Has anyone measured the maximum torque that the various knob and bevel gears can take before they deform/crack?
I managed to find some figures for spur gears that seem to suggest around 5 Ncm per tooth ( https://brickexperimentchannel.wordpress.com/2023/11/15/characteristics-of-lego-parts/ ), but obviously bevels will be less.
If I had a sensible way of testing and calculating this myself I would...is there any simple method that doesn't require a special device that measures torque?
Need this info because I'm trying to put together a drivetrain calculator that tells you if you're going to damage an axle or gear!
Thanks
Edited by AxeSlash
I don't have specific data, but in my experience knob gears perform very poorly under load especially when run for an extended period. The surfaces degrade quickly, increasing the friction, and after a while pieces start chipping off the teeth.
Thanks guys, but what I'm looking for here is numbers that I can crunch in a spreadsheet, not general construction advice.
Or alternatively a simple test method.
