Kostq Posted February 20, 2025 Posted February 20, 2025 These beams always seem a bit hard to incorporate in my alt-build MOCs due to my lack of ultra-mega-master-engineer-knowledge. and it's cousin/brother I know they are very useful, yet for some reason I can't position them properly to benefit from the angle they have and they are always somewhat sticking out. Do you have any recommendations on how to better utilize them - as in how to make a 90degree connection with them besides using the axle holes on the long side? Or any other useful angle combo that can be structurally sound. https://rebrickable.com/parts/32271/technic-beam-1-x-9-bent-7-3-thick/ https://rebrickable.com/parts/32348/technic-beam-1-x-7-bent-4-4-thick/ Both 42164 and 42197 have those and I struggle with incorporating them in my designs. Quote
Aurorasaurus Posted February 20, 2025 Posted February 20, 2025 31 minutes ago, Kostq said: These beams always seem a bit hard to incorporate in my alt-build MOCs due to my lack of ultra-mega-master-engineer-knowledge. %7BfileStore.core_Attachment%7Dmonthly_2025_02/image.jpeg.8849afedc5d135cbf45175d00dee501a.jpegand it's cousin/brother %7BfileStore.core_Attachment%7Dmonthly_2025_02/image.jpeg.ad73762b63e778a910e306f445b6f0dd.jpeg I know they are very useful, yet for some reason I can't position them properly to benefit from the angle they have and they are always somewhat sticking out. Do you have any recommendations on how to better utilize them - as in how to make a 90degree connection with them besides using the axle holes on the long side? Or any other useful angle combo that can be structurally sound. https://rebrickable.com/parts/32271/technic-beam-1-x-9-bent-7-3-thick/ https://rebrickable.com/parts/32348/technic-beam-1-x-7-bent-4-4-thick/ Both 42164 and 42197 have those and I struggle with incorporating them in my designs. I find them most useful for making fenders! I find "Technic Beam 1 x 9 Bent (6 - 4) Thick" much more useful. Sometimes the 7-3 one is good if you're making an 11 7 9 pythagoras triangle and you want to use that to support the angle, and the other two wouldn't fit for some reason. Quote
gyenesvi Posted February 20, 2025 Posted February 20, 2025 In general they are useful in the same geometries as the 6-4 version (which I agree is more often usable), in cases where they can/need to be extended differently. But yeah, I have seen the 7-3 more often in aesthetic positions than geometrical ones, where some corners needed to be rounded off.. Quote
Stereo Posted February 20, 2025 Posted February 20, 2025 Aside from the 3 mentioned parts, there's a non-obvious piece that uses the same 3-4-5 pythagorean triple: https://rebrickable.com/parts/32333/technic-pin-connector-block-1-x-5-x-3/ The top and angled rows of studs are the same angle as these bent beams. Quote
