Razgriz94 Posted June 8, 2017 I have a problem with Bluerender. When I try to render a LDD file, the render appears all black. Do you know how to solve this problem? Thanks Share this post Link to post Share on other sites
KamalMYafi Posted June 8, 2017 (edited) Did you put your model above the horizon/building plane? If not, try to fix it using (CTRL+A), then pick the model and then place it again (could be on same place), so it should be above the horizon/building plane. Edited June 8, 2017 by KamalMYafi Share this post Link to post Share on other sites
Tintin1 Posted February 5, 2020 I know well this problem. It’s caused because of your point of view in ldd. In blue render, the light come from top so if you see from bottom to top, you will ave a black screen. You can solve it by seeing from top to bottom. If you are not sure, try the preview button up to « render ». Share this post Link to post Share on other sites
