Hello, I have tried to update ldd but have only been able to see the new parts in LDD extended, no color choices
There are a lot of ? marks in brick selection, any suggestions
I am using LDD to teach architecture in my class, any help would be greatly appreciated
Hi,
1. The bricks are only available in LDD Extended.  To be available in ‘normal’ LDD requires more work, starting with knowing which parts are available in which colours.
2. If you have red ? in the palette, then you’re missing files.  Either you didn’t install the custom parts correctly or you used LDD 4.3.12.  LDD 4.3.12 is crap, it comes with an outdated parts library.  Some of the official parts are customized here (more decors, bugs fixes…) and only the modified files are distributed here.  So your LDD may see the parts because of these few files but it’s missing the 3D models for these parts.  Desinstall (and scrub) LDD and install the 4.3.11.  There’s a few posts on the forum with more info.
  • 4 weeks later...
Development Version 20220716
Version 20220716 or GitHub [download files separate] and LXF file with new and updated parts
New parts
585.png   585(0) —— Technic Bush with Lip and Side Grooves [BL: x148]
1126.png   1126 —— Tile, Round 1 x 2 Oval — Decoratable
1566.png   1566 —— Plant Stem / Stalk / Vine with Stud and Bar Attachments
1762.png   1762 —— Slope, Curved 33 2 x 2 Double Inverted
1881.png   1881 —— Arm and Hand Long with Pin - Horizontal Grip
2310.png   2310 —— Slope 45° 2 x 1 Inverted with 2/3 Cutout
3947.png   3947 —— Baseplate, Raised 32 x 32 Crater Plate without Crater Studs [BL: 3947a]
6221.png   6221 —— Technic Hub / Handle 1 x 1
12799.png   12799 —— Pullback Motor 6 x 5 x 3 [BL: 12787*] — multi-colorable
18168.png   18168 —— Minifigure Armor Pauldron Cloth, Tattered — decoratable
18922.png   18922 —— Brick, Modified 8 x 16 x 2/3 with 1 x 4 Indentations and 1 x 4 Plate
24791.png   24791 —— Minifigure, Hair Swept Back with Widow's Peak, Sideburns and Fluffed Bangs
28578.png   28578 —— Wheel Bicycle with Fixed Hard Rubber Tire (1-Piece Wheel) — multi-colorable
33464.png   33464 —— Minifigure, Baby / Toddler Head with Neck — decoratable
35386.png   35386 —— Tile 1 x 2 with Groove [transparent version] — decoratable
35391.png   35391 —— Panel 1 x 2 x 1 with Rounded Corners and 2 Sides [2018-current version] — decoratable
35742.png   35742 —— Minifigure, Hair Combo, Hair with Hat, Swept Sideways with Ponytail — multi-colorable, decoratable
36039.png   36039 —— Minifigure, Headgear Helmet SW Stormtrooper, Raised Forehead Type 2 — decoratable
38597.png   38597 —— Neckwear Cape, Pleated [Traditional Starched Fabric] — decoratable
39523.png   39523 —— Minifigure Neck Collar, Cloth, Fur Effect
40687.png   40687 —— Plate, Modified 2 x 4 with Pins and Thick Reinforced Supports
41202.png   41202 —— Minifigure Armor Shoulder Pads with Cobras Facing Over Shoulders and Stud on Back
43058.png   43058 —— White Wedge, Plate 16 x 16 x 1 with 4 Pins [BL: 42609] — multi-colorable
47976.png   47976 —— Brick, Modified 12 x 12 with 3 Pin Holes on each Side and Peg at each Corner
49242.png   49242 —— Figure Base Mario with 4 Top Studs and LCD Screens for Eyes and Chest — multi-colorable, decoratable (note: since the decoratable surfaces are behind the screen glass, you can only decorate this one through the 2020 New Pre-Colored Parts palette)
49649.png   49649 —— Minifigure, Utensil Shopping Cart Frame
50015.png   50015 —— Tricycle Frame
51149.png   51149 —— Technic Changeover Catch - New Style
53540.png   53540 —— Brick Special 1 x 2 with 2 Pins, Square Pin Holes
54657.png   54657 —— Hinge Plate 1 x 2 Locking with 2 Fingers on End and 7 Teeth without Bottom Groove
54671.png   54671 —— Hinge Brick 1 x 2 Locking with 2 Fingers Vertical End, 7 Teeth
54672.png   54672 —— Hinge Brick 1 x 2 Locking with 2 Fingers Horizontal End, 7 Teeth
58101.png   58101 —— Large Figure Legs, Super Mario Overalls — multi-colorable
60674.png   60674 —— Minifigure, Weapon Club with Spikes - Large
64954.png   64954 —— Vehicle, Trailer Base 6 x 16 x 2 2/3 with 8 Holes
65129.png   65129 —— Container, Box Vidiyo BeatBit — can hold tiles in the slots
65146.png   65146 —— Container, Box Vidiyo Clip
66788.png   66788 —— Arm and Hand Long with Pin - Vertical Grip
67017.png   67017 —— Large Figure Headgear, Super Mario Cap — decoratable
67491.png   67491 —— Technic, Liftarm, Modified Frame Thick 3 x 19 Open Center
67695.png   67695 —— Technic, Axle Connector 2 x 3 with Ball Joint Socket - Closed Sides, Straight Forks with Closed Axle Holes
67696.png   67696 —— Technic, Brick Modified 2 x 2 with Ball Socket and Axle Hole - Straight Forks with Round Ends and Closed Sides
69984.png   69984 —— Technic, Plate Rotor 6 Blade with Clip Ends Connected (Water Wheel) - Solid Studs
70646.png   70646 —— Ladder 16 x 2.5 with Studs
73304.png   73304 —— Power Burst Figure Pedestal 5 x 5 x 2/3
73562.png   73562 —— Bracket 3 x 2 x 1 1/3 with Bottom Stud Holder
73642.png   73642 —— Windscreen 14 x 14 x 4 Curved
73832.png   73832 —— Plate, Round 4 x 8 x 2/3, Raised 2 x 8 and 2 x 2 Cutout
76959.png   76959 —— Slope, Inverted 45 2 x 2 with Hollow Round Bottom Tube
77598.png   77598 —— Vehicle, Base 2 x 2 x 2/3 Wheel Fork with 2 Arms and Pin Holes
78643.png   78643 —— Minifigure Armor Breastplate with Shoulder Pads — decoratable
79194.png   79194 —— Plate, Round 1 x 1 with Bar Handle on Long Stem
79717.png   79717 —— Technic, Shock Absorber 9L — multi-colorable
79757.png   79757 —— Slope, Curved 2 x 2 x 2/3 Double Corner
80015.png   80015 —— Plate, Round Corner 5 x 5 with 4 x 4 Curved Cutout
80177.png   80177 —— Wedge 3 x 2 No Studs Left — decoratable
80178.png   80178 —— Wedge 3 x 2 No Studs Right — decoratable
80222.png   80222 —— Windscreen 6 x 7 x 1 1/3 — decoratable
80271.png   80271 —— Technic, Panel Curved #70 5 x 4 x 3 Tapered Right
80272.png   80272 —— Technic, Panel Curved #71 5 x 4 x 3 Tapered Left
80284.png   80284 —— Technic Panel Car Mudguard Arched 13 x 2 x 5, Arched Top, Pointed Bottom
80285.png   80285 —— Technic Panel 3 x 2 x 5
80324.png   80324 —— Flag 2 x 2 Trapezoid with Flared Edge
80336.png   80336 —— Mini Doll Skirt Long Full Octagonal (Diamond Dress Container Bottom)
80431.png   80431 —— Technic, Brick Modified 1 x 2 x 1 1/3 with Rotation Joint Socket
80519.png   80519 —— Wave Rounded Straight Small with Clip End (Flame)
80542.png   80542 —— Tire 75.1mm D. x 20mm Motorcycle
80545.png   80545 —— Slope 45 2 x 4 x 1 1/3 Double, Tapered
80679.png   80679 —— Squirrel — decoratable
84133.png   84133 —— Spring Prosthetic Left Leg — multi-colorable, decoratable
84772.png   84772 —— Wheel 62.3mm D. x 20.3mm Motorcycle with Molded Outer Rim — multi-colorable
84868.png   84868 —— Bar Holder Double with Stud Holder
85834.png   85834 —— Large Figure Armor, Smooth with 2 x 2 Round Brick Attachment — decoratable
89679.png   89679 —— Technic, Panel Curved 2 x 1 x 1
722102.png   722102 —— Wheel Cover 9 Spoke - for Wheel 72206c01
Original parts — updated parts
Custom parts — updated parts
Original / Custom parts — decorated parts
New colors
New assembly
• 12799 (12799, 9029)
• 43058 (42609, 42865)
• 84133 ({3816}, {3815}, 80690)
• 49242 (58272, 58213)
• 24689 ({88618}, 9570)
• 26608 ({24937}, {3818}, {2531}, {3819}, {3820})
• 26371 ({24937}, {3818}, {3820}, {3819})
• 26393 ({24940}, {24943})
• 26497 ({25315}, {24943})
• 26460 ({25281}, {24943})
• 26541 ({25331}, {24943})
• 26474 ({25336}, {24943})
• 79717 (80021, 80022)
{} = original LDD part
Updated original parts
• Updated collisions: 3003, 3008, 3021, 3031, 3039, 3900, 4477, 6111, 6141, 11212, 11214, 15712, 20952, 28326, 30145, 30565, 30987, 32828, 32952, 33492, 40378, 45677, 54200, 60479, 61800, 64393, 64394, 64680, 64681, 98138
• Added decoration surface: 2654, 11153, 13197, 13198, 15308, 15310, 15864, 16501, 18679, 19114, 20905, 20950, 22385, 23850, 23969, 24937, 24940, 25281, 25315, 25331, 25336, 28081, 30259, 33909, 61068, 61678, 88930, 89974, 93606
• Updated decoration surface: 13194, 16497
• Updated connections: 3900, 25893, 93095
• Updated 3D model: 64390
• Changed category: 24943 [loose parts], 30157 [wheel base]
• Updated outlines: 4162
Updated custom parts
• Updated outlines: 35459, 43045, 43056, 49743, 67446, 77765, 86996
• Updated connections: 24869, 26021, 25059, 25061, 26022, 26560, 34738, 36470, 37352, 49743, 65128, 65138, 65635, 66792, 68325, 68568, 69900, 71708, 73825, 79505, 98107
• Updated collisions: 1023, 1025, 2451, 2641, 2698, 2700, 2703, 2704, 2707, 2708, 2709, 2900, 2908, 2989, 2999, 3651, 4470, 4745, 6272, 6543, 7039, 9237, 18591, 21562, 24300, 24400, 24869, 25061, 26021, 36470, 41894, 41895, 42090, 42545, 42908, 43463, 45800, 45801, 47592, 48291, 49612, 54657, 62233, 65401, 65402, 65418, 65426, 65635, 65783, 65803, 66405, 68325, 68568, 68888, 69636, 71689, 71710, 73111, 74132, 77813, 78443, 79505, 299101, 373415, 949001, 999994
• Added collisions: 25059, 26022, 26560, 34738, 35646, 35654, 49098, 51270, 65633, 65634
• Added decoration surface: 49098
• Updated 3D model: 49098, 49743, 77765
• Updated name: 24866, 36840, 69778, 69779
• Updated category: 51270 [moved to Foodstuff]
• Changed default camera angle: 43743
Other notes:
Other notes:
• Added decoration: 1142, 1147, 1518, 1554, 1810, 13831, 16796, 16930, 17791-17793, 17861-17864, 17978, 18381-18384, 18441-18444, 19201-19205, 19211-19216, 19311-19313, 19645, 19922, 20224, 21191-21195, 21201-21205, 21211-21214, 23295, 23709, 23794, 23915, 24275, 24277, 24330, 24371, 24372, 24379, 24380, 24390, 24391, 24419, 24421, 24435, 24464, 24481, 24483, 24485, 24508, 24522, 24524, 24534, 24544, 24559, 24565, 24567, 24575-24577, 24579, 24580, 24583, 24584, 24589, 24590, 24596, 24610, 24613, 24616, 24619, 24621, 24959, 25185, 25818, 25819, 26001, 26460, 26474, 26497, 26633, 26730, 26893, 29072, 29073, 29078, 29079, 29083, 29089, 29092, 29093, 29199, 29201, 29225, 29409, 30958, 33657, 33764, 33766, 33768, 33770, 33775, 34387, 35555, 37021, 38483, 38597, 39430, 39439, 39746, 42852, 47182, 48631, 48632, 48741, 48742, 49113, 49941, 49942, 50051, 50161, 50162, 52261, 52262, 52271, 52272, 52401, 52402, 52411, 52412, 56841, 56842, 56861-56863, 63816, 64678, 66808, 66902, 67284, 67989, 68420, 68891, 69043, 75168, 77020, 78738, 79532, 85541, 87532, 87744, 87917, 88090-88092, 88094, 88099, 88109, 89360, 90446, 93736, 98480, 98481, 179781, 194851, 197211, 197212, 223861-223897, 244267, 255092, 263108, 263711-263718, 263931-263935, 265411, 265412, 266081, 344535, 375716, 444453, 480414, 480415, 492421, 578501, 632911, 649481, 687801, 687802, 687891, 687931, 687932, 687961, 687962, 788091, 744181, 744182, 763873, 787921-787926, 842110, 842111, 842011-842019, 892001-892004, 904461, 935811, 935812, 992191
• Updated decoration: 16872, 39459
• Updated 2020NewPreColoredParts palette with: 1x 2431 [7690802], 1x 2654 [6153491], 1x 3023 [6376903], 1x 3039 [6309297], 1x 3068 [7690804], 1x 3070 [6346775], 7x 3626 [6280003, 6292188, 6308217, 6308193, 6308206, 6308213, 6347422], 1x 6179 [7690803], 1x 6636 [7690809], 3x 10202 [7531301, 7531303, 7531304], 2x 11153 [6063718, 6387687], 1x 12799 [6143751], 1x 13194 [6032863], 1x 13197 [6032943], 1x 13198 [6033028], 2x 14769 [6237231, 6376730], 3x 15068 [7690805, 7690806, 7690808], 3x 15308 [6388284, 6064465, 6103903], 2x 15310 [6064224, 6235174], 1x 15864 [6055597], 1x 16471 [6078291], 4x 16497 [6100776, 6188946, 6142215, 6290210], 1x 16501 [6258810], 1x 18679 [6102614], 1x 19114 [6101867], 2x 20905 [6126540, 6203239], 20907 [6124040], 2x 20950 [6124603, 6280180], 100x 22385 [6131738, 6131739, 6132187, 6132326, 6132331, 6132391, 6132395, 6132446, 6132447, 6132658, 6132662, 6132736, 6132984, 6133051, 6133058, 6133087, 6133150, 6133154, 6133167, 6133197, 6133242, 6133259, 6133264, 6133304, 6133306, 6133342, 6133403, 6133414, 6133460, 6133481, 6133484, 6133489, 6133533, 6133622, 6133625, 6133638, 6133661, 6133669, 6138107, 6143066, 6143068, 6144629, 6152401, 6171915, 6171918, 6172163, 6178327, 6245494, 6172108, 6172170, 6245481, 6245495, 6172770, 6245483, 6245488, 6173005, 6174118, 6190261, 6190269, 6190274, 6190282, 6195107, 6247143, 6304933, 6335504, 2238501-2238544], 1x 23794 [6124940], 1x 23850 [6136436], 2x 24246 [6376854, 6376855], 1x 24689 [4578112], 8x 26371 [6149538, 6151450, 6151472, 6151476, 6151482, 6151763, 6151777, 6151900], 5x 26393 [6149659, 6151938, 6151392, 6151960, 6151962], 1x 26460 [6150564], 1x 26474 [6151123], 1x 26497 [6151311], 1x 26541 [6151492], 1x 26603 [6393696], 1x 26608 [6151910], 1x 28081 [6151964], 1x 28578 [4622574, 6372618], 1x 29685 [6397658], 14x 30259 [3025901-3025915], 1x 33464 [6381994], 2x 33909 [7690810, 7690811], 1x 35386 [6331042], 1x 35391 [6295461], 1x 35742 [6214981], 1x 36039 [6225256], 1x 38597 [6226351], 1x 41835 [6399031], 1x 42609 [4260900], 2x 49098 [6376856, 6253654], 1x 49242 [6286809], 1x 49656 [6399651], 1x 58101 [6278685], 1x 61068 [4544026], 1x 65633 [6385624], 1x 65834 [6395295], 1x 66855 [6353856], 2x 67017 [6308851, 6331610], 2x 69729 [7531302, 7531305], 10x 73200 [6281923, 6281930, 6292197, 6308145, 6353392, 6289460, 6308196, 9308209, 6347425, 6347420], 10x 76382 [6281921, 6281929, 6289433, 6292211, 6311447, 6311451, 6311099, 6311105, 6353359, 6356347], 2x 79717 [6364922, 6404005], 1x 80177 [6376905], 1x 80178 [6376906], 1x 80222 [6376902], 3x 80679 [6384077, 6384078, 6390506], 1x 84133 [6374213], 1x 84772 [6375447], 1x 85834 [6376668], 1x 87552 [7690807], 2x 88930 [4597575, 6385763], 3x 89974 [6234575, 6234736, 4583725], 1x 90498 [7531306], 1x 93549 [6390368], 1x 93606 [7690801], 1x 98138 [6284072]
• Updated MaterialSelector.xml with: 370 [Medium Brown], 371 [Warm Tan]
• Updated CurrentMaterials.xml with: 370 [Medium Brown], 371 [Warm Tan]
• Updated Materials.xml with: 354 [High Tr. Diff. White], 370 [Medium Brown], 371 [Warm Tan]
• Updated MaterialsNames with: 354 [High Tr. Diff. White], 370 [Medium Brown], 371 [Warm Tan]
• Updated Complete Color chart - 2022 with: 354 [High Tr. Diff. White], 370 [Medium Brown], 371 [Warm Tan]
Edited by Stephan
  • 5 months later...
Development Version 20221229
Version 20221229 or GitHub [download files separate] and LXF file with new and updated parts
New parts
1411.png   1411 —— Corn Cob with Husk [BL: 1411*]
1745.png   1745 —— Plate, Round 1 x 2 Half with 1 Stud (Jumper)
1746.png   1746 —— Tower Roof 4 x 8 x 6 Half Cone Shaped with Roof Tiles
1747.png   1747 —— Plant Stem / Stalk with 2 Leaves and Bar Attachments
1748.png   1748 —— Tile, Round 1 x 2 Half — decoratable
1749.png   1749 —— Support 2 x 4 x 13 Semicircle with 5 Pin Holes
1750.png   1750 —— Slope, Curved 2 x 2 x 1 Inverted with 2 Recessed Studs
1751.png   1751 —— Tile 4 x 4 — decoratable
1871.png   1871 —— Slope, Curved 1 x 1 x 1 1/3 Corner [BL: bb1284*] — decoratable
1874.png   1874 —— Windscreen 6 x 9 x 1 2/3 — decoratable
1936.png   1936 —— Technic Turntable / Swashplate 5 x 5 Top with 5 Pin Holes
1937.png   1937 —— Technic Turntable / Swashplate 5 x 5 Base with 4 Pin Holes
1938.png   1938 —— Technic Ball Joint Swashplate with 4 Grooves and Square Hole
2008.png   2008 —— Hair Mid-Length Swept Back with Ruffled Back
2010.png   2010 —— Minifig Headwear Hat Brimmed
2012.png   2012 —— Minifig Neckwear Breathing Apparatus (Cad Bane)
2016.png   2016 —— Minifig Neckwear Armor Shoulder Pads Rounded with Neck Protection and Clip on Back [Plain]
2387.png   2387 —— Technic Panel Fairing #7 3L Very Small Smooth, Side A — decoratable
2389.png   2389 —— Technic Panel Fairing #8 3L Very Small Smooth, Side B — decoratable
2391.png   2391 —— Technic Beam 1 x 7 Thick with Alternating Holes
2393.png   2393 —— Technic Pin Connector Hub Perpendicular 3L with 2 Pins
2395.png   2395 —— Technic Panel Fairing #9 Medium Triangle Smooth — decoratable
2403.png   2403 —— Technic Panel Fairing #10 Medium Triangle Smooth — decoratable
2457.png   2457 —— Technic Panel Fairing 2 x 3 x 1 #3 Angled — decoratable
2459.png   2459 —— Technic Panel Car Mudguard Arched 9 x 2 x 3, Arched Top #42 — decoratable
3704.png   3704 —— Technic, Axle 2L
4350.png   4350 —— Electric 4.5V 3 C-Cell Battery Box without Switch 4 x 22 — multi-colorable
5840.png   5840 —— Technic Bush with Lip [BL: x1299]
18821.png   18821 —— Minifigure, Head, Modified Manta with Air Tank — multi-colorable, decoratable
22168.png   22168 —— Electric, Light Unit Powered Up Attachment — multi-colorable
24219.png   24219 —— Minifigure, Head, Modified SW Ugnaught — decoratable
25508.png   25508 —— Minifigure Skirt Cloth 3 Truncated Points Partial Wrap
26990.png   26990 —— Minifigure, Head, Modified with Flaming Hair — multi-colorable, decoratable
28657.png   28657 —— Minifigure, Utensil Goblet [transparent]
30101.png   30101 —— Door, Frame 2 x 8 x 6 Swivel with Bottom Notches
30102.png   30102 —— Door 2 x 5 x 5 Swivel, Flat Base — decoratable
35157.png   35157 —— Glass for Train Door with Lip on All Sides
35635.png   35635 —— Minifigure Armor with 2 Flaps over Shoulders
35701.png   35701 —— Minifigure, Hair Short, Parted with Two Pigtails, Hole for Pin on Top
36060.png   36060 —— Minifigure, Hair Coiled and Short
36481.png   36481 —— Technic, Gear 24 Tooth with 3 Axle Holes [BL: x187]
36756.png   36756 —— Rat / Mouse — decoratable
37614.png   37614 —— Minifigure Armor Shoulder Pads Ridged
37619.png   37619 —— Minifigure, Headgear Helmet SW Range Trooper — decoratable
37631.png   37631 —— Minifigure, Headgear Helmet SW Enfys Nest — multi-colorable, decoratable
38547.png   38547 —— Dragon Wing 8 1/4 x 5 — multi-colorable
42819.png   42819 —— Door 1 x 4 x 5 Train Right, Thick Support at Bottom
43967.png   43967 —— Door 1 x 4 x 5 Train Left, Thick Support at Bottom
44511.png   44511 —— Tower Roof 8 x 12 x 10 Onion Dome
48267.png   48267 —— Technic Tooth 1 x 3 with Axle Hole [Hollow Underside]
50335.png   50335 —— Vehicle, Digger Bucket 7 Teeth 3 x 6, Rise Inside with Locking 2 Finger Hinge
54662.png   54662 —— Hinge Cylinder 1 x 3 Locking with 1 Finger and 2 Fingers on Ends, 7 Teeth, with Hole
61520.png   61520 —— Windscreen 6 x 4 x 1 1/3 without Bottom Tabs and with Solid Studs [BL: 6152b]
64872.png   64872 —— Technic, Steering Arm 5.5 x 2 with Towball Socket Rounded, Chamfered [Reinforced]
67737.png   67737 —— Propeller 4 Blade 5 Diameter with Rounded Ends and Closed Hub
67929.png   67929 —— Plate, Modified 8 x 8 with Cut Corners, Raised Sides and 4 Feet
68327.png   68327 —— Wheel 41mm D. x 15mm Technic
68547.png   68547 —— Wave Rounded Straight Swirls with Bar End (Cloud / Wind Gusts)
69754.png   69754 —— Projectile Launcher, 1 x 2 Mini Blaster / Tile Shooter
69755.png   69755 —— Projectile Launcher Part, Trigger for Bazooka, Mini Blaster / Shooter
69761.png   69761 —— Technic, Gear 22 Tooth Bevel
69762.png   69762 —— Technic, Gear 14 Tooth Bevel Thick
69767.png   69767 —— Minifigure, Weapon Bazooka, Mini Blaster / Shooter
71603.png   71603 —— Electric, Light & Sound 4 x 20 x 5 Insectoid Stinger [BL: x239] — decoratable
72514.png   72514 —— Belville, Clothes Crown Mini [BL: x250] — multi-colorable
73389.png   73389 —— Wheel 75mm D. x 41mm Technic Racing Large #1 Model Left Side (Spokes Slanted Left)
73398.png   73398 —— Wheel 75mm D. x 41mm Technic Racing Large #2 Model Right Side (Spokes Slanted Right)
77107.png   77107 —— Support 11 x 11 Girder, Round
77127.png   77127 —— Figure Base Luigi with 4 Top Studs and LCD Screens for Eyes and Chest — multi-colorable, decoratable (note: since the decoratable surfaces are behind the screen glass, you can only decorate this one through the 2020 New Pre-Colored Parts palette)
77834.png   77834 —— Brick, Modified 2 x 2 x 5 with 2 x 4 Plate Base, Spring Unit, and 2 Technic Holes [BL: 80432c01] — multi-colorable
78645.png   78645 —— Minifigure, Headgear Helmet with Horns, SW Mandalorian — multi-colorable, decoratable
80273.png   80273 —— Technic, Liftarm, Modified Rotor 5 Blade with Square Hole
80274.png   80274 —— Technic, Panel Curved #62 5 x 4 Tapered Right
80278.png   80278 —— Technic, Panel Curved #63 5 x 4 Tapered Left
80279.png   80279 —— Tire 87.9 x 44
80319.png   80319 —— Plate, Modified 8 x 8 with Double-Sided Adhesive Tape on Back [BL: 79759c01] — multi-colorable, decoratable
80326.png   80326 —— Flag 2 x 2 Square with Flared Edge — decoratable
80477.png   80477 —— Technic, Pin with Bar and Tow Ball, 3L
80543.png   80543 —— Arch 1 x 4 x 3
80563.png   80563 —— Technic Rotation Joint Disk with Pin Hole and 2 Pins
80677.png   80677 —— Tile, Round 2 x 2 Splat with Side Extensions — decoratable
81346.png   81346 —— Technic, Gear 20 Tooth with Clutch on Both Sides
81911.png   81911 —— Windscreen 2 x 4 x 1 Curved
84867.png   84867 —— Legs with Plate Round 2 x 2 and Axle Hole - 4 Feet
86368.png   86368 —— Minifigure, Hair Female Long Tousled with Center Part
88105.png   88105 —— Minifigure, Head, Modified SW Ree-Yees — multi-colorable, decoratable
90826.png   90826 —— Minifigure, Utensil Broom Bristles with Stud Holder
98878.png   98878 —— Windscreen 10 x 4 x 2 with Bar Handle
100560.png   100560 —— Neckwear Cape, Pauldron, Tattered
100646.png   100646 —— Minifig Neckwear Armor Shoulder Pads with Clip on Back — decoratable
107700.png   107700 —— BBB Train Wheel XXL Flanged Driver 43.2 mm
360831.png   360831 —— Minifigure, Weapon Web Effect, Long and Narrow, Bars at Both Ends [BL: 36083a]
360832.png   360832 —— Minifigure, Weapon Web Effect, Handcuffs [BL: 36083b]
360833.png   360833 —— Minifigure, Weapon Web Effect, Medium, Bar on Back [BL: 36083c]
360834.png   360834 —— Minifigure, Weapon Web Effect, Small, Short Bar on Front and Back [BL: 36083d]
360835.png   360835 —— Minifigure, Weapon Web Effect, Large, Bar on Back, Bar Handles on Sides [BL: 36083e]
360836.png   360836 —— Minifigure, Weapon Web Effect, Two Branches, Bars on Each End [BL: 36083f]
New colors
New assembly
• 77127 (9324, 58213)
• 22168 (25452, 25450, 62498, {23816})
• 77834 (80432, 80433)
• Updated connections: 4035, 32828
• Updated collision data: 3029, 3034, 3068, 3623, 3666, 4282, 15395, 15461, 26047, 32828, 48989, 54200, 60477, 87580, 99781
• Added decoration surface: 4515, 24119, 27925, 28946, 28948, 28949, 32316, 60581, 64799
• Updated decoration surface: 2723
• Updated 3D model: 6152, 24119, 30410
• Updated connections: 2711, 2719, 4261, 4262, 4263, 4442, 26559, 32828, 49309, 67440, 69066, 86876
• Added decoration surface: 35700, 49311, 71682, 89679
• Added collisions: 25195, 26559, 35464, 49309
• Updated collisions: 37352, 69958
• Updated 3D model: 4263, 25195, 80222
• Updated name: 26559, 35464, 49309, 67440, 69066, 79393
• Changed default camera angle: 71682
Other notes:
Other notes:
• Added decoration: 1557, 10217, 10243, 10571, 10572, 10792, 11121, 11479, 13231, 13639, 13673, 13674, 13688, 14152, 15117, 15622, 16986, 17324, 18354, 18356, 18794, 18958, 19686, 19688, 19745, 20123, 20894, 23088, 23884, 24829, 24865, 24905, 24961, 25395, 26220, 26223, 26247, 28946, 28948, 28949, 29584, 29586, 29591, 31913, 32642, 33601, 33859, 33878, 34053, 35147, 36942, 37065, 37284-37286, 37387, 37737, 37797, 38184, 38198, 38683, 38635, 39413, 39512, 39592, 39616, 39672, 39850, 39851, 39879, 43377, 44096, 44108, 52998, 53000, 56295, 62591, 62592, 62621, 62622, 62751, 62752, 62531, 62532, 65952, 65957, 67878, 68209, 68244, 68398, 68418, 68584, 68695, 68795, 69534, 69606, 69870, 70140, 70145, 72198, 72295, 73211, 73791, 73809, 73880, 73883, 74446, 75839, 77388, 78238, 78691-78697, 78699, 78700, 78704, 78808, 78891, 79515, 79516, 80319, 81283, 82462, 92191, 93273, 94031, 97709, 98314, 100526, 100529, 100915-100919, 100665, 100666, 100669, 100674, 100646, 100675, 102317-102319, 102321, 102322, 102324, 105091-105098, 306802, 306818, 306819, 393561-393579, 416201-416205, 451505, 472611, 799941, 932401, 980201
• Updated decoration: 68411, 78280, 87917, 773980
• Updated 2020NewPreColoredParts palette with: 1x 1126 [6408440], 1x 1411 [6387149], 1x 1874 [6408444], 4x 2723 [6191951, 6306819, 6370494, 8454001], 2x 3009 [6323429, 6408450], 1x 3024 [6408441], 1x 3068 [3068002, 6123040, 6125777, 6192746, 6236629, 6238262, 6238268, 6326920, 6360862, 6428480-6428482, 6428484, 6428485, 6428487], 4x 3069 [6304928, 6346646, 6139435, 6329597], 1x 3070 [641414], 1x 3623 [6414137], 70x 4162 [89843, 2110001, 4162001-4162005, 4613282, 4638309, 4642923, 4653629, 4653640, 6001727, 6005372, 6005373, 6011634, 6015808, 6024587, 6030988, 6031423, 6031424, 6031551, 6036556, 6045721, 6052208, 6064767, 6070233, 6082179, 6082195, 6089148, 6101015, 6101020, 6103359, 6109669, 6135202, 6135307, 6135412, 6146710, 6146728, 6174611, 6174624, 6174627, 6181555, 6182355, 6191892, 6201676, 6214597, 6215388, 6217985, 6221587, 6223269, 6223318, 6253221, 6253232, 6265011, 6265021, 6285745, 6299932, 6302574, 6226753, 6267596, 6285764, 6304835, 6338083, 6366690], 1x 4350 [4350000], 1x 4515 [6371343], 1x 4740 [6414133], 8x 10509 [6022359, 6022370, 6036454, 6037638, 6038711, 6284169, 6343565, 6370297], 4x 11217 [6308091, 6308216, 6347421, 6388287], 1x 16497 [6405202], 2x 18821 [6118824, 6236918], 1x 19478 [6383181], 1x 22168 [6145779], 1x 24119 [6346658], 2x 24219 [6136460, 6238339], 5x 26990 [6217403, 6217404, 6217410, 6247869, 6329731], 1x 27925 [6410654], 1x 28946 [6195733], 1x 28948 [6195725], 1x 28949 [6195709], 1x 30311 [6188675], 1x 30680 [3068003, 3068004], 1x 32316 [6346649], 1x 35386 [6414139], 1x 35700 [6318313], 2x 36756 [6226594, 6234453], 1x 37619 [6236146], 1x 37631 [6236528], 3x 38547 [6236256, 6387613, 6395816], 1x 49311 [6349122], 1x 54200 [6343004], 1x 60581 [1026115], 1x 64799 [6408449], 1x 67931 [6404645], 1x 71603 [7160300], 2x 71682 [6346648, 6346647], 4x 72514 [7251400-7251403], 4x 76382 [6410516, 6410899, 6411665, 6410153], 1x 77127 [6351935], 2x 78645 [6353637, 6353638], 1x 80267 [6346654], 1x 80268 [6346653], 6x 80319 [6370224, 6395750, 6396070, 6396071, 6396074, 6396076], 1x 80326 [6317066], 1x 85984 [6101924], 7x 87079 [6147001, 6302718, 6316467, 6323891, 6329428, 6329431, 6221185], 1x 87610 [6405205], 1x 88105 [6038729], 1x 88930 [6414135], 1x 89679 [6346651], 1x 93273 [6346645], 3x 98138 [6287874, 6329607, 6346650], 1x 99013 [6387405], 1x 100646 [6407913]
• Created 'UV maps' folder in 'Decorations' folder.
• Added UV map: 1751, 1748, 1871, 1874, 2387, 2389, 2395, 2403, 2457, 2459, 2654, 2723, 3024, 3068, 4162, 4515, 4740, 9324, 9441, 10350, 13744, 18821, 24119, 27925, 29238, 29241, 29243, 30102, 35700, 36756, 37530, 60581, 64799, 71682, 78891, 80267, 80268, 80319, 80326, 80677, 87566, 87567, 89679
• Updated MaterialSelector.xml with: 376 [Transparent Yellow Opal]
• Updated Materials.xml with: 376 [Transparent Yellow Opal]
• Updated CurrentMaterials.xml with: 376 [Transparent Yellow Opal]
• Updated MaterialsNames with: 376 [Transparent Yellow Opal]
• Updated Complete Color chart - 2022 with: 376 [Transparent Yellow Opal]
Edited by Stephan
  • 5 months later...
  • 3 months later...
Any ETA on the next pack update? Or a link where I could download the individual components? Thanks and keep up the good job, Stephan!
Edited by Zerobricks
Yes, I am second that: it would be good to have pack with JUST THE NEW ADDITIONS, not everything together, so the pack would be much smaller in size and yet we could exactly know what is new in a specific release without going thru this post all the time just to check what is new...just saying + good job, of course!
Edited by macouso
Development Version 20231023
Version 20231023, or GitHub [download files separate], or Only the files from this update (you need the previous updates for this) and LXF file with new and updated parts
New parts
1413.png   1413 —— Chicken, Wide Base — multi-colorable, decoratable
1686.png   1686 —— Large Figure Armor, Round, Smooth with Bar Handle - Free Ends
 1744.png  1744 —— Cone 3 x 3 x 3 (Elliptic Paraboloid)
1846.png   1846 —— Vehicle, Mudguard 4 x 3 x 1 2/3 with Arch Round, Wide Cylinder
1872.png   1872 —— Wheel Cover Thin Spoke and Spinner - for Wheel 18976
1939.png   1939 —— Tile, Round Corner 4 x 4 Macaroni Widet — decoratable
1942.png   1942 —— Electric, Light Slope Curved 4 x 2 x 2/3 Double with Fresnel Lens
2142.png   2142 —— Dragon Tail / Horn Section Stepped
2405.png   2405 —— Technic, Steering CV Joint Axle 5L
2438.png   2438 —— Technic, Panel Curved 5 x 3 x 2 Corner Quarter Ellipse, Left — decoratable
2442.png   2442 —— Technic, Panel Curved 5 x 3 x 2 Corner Quarter Ellipse, Right — decoratable
2471.png   2471 —— Technic, Gear 24 Tooth with Clutch on Both Sides
2473.png   2473 —— Technic Driving Ring 2L with 8 Teeth
2474.png   2474 —— Technic, Gear Ratchet 8 Tooth
2477.png   2477 —— Technic, Liftarm, Modified Perpendicular Holes Bent Thick L-Shape 3 x 5
2502.png   2502 —— Technic Skidder Arm Claw with 4L Liftarm and 2 Axle Holes
2509.png   2509 —— Technic, Panel Car Mudguard Arched #32 11 x 2 x 5 Straight Top
2628.png   2628 —— Brick, Modified 8 x 8 x 2/3 with 1 x 4 Indentations
2629.png   2629 —— Brick, Modified 8 x 16 x 2/3 with 1 x 4 Indentations
2656.png   2656 —— Container, Cupboard / Refrigerator 2 x 3 x 5
2657.png   2657 —— Door 1 x 3 x 5 with Stud Handle
2676.png   2676 —— Minifigure Beard, Full with Braided Moustache Ends and Braid in Back
2682.png   2682 —— Plant Plate, Round 1 x 1 with Curved, Upright Leaf
2937.png   2937 —— Slope 55 6 x 1 x 5 with Bottom Stud Holders  — decoratable
3130.png   3130 —— Container, Box 2 x 2 x 1 Half with 4 Side Supports
3131.png   3131 —— Container, Box 2 x 2 x 1 Half with Stud and 4 Corner Supports
3160.png   3160 —— Brick, Modified 6 x 6 x 2/3 No Studs with Ice Crystal Surface Profile
3161.png   3161 —— Rock Panel 2 x 4 x 4
3172.png   3172 —— Plate, Modified 1 x 2 with Pin Hole on End
3224.png   3224 —— Fence 1 x 2 x 1 2/3 with Diagonal Bar
3250.png   3250 —— Support 15 x 15 Girder, Round
3251.png   3251 —— Technic, Panel Curved 8 x 8 x 2
3263.png   3263 —— Plate, Round 3 x 4 x 2/3, Raised 1 x 4
3384.png   3384 —— Windscreen 6 x 4 x 1 1/3 Canopy Sloped Sides — decoratable
3385.png   3385 —— Vehicle Base 6 x 12 x 1 with 5 x 6 Recessed Center, 12 Holes and 1 x 2 Cutouts on Ends
3386.png   3386 —— Brick, Round 1 x 1 x 2/3 Half Circle Extended with Side Stud
3387.png   3387 —— Vehicle, Mudguard 4 x 2 1/2 x 2 with Arch Round
3388.png   3388 —— Wedge 5 x 1 x 1 1/3 with 4 x 1 Base Left
3389.png   3389 —— Wedge 5 x 1 x 1 1/3 with 4 x 1 Base Right
3395.png   3395 —— Tile, Modified 2 x 4 Inverted — decoratable
3396.png   3396 —— Tile, Modified 2 x 2 with 2 1 x 1 Curved Cutouts (Double Arrow) — decoratable
3477.png   3477 —— Tile, Round Corner 4 x 4 Macaroni Wide — decoratable
3486.png   3486 —— Wheel Hard Plastic, Treaded 36mm D. with 4 Studs
3504.png   3504 —— Wedge 5 x 2 Left
3505.png   3505 —— Wedge 5 x 2 Right
3535.png   3535 —— Panel 3 x 3 x 2 Corner Convex — decoratable
3538.png   3538 —— Technic, Panel Car Mudguard Arched #43 11 x 2 x 5 Rounded Top
3544.png   3544 —— Wedge, Plate 8 x 3 Left
3545.png   3545 —— Wedge, Plate 8 x 3 Right
3556.png   3556 —— Brick 2 x 4 [transparent]
3569.png   3569 —— Cone 4 x 4 x 3 with Axle Hole
3572.png   3572 —— Arch 1 x 5 x 2 Raised
3661.png   3661 —— Plate, Round 1 x 1 Open Stud with Bar Arm Down
3668.png   3668 —— Technic, Brick 2 x 6 x 1 1/3 with Axle Holes and Bottom Stud Holders
3885.png   3885 —— Minifigure, Weapon Sword Blade with Bar (SW Darksaber)
4158.png   4158 —— Technic Changeover Cylinder
4159.png   4159 —— Technic Changeover Catch Double (Fork)
4190.png   4190 —— Slope, Curved 2 x 2 Concave Corner with Recessed Stud
4192.png   4192 —— Technic, Steering CV Joint Wide with 2L Axle
4569.png   4569 —— Slope 10 6 x 1 — decoratable
22566.png   22566 —— Minifigure, Weapon Gun, Portal Gun [BL: bb0674*] — multi-colorable
23323.png   23323 —— Electric Bionicle Motor Remote Control Receiver Unit (Manas) — multi-colorable
26741.png   26741 —— Minifigure, Weapon Sword, Small with Detailed Hilt (Sting) [4674a]
 26742.png  26742 —— Minifigure, Weapon Sword, Greatsword with Broken Blade (Narsil) [4674b]
26743.png   26743 —— Minifigure, Weapon Sword, Greatsword Pointed with Upturned Crossguard and Capped Pommel [4674c]
26744.png   26744 —— Minifigure, Weapon Sword, Greatsword with Detailed Hilt and Capped Pommel [4674d]
26745.png   26745 —— Minifigure, Weapon Sword, Elven Warrior Blade with Short Hilt [4674e]
26746.png   26746 —— Minifigure, Weapon Axe, Dwarven [4674f]
28621.png   28621 —— Minifigure, Head (Plain) - Vented Stud — decoratable
32305.png   32305 —— Technic, Pin Connector Block 7 x 3
32533.png   32533 —— Bionicle Kanoka Disk — decoratable
35315.png   35315 —— Glass for Window 1 x 2 x 2 Flat Front — decoratable
35341.png   35341 —— Tile, Modified 2 x 3 Pentagonal — decoratable
35530.png   35530 —— Minifigure, Head, Modified Small Cube, Plain
37276.png   35750 —— Creature Head Pixelated Chicken Head [BL: bb0816*] — multi-colorable, decoratable
35762.png   35762 —— Minifigure, Headgear Head Cover, Costume Flower — multi-colorable
37822.png   37822 —— Minifigure Baby Carrier
 38301.png  38301 —— Minifigure Cape Cloth, Scalloped - Traditional Starched Fabric — multi-colorable
38458.png   38458 —— Minifigure, Head, Modified Mojo Jojo — multi-colorable, decoratable
39016.png   39016 —— Minifigure, Hair Combo, Hat with Hair, Batman Cowl — multi-colorable
39370.png   39370 —— Technic, Steering Ball Joint Large Receptacle with H-Shape Perpendicular Thick Liftarm
40145.png   40145 —— Plate, Round 2 x 2 Thin with Rotation Stem
45779.png   45779 —— Minifigure, Headgear Helmet Mask, Hole on Top [BL: bb0889*]
45991.png   45991 —— Tap 1 x 1 without Hole in Nozzle End [BL: 4599b]
49736.png   49736 —— Cylinder Tube, Straight
49737.png   49737 —— Cylinder Tube, Curved 45 degrees
51066.png   51066 —— Leg Mechanical, Droid with Technic Pin - Short with Squared Pin Hole
 57881.png  57881 —— Minifigure, Headgear Hat, Fisherman Rain
60189.png   60189 —— Brick, Braille 2 x 4 with 1 Stud (dots-1 ⠁) — decoratable
60190.png   60190 —— Brick, Braille 2 x 4 with 2 Studs (dots-12 ⠃) — decoratable
60191.png   60191 —— Brick, Braille 2 x 4 with 2 Studs (dots-14 ⠉) — decoratable
60192.png   60192 —— Brick, Braille 2 x 4 with 3 Studs (dots-145 ⠙) — decoratable
60207.png   60207 —— Brick, Braille 2 x 4 with 2 Studs (dots-15 ⠑) — decoratable
60220.png   60220 —— Brick, Braille 2 x 4 with 3 Studs (dots-124 ⠋) — decoratable
60221.png   60221 —— Brick, Braille 2 x 4 with 4 Studs (dots-1245 ⠛) — decoratable
60222.png   60222 —— Brick, Braille 2 x 4 with 3 Studs (dots-125 ⠓) — decoratable
60223.png   60223 —— Brick, Braille 2 x 4 with 2 Studs (dots-24 ⠊) — decoratable
60224.png   60224 —— Brick, Braille 2 x 4 with 3 Studs (dots-245 ⠚) — decoratable
60225.png   60225 —— Brick, Braille 2 x 4 with 2 Studs (dots-13 ⠅) — decoratable
60226.png   60226 —— Brick, Braille 2 x 4 with 3 Studs (dots-123 ⠇) — decoratable
60227.png   60227 —— Brick, Braille 2 x 4 with 3 Studs (dots-134 ⠍) — decoratable
60228.png   60228 —— Brick, Braille 2 x 4 with 4 Studs (dots-1345 ⠝) — decoratable
60229.png   60229 —— Brick, Braille 2 x 4 with 3 Studs (dots-135 ⠕) — decoratable
60230.png   60230 —— Brick, Braille 2 x 4 with 4 Studs (dots-1234 ⠏) — decoratable
60231.png   60231 —— Brick, Braille 2 x 4 with 5 Studs (dots-12345 ⠟) — decoratable
60232.png   60232 —— Brick, Braille 2 x 4 with 4 Studs (dots-1235 ⠗) — decoratable
60233.png   60233 —— Brick, Braille 2 x 4 with 3 Studs (dots-234 ⠎) — decoratable
60234.png   60234 —— Brick, Braille 2 x 4 with 4 Studs (dots-2345 ⠞) — decoratable
60235.png   60235 —— Brick, Braille 2 x 4 with 3 Studs (dots-235 ⠖) — decoratable
60237.png   60237 —— Brick, Braille 2 x 4 with 2 Studs (dots-34 ⠌) — decoratable
60238.png   60238 —— Brick, Braille 2 x 4 with 3 Studs (dots-136 ⠥) — decoratable
60239.png   60239 —— Brick, Braille 2 x 4 with 4 Studs (dots-1236 ⠧) — decoratable
60240.png   60240 —— Brick, Braille 2 x 4 with 4 Studs (dots-1346 ⠭) — decoratable
60243.png   60243 —— Brick, Braille 2 x 4 with 5 Studs (dots-13456 ⠽) — decoratable
60244.png   60244 —— Brick, Braille 2 x 4 with 4 Studs (dots-1356 ⠵) — decoratable
60289.png   60289 —— Brick, Braille 2 x 4 with 5 Studs (dots-12346 ⠯) — decoratable
60290.png   60290 —— Brick, Braille 2 x 4 with 6 Studs (dots-123456 ⠿) — decoratable
60291.png   60291 —— Brick, Braille 2 x 4 with 5 Studs (dots-12356 ⠷) — decoratable
60292.png   60292 —— Brick, Braille 2 x 4 with 4 Studs (dots-2346 ⠮) — decoratable
60293.png   60293 —— Brick, Braille 2 x 4 with 5 Studs (dots-23456 ⠾) — decoratable
60294.png   60294 —— Brick, Braille 2 x 4 with 4 Studs (dots-2356 ⠶) — decoratable
60295.png   60295 —— Brick, Braille 2 x 4 with 4 Studs (dots-3456 ⠼) — decoratable
60297.png   60297 —— Brick, Braille 2 x 4 with 2 Studs (dots-36 ⠤) — decoratable
60305.png   60305 —— Brick, Braille 2 x 4 with 2 Studs (dots-16 ⠡) — decoratable
60311.png   60311 —— Brick, Braille 2 x 4 with 3 Studs (dots-126 ⠣) — decoratable
60312.png   60312 —— Brick, Braille 2 x 4 with 3 Studs (dots-146 ⠩) — decoratable
60329.png   60329 —— Brick, Braille 2 x 4 with 4 Studs (dots-1456 ⠹) — decoratable
60330.png   60330 —— Brick, Braille 2 x 4 with 3 Studs (dots-156 ⠱) — decoratable
60331.png   60331 —— Brick, Braille 2 x 4 with 4 Studs (dots-1246 ⠫) — decoratable
60332.png   60332 —— Brick, Braille 2 x 4 with 5 Studs (dots-12456 ⠻) — decoratable
65066.png   65066 —— Glass for Door Frame 1 x 6 x 7 Arched with Notches and Rounded Pillars — decoratable
65547.png   65547 —— Brick, Braille 2 x 4 with 4 Studs (dots-1256 ⠳) — decoratable
65548.png   65548 —— Brick, Braille 2 x 4 with 3 Studs (dots-246 ⠪) — decoratable
65549.png   65549 —— Brick, Braille 2 x 4 with 4 Studs (dots-2456 ⠺) — decoratable
65550.png   65550 —— Brick, Braille 2 x 4 with 3 Studs (dots-256 ⠲) — decoratable
65551.png   65551 —— Brick, Braille 2 x 4 with 1 Stud (dots-3 ⠄) — decoratable
65552.png   65552 —— Brick, Braille 2 x 4 with 1 Stud (dots-2 ⠂) — decoratable
65555.png   65555 —— Brick, Braille 2 x 4 with 3 Studs (dots-236 ⠦) — decoratable
65556.png   65556 —— Brick, Braille 2 x 4 with 1 Stud (dots-46 ⠨) — decoratable
65557.png   65557 —— Brick, Braille 2 x 4 with 1 Stud (dots-6 ⠠) — decoratable
65558.png   65558 —— Brick, Braille 2 x 4 with 2 Studs (dots-25 ⠒) — decoratable
65559.png   65559 —— Brick, Braille 2 x 4 with 1 Stud (dots-5 ⠐) — decoratable
65563.png   65563 —— Brick, Braille 2 x 4 with 2 Studs (dots-35 ⠔) — decoratable
66964.png   66964 —— Minifigure, Weapon Sword, Greatsword Pointed with Upturned Crossguard
67631.png   67631 —— Otter — decoratable
68577.png   68577 —— Wheel 62.3mm D. x 42mm Technic Racing Large with 10 'Y' Spokes
68614.png   68614 —— Minifigure, Headgear Helmet SW Raised Visor, Antennas, and Ear Covers — multi-colorable, decoratable
69912.png   69912 —— Tire 81 x 35 Tractor
69945.png   69945 —— Hermit Crab, Bar on Back — decoratable
70495.png   70495 —— Windscreen 3 x 14 x 4
70880.png   70880 —— Wave Rounded 1 x 4 with 2 Studs on Ends (Flame, Rock)
73261.png   73261 —— Electric 4.5V 3 C-Cell Battery Box Polarity Switch 2 x 4 — multi-colorable, switch moves
73763.png   73763 —— Technic, Gear Worm Screw 6L
77123.png   77123 —— Minifigure, Head, Modified Mouse with Fire Helmet — multi-colorable, decoratable
77822.png   77822 —— Sports Stuntz Loop Ramp Base
77823.png   77823 —— Sports Stuntz Loop Ramp Section
77844.png   77844 —— Plate 3 x 3 Corner
77845.png   77845 —— Plate, Round 1 x 4 with 2 Open Studs
77850.png   77850 —— Plate, Round 1 x 3 with Open Studs
78124.png   78124 —— Container, Cupboard 2 x 3 Drawer [reinforced version]
78168.png   78168 —— Plate, Modified 2 x 6 with Coupling, Female
79768.png   79768 —— Technic, Liftarm, Modified Girder Triangular Thick 7 x 16
79996.png   79996 —— Bag Tag with 3 x 8 Studs
80031.png   80031 —— Plate, Round 10 x 10 Rounded End
80390.png   80390 —— Bag Tag with 3 x 6 Studs
80394.png   80394 —— Cockpit 6 x 4 x 4 2/3
80428.png   80428 —— Technic Weight 7 x 11 x 2 Solid
80497.png   80497 —— Elephant Tail / Trunk with Bar End - Long Straight Tip
80513.png   80513 —— Bird, Toucan with Molded Beak — multi-colorable, decoratable
80562.png   80562 —— Train, Track Roller Coaster Straight 4L
80567.png   80567 —— Vehicle, Mudguard 10 x 4 x 2/3 with Horizontal Arch Curved
80577.png   80577 —— Mini Doll, Hair Combo, Hair with Hat, Long Wavy with Molded Beanie — multi-colorable
80683.png   80683 —— Door 1 x 3 x 6 with Stud Handle
80834.png   80834 —— Minifigure, Hair Combo, Hat with Hair with Nursing / Nurse Cap — multi-colorable
83496.png   83496 —— Tile, Modified 4 x 8 Inverted with Studs on Edges — decoratable
84205.png   84205 —— Vehicle, Caravan Roof 6 x 6 x 5 Half with 4 Studs on Top and 2 Studs and Window on Both Sides
85824.png   85824 —— Electric Battery Box Powered Up Bluetooth Hub with Bottom - Screw Opening — multi-colorable
90840.png   90840 —— Train Wheel RC, Spoked with Technic Axle Hole and Counterweight, 50 mm D. (Flanged Driver)
98370.png   98370 —— Minifigure, Weapon Sword, Greatsword Pointed with Thin Crossguard
100662.png   100662 —— Minifigure, Head, Modified Baby / Toddler with Molded Space Helmet and Air Tanks — multi-colorable, decoratable
101658.png   101658 —— Minifigure Cape Cloth, Stepped Shoulders with Single Top Hole - Spongy Stretchable Fabric — multi-colorable
101777.png   101777 —— Minifigure, Headgear Hat, Top Hat Large — multi-colorable, decoratable
102498.png   102498 —— Minifigure, Utensil Wand — multi-colorable
350321.png   350321 —— Power Burst, Blaster with Bar Handle [BL: 35032a]
350322.png   350322 —— Power Burst, Bolt Large with Bar Ends [BL: 35032b]
350324.png   350324 —— Power Burst, Bolt Spiral with Bar Ends [BL: 35032d]
350325.png   350325 —— Power Burst, Shield Large with Bar End [BL: 35032e]
350326.png   350326 —— Power Burst, Shield Small with Bar Ends [BL: 35032f]
New colors
New assembly
• Updated 3D model: 3001, 32019, 63037
• Updated connections: 2443, 23816, 24375, 42409, 57585, 59443
• Updated collisions: 2465, 3743, 3821, 3822, 6112, 6231, 15038, 15462, 15470, 15573, 23816, 26601, 57585
• Added decoration surface: 3005, 3710, 6178, 11439, 13744, 18675, 21599, 24629, 24946, 25126, 29238, 29241, 29243, 30668, 37530, 43723, 92950
• Updated decoration surface: 32474, 59349
• Updated name: 27507
• Added collisions: 30034, 32298, 35459, 36840, 71708
• Updated collisions: 28738, 37195, 71708, 80286, 89679
• Updated connection data: 28738, 28974, 37195, 49283 [attached to wire now], 55889, 69761, 71720, 80015
• Added decoration surface: 9363, 9367, 42531, 71771
• Updated UV mapping: 3814
• Updated 3D model: 3384, 23945, 28802, 65092, 65509, 71711, 71720, 73230, 76776
• Updated name: 2387, 2389, 2393, 2395, 2403, 2459, 65092, 65509, 65633
• Renamed: 2682 to 268200
• Updated assembly: 268400
• Updated category: 66789, 66790, 66792, 68869, 79387
• Corrected position relative to connections: 52629
Other notes:
Added decoration: 1911, 15926, 21637, 23035, 26823, 26864, 27347, 27985, 29101, 29102, 34448, 37276, 37615, 38458, 39707, 42229, 42315, 45779, 47937, 48883, 59938, 60189-60192, 60207, 60220-60235, 60237-60240, 60243, 60244, 60289-60295, 60297, 60311, 60312, 60329-60332, 65547-65549, 65550-65552, 65555, 65557, 65559, 67201, 67206, 67786, 68804, 68956, 68976, 69192, 69361, 69457, 69459, 69461, 69463, 69603, 69945, 70686, 72187, 72188, 72258, 73794, 74642, 76935, 76936, 78214, 78217, 78218, 78221, 78324, 78503, 79546-79548, 79701, 79872, 80513, 80814-80820, 80915, 94664, 94866, 100555, 100662, 100891, 101321-101323, 101647, 101769-101771, 101776, 101868, 101871, 102030, 102055, 102240, 102257, 102258, 102261-102263, 102465-102467, 102469, 102470, 102490, 102576, 102577, 102702, 102763, 102764, 102976, 103032, 103276-103278, 103625-103630, 103632-103644, 103714, 103718, 103739, 103789, 103806, 103807, 103813, 103814, 104134, 104204-104210, 104367, 104423, 104631, 104741-104744, 104992, 105172, 105186, 105187, 251261, 307001, 325301-325351, 474401-474403, 601891, 601901, 601911, 601921, 602071, 602201, 602211, 602221, 602232, 602241, 602951, 603051, 730021-730023, 981381, 990891, 990892
• Updated 2020NewPreColoredParts palette with: 1x 1413 [6319680], 5x 2431 [6237026, 6315054, 6417656, 6443113, 6445159], 1x 2438 [6426365], 1x 2442 [6426366], 1x 3004 [6360242], 1x 3005 [6437893], 1x 3010 [6430740], 9x 3068 [6122977, 6312724, 6366172, 6413111, 6421844, 6421849, 6422385, 6436476, 6443116], 3x 3069 [6299715, 6405973, 6436474], 9x 3070 [6308528, 6315641, 6315648, 6320139, 6326107, 6326107, 6326107, 6421365, 6444525], 1x 3245 [6431022], 1x 3460 [6438731], 2x 3622 [6443114, 6443119], 1x 3710 [6438730], 4x 4744 [4744001-4744004], 1x 6178 [6434916], 1x 6179 [6366170], 2x 6636 [6436395, 6459442], 1x 10202 [6434914], 8x 11439 [6020758, 6022109, 6022638, 6022644, 6116913, 6139219, 6160277, 6160280], 1x 14719 [6436477], 8x 14769 [6157942, 6313877, 6353870, 6353871, 6366174, 6422398, 6430739, 6436479], 1x 15535 [6436393], 7x 21599 [6117526, 6230174, 6230175, 6271865, 6309185, 6316957, 6421338], 1x 22566 [6122397], 1x 23323 [2332300], 3x 23945 [6133831, 6353089, 6440804], 3x 24246 [6315639, 6437897, 6437918], 8x 24629 [6172316, 6172318, 6245354, 6245442, 6342620, 6342623, 6342624, 6355646], 2x 24946 [6343846, 6449708], 8x 25126 [2512601, 6154171, 6160305, 6217068, 6222798, 6227117, 6232083, 6330212], 3x 26603 [6366169, 6436478, 6443118], 1x 27925 [6449710], 4x 28621 [6422584, 6434208, 6441199, 6455328], 2x 30668 [6197159, 6251995], 5x 32474 [6259640, 6261631, 6438706, 6449711, 6458485], 51x 32533 [3253301-3253351], 5x 34140 [6193877, 6193904, 6193919, 6215575, 6225509, 6287660], 1x 35315 [6366171], 2x 35341 [6421843, 6430719], 1x 35380 [6447377], 1x 35398 [6308522], 3x 35762 [3576200, 3576201, 6223572], 1x 37276 [6217227], 1x 37779 [6453338], 1x 37783 [6453339], 1x 38301 [6226394], 1x 38458 [6226689], 1x 38502 [6225509], 1x 39016 [6242834], 4x 42531 [6335197, 6335198, 6426360, 6426361], 1x 43722 [6438738], 1x 43723 [6438737], 1x 43898 [6397503], 2x 45779 [6315642, 6350366], 10x 60189 [6018900, 6018901], 10x 60190 [6019000, 6019001], 10x 60191 [6019100, 6019101], 5x 60192 [6019200], 10x 60207 [6020700, 6020701], 5x 60220 [6022000], 5x 60221 [6022100], 5x 60222 [6022200], 10x 60223 [6022300, 6022301], 5x 60224 [6022400], 5x 60225 [6022500], 5x 60226 [6022600], 5x 60227 [6022700], 5x 60228 [6022800], 5x 60229 [6022900], 5x 60230 [6023000], 5x 60231 [6023100], 5x 60232 [6023200], 5x 60233 [6023300], 5x 60234 [6023400], 1x 60235 [6023500], 1x 60237 [6023700], 5x 60238 [6023800], 5x 60239 [6023900], 5x 60240 [6024000], 5x 60243 [6024300], 5x 60244 [6024400], 5x 60289 [6028900], 5x 60290 [6029000], 5x 60291 [6029100], 5x 60292 [6029200], 5x 60293 [6029300], 1x 60294 [6029400], 2x 60295 [6029500, 6029501], 1x 60297 [6029700], 5x 60305 [6030500], 5x 60311 [6031100], 5x 60312 [6031200], 5x 60329 [6032900], 5x 60330 [6033000], 5x 60331 [6033100], 5x 60332 [6033200], 3x 63864 [6436475, 6443115, 6443117], 1x 65151 [6410048], 5x 65547 [6554700], 5x 65548 [6554800], 5x 65549 [6554900], 1x 65550 [6555000], 1x 65551 [6555100], 1x 65552 [6555200], 1x 65555 [6555500], 1x 65556 [6555600], 1x 65557 [6555700], 1x 65558 [6555800], 1x 65563 [6556300], 3x 66855 [6353872, 6382151, 6407496],  1x 67498 [6416662], 1x 67631 [6425514], 1x 68614 [6308228], 2x 69729 [6436397, 6417654], 1x 69945 [6326897], 1x 71771 [6436392], 1x 72046 [6429735], 1x 73261 [7326100], 3x 75902 [6258475, 6366557, 6421842], 2x 77123 [6342627, 6342621], 1x 79717 [6433367], 1x 80513 [8051300], 3x 80577 [6365950, 6382877, 8057700], 1x 80834 [6382549], 1x 85824 [6375901], 2x 85984 [6323420, 6323421], 8x 87079 [6345178, 6366173, 6366175, 6434915, 6430718, 6430720, 6436396, 6459441], 1x 92950 [6436394], 15x 98138 [6315333, 6322964, 6322971, 6323635, 6329604, 6417658, 6426364, 6430992, 6431715, 6431716, 6432105, 64334345, 6433501, 6433502, 6449709], 1x 100662 [6415219], 2x 101777 [6422609, 6438374], 2x 102498 [6431185, 6448068]
• Added UV map: 2x4 Braille*, 1939, 3001, 3384, 3395, 3396, 3460, 3477, 3535, 3710, 2937, 4569, 6178, 9367, 9442, 10124, 10128, 10154, 10202, 10304, 10305, 11217, 11219, 11331, 11538, 13195-13197, 14397, 14719, 15307, 15308, 15310, 15311, 16471, 16497, 16501, 17012, 17774, 18675, 18679, 18807, 19017, 19114, 20904, 20905, 20907, 20950, 20952-20954, 21417, 21557, 21566, 21599, 21810, 22385, 23850, 23969, 24067, 24076, 24219, 24246, 24772, 24937, 24940, 24946, 25113, 25114, 25126, 25266, 25269, 25281, 25315, 25331, 25336, 25741, 25743, 26078, 26081, 26793, 26990, 27090, 27133, 27135, 27136, 27142, 27956, 28230, 28232, 28240, 28412, 28414, 28451, 28631, 28710, 28716, 28782, 28792, 28948, 29602, 29685, 30370, 30375, 30378, 30380, 30408, 30489, 32474, 32611, 32835, 33492, 35037, 35341, 37313, 38458, 43722, 43723, 46203, 46534, 47545, 48288, 48494, 50950, 50995, 53075, 57900, 58101, 59349, 61189,61195, 62576, 63864, 64225, 64803, 64806, 65066, 66955, 67017, 67644, 67908, 67950, 68881, 68986, 69061, 69101, 69729, 69945, 70495, 71771, 73210, 76328, 76776, 76796, 77237, 78522, 78989, 79001, 80177, 80178, 80222, 80513, 80679, 80683, 83496, 85834, 85984, 87556, 87557, 87561, 87566, 87567, 87568, 87610, 88105, 88616, 88618, 89973, 89974, 92474, 92742, 92744, 92745, 92755, 92950, 93057, 93060, 93066, 93273, 93604, 93696, 98099, 98101, 98103, 98117, 89118, 89120, 101777, 981011
• Updated in 2020NewPreColoredParts: 54675 [6317490/6384835], 66855 [6353856]
• Updated MaterialSelector.xml with: 375 [Transparent Black]
• Updated Materials.xml with: 375 [Transparent Black]
• Updated CurrentMaterials.xml with: 375 [Transparent Black]
• Updated MaterialsNames with: 375 [Transparent Black]
• Updated Complete Color chart - Current with: 375 [Transparent Black]
• Updated decorations: 19745, 30011, 30013, 30014, 30016, 30017, 73784, 79241, 80808, 99187, 300111, 300119, 300123, 611013, 616009
• Changed decoration name: 602201 --> 602200, 602221 --> 222401, 602222 --> 222402
• Added image '401' to
• Added 401 to MainGroups.xml
* Can be used for: 60189-60192, 60207, 60220-60235, 60237-60240, 60243, 60244, 60289-60295, 60297, 60305, 60311, 60312, 60329-60332, 65547-65552, 65555-65559, 65563
Edited by Stephan
@Stephan
I somehow do not fully understand this line of yours here:
I That is: what for there are ONLY THE FILES FROM THIS UPDATE when you immediately say that we need also previous update for that? I am trying to get the meaning here: I would thought that ONLY THE FILES... would be a pack of just the newly added bricks, right? But then the appendix to that is really messy for me cos it looks that it is of no use as I also need some other previous update? Could you, please, explain this a bit more?
3 minutes ago, macouso said:
@Stephan
Yes, of course. But sometimes collision data is updated, and then I do not include the g files. So this update only works if you have previous updates installed. Just like any other programm. If you want to select your own files, you can download them individually or combined through Github.
And like it was written in the 1st post, please refrain from asking questions in this topic to keep this topic clean and only as an informational topic about new updates.
Edited by Stephan
Thank you for this massive update, Stephan!
Unfortunately it seems, some files are missing, I'm getting an error 17 pieces could not be loaded including 3538, 3885, 68577, and searching for those ID shows up no .xml or.g files.
Can you send me a screenshot of the new parts overview? Then I can quickly pinpoint the missing parts and update the update files today.
Ehm, is it somehow all of a sudden OK now asking questions here when others were told not doing so??? Where is any sort of consistency in approach???
Edited by macouso
FIX Development Version 20231026
Version 20231026, or GitHub [download files separate], or Complete parts pack and LXF file with new and updated parts
• Updated connections: 4036
• Updated 3D model: 80577
• Updated collisions: 2142, 3250, 3251, 6170, 57881, 68614, 80577, 90840
• Updated connections: 2656, 3161, 3263, 3388, 3544, 3545, 77850
Edited by Stephan
Thanks much for the updated parts. Lego LDD now has greater capabilities. I dreaded moving to Studio. I'm having a problem with brick 36840. I can build with it, generate building steps, and save. The problem is when I open the project I receive this message: “brick could not be loaded and has been removed from the model.” I'm using the latest xml file (2022-12-30). Any suggestions?
Thanks much,
Jeff
Development Version 20231029
Version 20231029, or GitHub [download files separate], or Complete Update and LXF file with new and updated parts
New parts
2491.png   2491 —— Tire 81.5 x 29
2612.png   2612 —— Brick, Modified Corner 16 x 16 x 2/3 with 7 x 7 Inside Corner and 1 x 4 Side Indentations
 3166.png  3166 —— Wedge 10 x 4 x 2/3 Cutout (Mudguard)
3221.png   3221 —— Minifigure, Headgear Helmet, Pot / Pan with Stud on Side
65514.png   65514 —— Brick, Modified 2 x 2 with Pins and Axle Hole [dual-molded]
65886.png   65886 —— Tile, Modified 2 x 3 with 2 Open O Clips [2020-current] — decoratable
86879.png   86879 —— Axolotl Body Pixelated
103918.png   103918 —— Windscreen 4 x 4 x 2 with Molded Glass
• Corrected decoration surface: 14719
Other notes:
• Added decoration: 80815, 104631
• Updated 2020NewPreColoredParts palette with: 1x 35380 [6447377], 1x 103918 [6440190]
Edited by Stephan
  • 2 months later...
Development Version 20240120
Version 20240120, or GitHub [download files separate], or Complete Update and LXF file with new and updated parts
!!!IMPORTANT!!!
!!!Part 69073 has been renumbered to 67649!!!
!This means that you have to replace this part in your build with the new numbered part!
New parts:
• 1994, 1995, 3167, 3171, 3233, 3484, 3563, 3565, 3567, 3573, 3627, 3766, 3917, 3968, 4041, 4042, 4585, 4586, 5065, 5152, 5405, 21788, 35809, 37784, 42876, 65203, 65700, 65766, 67037, 67144, 67361, 67697, 68212, 69857, 72132, 73764, 78333, 79735, 79766, 79767, 79808, 80295, 80835, 100942
New assembly:
• 100943 [3468, {9476}, 3465]
• 18386 [{3815}, {3816}, {3817}, 15447]
Updated original parts:
• Updated UV map: 6636
• Added decoration surface: 6143, 24782, 75904
• Updated name: 64276
• Updated collision data: 52107
Updated custom parts:
• Updated connection data: 3396, 6025, 65886, 66857, 80015
• Updated 3D data: 2821, 26073, 65886
• Updated collision data: 37195, 66857
• Added outlines: 26073
• Added collision data: 2682, 3396, 26073, 79756, 79768
• Updated PartID: 69073 → 67649
• Updated name: 67649
Other notes:
• Added decoration: 16859, 24861, 26441, 28444, 29882, 38273, 44286, 51018, 66923, 66927, 67065, 67835, 68025, 69090, 69091, 69885, 69915-69919, 69922, 69923, 69925-69928, 69930-69932, 70945, 73559, 73739, 73786, 78182, 78183, 79534, 80306, 84438, 87672, 87673, 96404, 96406, 98461, 99946, 100436, 103348, 103543, 104067, 104511-104513, 104738, 104740, 104789, 105956, 105957, 106211, 405951-405953, 663601
• Updated 2020NewPreColoredParts palette with: 1x 1751 [4059501], 4x 1995 [6430885, 6435597, 6435598, 6447085], 3x 2431 [6319298, 6319338, 6446940], 1x 2821 [6436048], 3x 3068 [4059502, 6163476, 6310510], 1x 3069 [6299836], 2x 3070 [6255958, 6310509], 1x 3622 [6064027], 2x 4162 [6319299, 6319300], 1x 4710 [6319322], 1x 6143 [6404665], 20x 6636 [4059500, 4561429-4561431, 4625456, 4625459, 4653275, 4654480, 6176227, 6135286, 6223853, 6294195, 6292560, 6319296, 6319324, 6328062, 6342705, 6342711, 6636000, 6636001], 5x 14769 [6318694, 6353858, 6362613, 6451322, 6467694], 1x 18386 [6083001], 6x 24782 [6143292, 6150254, 6157689, 6258319, 6273702, 6466206], 5x 26073 [2607300, 6159684, 6196694, 6275293, 6442128], 1x 35341 [6449634], 1x 35380 [6384069], 3x 35809 [6213681, 6223175, 6446980], 3x 63864 [6319301, 6319325, 6319326], 1x 67037 [6307850], 1x 67144 [6294650], 1x 68495 [6454153], 3x 75902 [6301437, 6446939, 6449632], 1x 75904 [6446943], 3x 87079 [6319327, 6319334, 6319335], 1x 88930 [6319304], 3x 98138 [6329593, 6375358, 6435099], 1x 100942 [6414501], 1x 100943 [6459445]
• Added UV map: 2821, 3567, 4041, 5065, 6143, 6636, 24782, 65203
• Updated decoration: 69092, 103628, 105187, 842019
• Updated MaterialSelector.xml with: 314 [Iron Red], 402 [Reddish Orange], 422 [Sienna Brown], 423 [Umber Brown]
• Updated Materials.xml with: 314 [Iron Red], 402 [Reddish Orange], 422 [Sienna Brown], 423 [Umber Brown]
• Updated CurrentMaterials.xml with: 402 [Reddish Orange], 422 [Sienna Brown], 423 [Umber Brown]
• Updated MaterialsNames with: 314 [Iron Red], 402 [Reddish Orange], 422 [Sienna Brown], 423 [Umber Brown]
• Updated Complete Color chart - Current with: 314 [Iron Red], 402 [Reddish Orange], 422 [Sienna Brown], 423 [Umber Brown]
For a complete list, including images, please see CustomLDDUpdates.com.
I found this forum, and topic about a year ago and I really appreciate the added LDD parts, Stephan! However, I found when assembling the new 76282 "Rocket & Baby Groot", when adding part 5066 in step 44 of the instructions, it cannot be placed on top of any parts. Parts can be attached to the top of it, but not the underside! I believe the inside dimensions of part 5066 are off, could that be fixed please?
Edited by make
My man, this isn't the place for that, go there:
Sorry about that, I'll stick to the correct thread in the future!
  • 2 months later...
Development Version 20240504
Version 20240504, or Complete Update and LXF file with new and updated parts
New parts:
• 1997, 2229, 2514, 3417, 3571, 3628, 3863, 4367-4369, 4410, 4412, 4413, 4472, 4500, 4527, 4920, 4973, 4974, 5032, 5090-5092, 5151, 5175, 5240, 5258-5260, 5294, 5401, 5404, 5426, 5466, 5520, 18034, 49699, 54568, 59276, 65579, 65673, 75674, 77263, 80910, 105162, 105645, 106700
New assembly:
• 61929 [62473, 62875, 62469, {58124}]
• 619291 [62473, 624691, {58124}]
• Updated name: 15210, 30258
• Updated decoration surface: 3023, 24299, 24307, 41751, 45677
• Added decoration surface: 3666, 3961, 4742, 29119, 29120, 30602
• Updated assemblies: 99499 [{10095}, {10089}, {58124}], 99498 [{10152}, {10130}, {58124}]
• Updated name: 38320
• Updated connection data: 2656, 35189, 38320, 73763, 73764, 80567
• Updated 3D model: 4304, 35189
• Updated collision data: 35189, 65416
Other notes:
• Added decoration: 26819, 69173, 76979, 77126, 77573, 77609, 79422, 79423, 83519, 101027, 102256, 104593, 105164, 105275, 105276, 105363, 105364, 105889, 105890, 106248-106250, 106700, 106718, 106719, 106723-106731, 106733, 106736, 106739, 106744, 106772-106776, 107053, 107054, 107108, 107109, 107172, 107307, 107311, 107315, 107322-107324, 107326-107328, 107330-107334, 107485, 107486, 107524, 107728, 107907, 108120, 108330, 108331, 108568, 108569, 109141, 432491-432498, 753761-753766
• Updated decoration: 88094
• Updated 2020NewPreColoredParts palette with: 1x 2431 [6465833], 1x 2683 [6472238], 3x 3023 [6311491, 6472243, 6472260], 2x 3024 [6472242, 6477795], 5x 3068 [6467910, 6467911, 6476629, 6479551, 6479552], 4x 3069 [6477802-6477805], 2x 3070 [6482755, 6489744], 2x 3666 [6472244, 6472245], 1x 3846 [6477785], 1x 3863 [6447176], 1x 3961 [6476628], 2x 4412 [6532261, 6532263], 1x 4742 [6472349], 1x 4973 [6461847], 1x 5401 [6480502], 3x 6179 [6472354, 6472355, 6484084], 2x 6636 [4324900, 6472233], 6x 14769 [6472246, 6472350, 6472351, 6477793, 7537600], 3x 15068 [6461848, 6472234, 6477777], 3x 18835 [6094029, 6145157, 6198121], 1x 24299 [6477797], 1x 24307 [6477798], 1x 26603 [6476888], 1x 27925 [6467909], 1x 29119 [6472239], 1x 29120 [6472240], 1x 32474 [6477781], 1x 32627 [6338524], 1x 41751 [4324900], 1x 45677 [6472248], 1x 49311 [6483080], 1x 49661 [6258021], 1x 53118 [6472255], 3x 54200 [6338182, 6486103, 6486137], 1x 59349 [6458417], 1x 61929 [4654822], 1x 63864 [6465832], 2x 64225 [4324900], 1x 65151 [6483561], 1x 65673 [6335355], 1x 67095 [6484083], 4x 67931 [6400148, 6425407, 6430320, 6441417], 4x 72206 [6336858, 6337780, 6438086, 6477787], 1x 75902 [6477801], 2x 76776 [6476337, 6476338], 2x 80177 [4324900], 2x 80178 [4324900], 2x 85984 [6472241, 6472251], 5x 87079 [6335978, 753700], 2x 93606 [6352816, 6352817], 11x 98138 [6287856, 6372427, 6415285, 6426359, 6455628, 6455633, 6471274, 6471276, 6477794, 6477799, 6480253], 1x 99498 [6000566], 1x 99499 [6000564], 1x 102498 [6480597], 1x 105162 [6481568], 1x 106700 [6471931], 1x 619291 [4654822]
• Added UV map: 3023, 3666, 3863, 3961, 4412, 4500, 4527, 4742, 4973, 5091, 5092, 5401, 5404, 5426, 5520, 24299, 24307, 29119, 29120, 30602, 41751, 45677, 53118, 93606, 105162, 106700
• Updated Materials.xml with: 142 [Earth Violet], 152 [Earth Red], 159 [Medium Reddish Orange], 160 [Light Reddish Orange], 161 [Sand Orange], 162 [Medium Yellow], 163 [Dark Yellow], 164 [Dark Blue], 165 [Medium Violet], 166 [Light Violet], 167 [Dark Violet], 214 [Beige], 215 [Dark Orange Brown], 286 [White with Glitter], 287 [Earth Green with Glitter], 288 [Earth Blue with Glitter], 289 [Dark Red with Glitter], 290 [Brown with Glitter], 291 [Black with Glitter], 292 [Medium Nougat], 301 [Transparent Bright Purple w/ Glitter], 303 [Transparent Bright Reddish Lilac w/ Glitter], 305 [Warm Gold, Diffuse], 307 [Transparent (Label)], 313 [Smoke], 317 [Lib White for Label], 318 [Collector Star Wars Blue for Label], 319 [Medium Blue for Label], 320 [Dark Blue for Label], 327 [Glitter 2%], 328 [Emergency Yellow], 331 [Lacquer], 332 [Fluorescent Red Ink], 333 [Fluorescent Green Ink], 338 [Fiber Spot], 343 [Diffuse White], 344 [Cyan Metallic Ink], 345 [Magenta Metallic Ink], 347 [Transparent Light Blue with Glitter 2%], 356 [Pearlescent Lacquer], 357 [Rainbow Shimmer Ink], 359 [Process White], 361 [Transparent Red with Opalescence 3%], 401 [Gold Coating], 429 [Process Yellow], 439 [Process Magenta], 454 [Process Cyan], 459 [Process Cyan], 489 [Process Black]
• Updated MaterialsNames with: 142 [Earth Violet], 152 [Earth Red], 159 [Medium Reddish Orange], 160 [Light Reddish Orange], 161 [Sand Orange], 162 [Medium Yellow], 163 [Dark Yellow], 164 [Dark Blue], 165 [Medium Violet], 166 [Light Violet], 167 [Dark Violet], 214 [Beige], 215 [Dark Orange Brown], 286 [White with Glitter], 287 [Earth Green with Glitter], 288 [Earth Blue with Glitter], 289 [Dark Red with Glitter], 290 [Brown with Glitter], 291 [Black with Glitter], 292 [Medium Nougat], 301 [Transparent Bright Purple w/ Glitter], 303 [Transparent Bright Reddish Lilac w/ Glitter], 305 [Warm Gold, Diffuse], 307 [Transparent (Label)], 313 [Smoke], 317 [Lib White for Label], 318 [Collector Star Wars Blue for Label], 319 [Medium Blue for Label], 320 [Dark Blue for Label], 327 [Glitter 2%], 328 [Emergency Yellow], 331 [Lacquer], 332 [Fluorescent Red Ink], 333 [Fluorescent Green Ink], 338 [Fiber Spot], 343 [Diffuse White], 344 [Cyan Metallic Ink], 345 [Magenta Metallic Ink], 347 [Transparent Light Blue with Glitter 2%], 356 [Pearlescent Lacquer], 357 [Rainbow Shimmer Ink], 359 [Process White], 361 [Transparent Red with Opalescence 3%], 401 [Gold Coating], 429 [Process Yellow], 439 [Process Magenta], 454 [Process Cyan], 459 [Process Cyan], 489 [Process Black]
• Updated Complete Color chart - Current with: 142 [Earth Violet], 152 [Earth Red], 159 [Medium Reddish Orange], 160 [Light Reddish Orange], 161 [Sand Orange], 162 [Medium Yellow], 163 [Dark Yellow], 164 [Dark Blue], 165 [Medium Violet], 166 [Light Violet], 167 [Dark Violet], 214 [Beige], 215 [Dark Orange Brown], 286 [White with Glitter], 287 [Earth Green with Glitter], 288 [Earth Blue with Glitter], 289 [Dark Red with Glitter], 290 [Brown with Glitter], 291 [Black with Glitter], 292 [Medium Nougat], 301 [Transparent Bright Purple w/ Glitter], 303 [Transparent Bright Reddish Lilac w/ Glitter], 305 [Warm Gold, Diffuse], 307 [Transparent (Label)], 313 [Smoke], 317 [Lib White for Label], 318 [Collector Star Wars Blue for Label], 319 [Medium Blue for Label], 320 [Dark Blue for Label], 327 [Glitter 2%], 328 [Emergency Yellow], 331 [Lacquer], 332 [Fluorescent Red Ink], 333 [Fluorescent Green Ink], 338 [Fiber Spot], 343 [Diffuse White], 344 [Cyan Metallic Ink], 345 [Magenta Metallic Ink], 347 [Transparent Light Blue with Glitter 2%], 356 [Pearlescent Lacquer], 357 [Rainbow Shimmer Ink], 359 [Process White], 361 [Transparent Red with Opalescence 3%], 401 [Gold Coating], 429 [Process Yellow], 439 [Process Magenta], 454 [Process Cyan], 459 [Process Cyan], 489 [Process Black]
For a complete list, including images, please see CustomLDDUpdates.com. For 22-day-early acces to this update, become a Patron :)
Edited by Stephan
  • 3 months later...
3 hours ago, vonhellstrum said:
@Stephanwill you ever add in older bricks like the old bionicle bricks? I know they've got LDraw files of those old bricks.
Yes, definitely!
