Lego movie set of the bike (70808) uses a 40 tooth gear: http://brickset.com/...per-Cycle-Chase and on Bricklink looks like the biggest gear you can get is the 40 tooth gear: http://www.bricklink...P&catString=136 You might have to custom make something, hope this helps. Thank you, I know that the biggest gear is a 40 tooth gear. I called TLG after one week of searching this piece and said the same like you. I'm searching for a costume gear. and hope someone helps me. Quote
efferman Posted April 24, 2014 Posted April 24, 2014 does the big turntable work for you? it has 56 teeth Quote
Lego-Freak_1996 Posted April 24, 2014 Author Posted April 24, 2014 your links are private ond not visible for us. have you a picture of the gear do you want? Hi efferman, I updated the pictures. Hope that help you guys. see you later, Lego Freak does the big turntable work for you? it has 56 teeth Hi again, Sorry but the turnable doesn't fit to the cycle. I already bourght one on bricklink and after bilding it in I realise it doesen't fit. The size is perfect but the bright is too big. :( See you later, Lego Freak Quote
efferman Posted April 24, 2014 Posted April 24, 2014 ok, i will make one. the same holes like on the pictures or make it so simple as possible? Quote
Lego-Freak_1996 Posted April 24, 2014 Author Posted April 24, 2014 ok, i will make one. the same holes like on the pictures or make it so simple as possible? Really? :O Thank you so much!!! :) It would be very cool if it would be the same like the one on the pics and I could fix some other thing on, But it depense on you what is easier for you. Thank you so much. See you later, Lego Freak Quote
jonwil Posted April 24, 2014 Posted April 24, 2014 Would be interesting for someone to go through the LEGO Movie (and video game) and identify all the piece shapes that exist there but do not exist in actual ABS... :) Quote
Lego-Freak_1996 Posted April 24, 2014 Author Posted April 24, 2014 Would be interesting for someone to go through the LEGO Movie (and video game) and identify all the piece shapes that exist there but do not exist in actual ABS... :) Would be interesting for someone to go through the LEGO Movie (and video game) and identify all the piece shapes that exist there but do not exist in actual ABS... :) Yes indeed it is! The reviews of 'The Lego Movie', here in Germany said: "All parts exists in real Lego bricks and every one can rebuild there own favorit scene form the movie!" In my view they lied and TLG said there terrible sorry about that but some models of the movie are too big to make special parts for it! Quote
efferman Posted April 24, 2014 Posted April 24, 2014 here is the 56 tooth gear, but i have to say that the gear on the picture is bigger than 56 tooths, because some holes are not possible on this size Quote
Lego-Freak_1996 Posted April 24, 2014 Author Posted April 24, 2014 here is the 56 tooth gear, but i have to say that the gear on the picture is bigger than 56 tooths, because some holes are not possible on this size Thank you very much :) Quote
Hrafn Posted April 24, 2014 Posted April 24, 2014 I count 30 tread links on the first image posted, which would equate to 60 teeth on the gear. Quote
Lego-Freak_1996 Posted April 24, 2014 Author Posted April 24, 2014 I count 30 tread links on the first image posted, which would equate to 60 teeth on the gear. Hey, yes the original gear got 60 teeth but this is a bit too big! Quote
Jim Posted April 24, 2014 Posted April 24, 2014 Part of the discussion already took place in this topic: http://www.eurobricks.com/forum/index.php?showtopic=92936 Quote
SNIPE Posted April 24, 2014 Posted April 24, 2014 it looks like duplo gears and axles are compatible with lego technic, see here http://www.marshall.edu/lego/lessonplans/houston/legoprojects.html here is the duplo gears Quote
Lego-Freak_1996 Posted April 24, 2014 Author Posted April 24, 2014 it looks like duplo gears and axles are compatible with lego technic, see here http://www.marshall....goprojects.html here is the duplo gears Yes I see. I never new that Duplo gears are compatible with Technic gears. But it looks like the tread links can not be bound arount the gear. The Duplo gears are much brigther than normal Technic gears. Quote
SNIPE Posted April 24, 2014 Posted April 24, 2014 (edited) Maybe it doesn't matter that much if the tread links are meshed with the gear you can use stickers or maybe some grey lego domes on each side of the gear , that should hide the color. Maybe the chain links will fit over something like a gear , maybe the large lego pulley. the ground will drive the chain links anyhow when You move the model. Just try putting links around wheels and pulleys, etc. wheels usually have a groove in the middle which the links wlll sit in. Edited April 24, 2014 by SNIPE Quote
DrJB Posted April 25, 2014 Posted April 25, 2014 Effe, looks very nice. However, how about increasing the usability by adding more 'equally spaced' pin holes around the circumference? The current lego parts assortment can do only 8 (i.e 45 degrees separation). I've struggled several times to have more parts/branches radially, as in a Ferris Wheel. If you can fit something like 16 holes aroud the circumference, this part will have many more uses ... Quote
efferman Posted April 25, 2014 Posted April 25, 2014 i have changed it into 12 holes in the outer circle Quote
DrJB Posted April 25, 2014 Posted April 25, 2014 Nice, thank you. Now, one question: Are the teeth narow enough to be driven by a chain ... ie, same width as the old 8t gear? Quote
efferman Posted April 25, 2014 Posted April 25, 2014 this gear is exactly 3,7mm thick and the original gears which can be driven by a chain are 3,7mm too. at the most holes the gear is 4mm thick and at the center crossaxlehole is 7,8mm thick Quote
