Carsten Svendsen Posted September 7, 2022 Posted September 7, 2022 On 9/7/2022 at 7:13 AM, Dami said: https://imgur.com/a/lIF93E2 Will this gear usage for turntable work? Sorry I dont have parts to test it lol Yes I uploaded picture on Imgur cuz I cant send it here directly lol Expand That'll work fine as long as it's the beveled turntable, not the new one just being produced now. Quote
Zerobricks Posted September 7, 2022 Posted September 7, 2022 (edited) On 9/7/2022 at 7:13 AM, Dami said: https://imgur.com/a/lIF93E2 Will this gear usage for turntable work? Sorry I dont have parts to test it lol Yes I uploaded picture on Imgur cuz I cant send it here directly lol Expand Also I suggest you use the biscuit piece instead of the 5L beam. This will keep the gear from slipping out sideways. Edited September 7, 2022 by Zerobricks Quote
PassengerJet Posted September 8, 2022 Posted September 8, 2022 I'm building a studfull 9v motorized car. So far it is just motor, transmission, and rear axel with floating axle suspension. Sariel's unnofficial guide book has helped me quite a bit so far and I was able to build the floating rear axle by adapting some instructions that he includes in the book, but for the front axle I'm not sure where to start. What would a studfull front axle with suspension look like? Thanks! Quote
Jurss Posted September 9, 2022 Posted September 9, 2022 Some technic bricks + plates. Something like that. Anyway you will need to use something from technic. Quote
Carsten Svendsen Posted September 9, 2022 Posted September 9, 2022 On 9/8/2022 at 7:56 PM, PassengerJet said: I'm building a studfull 9v motorized car. So far it is just motor, transmission, and rear axel with floating axle suspension. Sariel's unnofficial guide book has helped me quite a bit so far and I was able to build the floating rear axle by adapting some instructions that he includes in the book, but for the front axle I'm not sure where to start. What would a studfull front axle with suspension look like? Thanks! Expand 8465 is studded and a small front axle. But if you need it to FWD then maybe look at 8880 Regardless, you're going to have to use quite some technic parts for the actual wishbones, and studded for the frame. Quote
rhplus Posted September 11, 2022 Posted September 11, 2022 Hello, does anybody know if it is possible to fit 4L bar (no. 30374) into holes in technic chainlink (no. 3873) ? Thanks Quote
Zerobricks Posted September 11, 2022 Posted September 11, 2022 (edited) Yes, but not fully through. Edited September 11, 2022 by Zerobricks Quote
2GodBDGlory Posted September 12, 2022 Posted September 12, 2022 To clarify, it can go all the way through the middle hole, but the other four don't allow it to go through. Quote
rhplus Posted September 12, 2022 Posted September 12, 2022 On 9/11/2022 at 9:31 PM, Zerobricks said: Yes, but not fully through. Expand On 9/12/2022 at 12:22 AM, 2GodBDGlory said: To clarify, it can go all the way through the middle hole, but the other four don't allow it to go through. Expand Thank you guys. So if I got it right it is possible to fit the bar in the side holes of the chainlink in the same way like for example in the jumper plate with the open stud... Quote
Carsten Svendsen Posted September 12, 2022 Posted September 12, 2022 On 9/12/2022 at 6:29 AM, rhplus said: Thank you guys. So if I got it right it is possible to fit the bar in the side holes of the chainlink in the same way like for example in the jumper plate with the open stud... Expand Depends what you're doing. The bars do fit in the 2 outer holes of the thread, but with no clutch power what so ever. They do not stick. In the middle hole however, it does stay, but I wouldn't call it a reliable connection. Especially since if you're planning to use it on gears like an actual chain, then the bar won't stay in either. Quote
rhplus Posted September 12, 2022 Posted September 12, 2022 On 9/12/2022 at 8:00 AM, Carsten Svendsen said: Depends what you're doing. The bars do fit in the 2 outer holes of the thread, but with no clutch power what so ever. They do not stick. In the middle hole however, it does stay, but I wouldn't call it a reliable connection. Especially since if you're planning to use it on gears like an actual chain, then the bar won't stay in either. Expand Hello, I want to built a Hay Tedder as a implement for my tractor, something like this... long chain with several chain thread pieces with bars inserted into holes. But if you are saying that the connection is not tight enough I have to look for another solution Quote
2GodBDGlory Posted September 12, 2022 Posted September 12, 2022 One thing you could try is putting a 1x4 plate on top of the track link, and then attaching some kind of bars to the plate. It might not look as good, but the plate-to-track connection is fairly strong. Quote
Jurss Posted September 13, 2022 Posted September 13, 2022 On 9/12/2022 at 6:39 PM, rhplus said: But if you are saying that the connection is not tight enough I have to look for another solution Expand I tested, connection in the middlehole could be OK, but on the other side there will be gear, so you can just put in a tip. On the sides I was not able to push that bar in at all. Didn't wanted to brake any link. Think of some idea to create some chain from some elements. Or try to go for large chainlinks, and make something based on those. Quote
rhplus Posted September 13, 2022 Posted September 13, 2022 On 9/13/2022 at 5:33 AM, Jurss said: I tested, connection in the middlehole could be OK, but on the other side there will be gear, so you can just put in a tip. On the sides I was not able to push that bar in at all. Didn't wanted to brake any link. Think of some idea to create some chain from some elements. Or try to go for large chainlinks, and make something based on those. Expand Hello, I am thinking of putting plate 1x3 on a tread and then using 3 round plates 1x1 with holes on top. Into holes I will put the lightsabre bars Quote
Jurss Posted September 13, 2022 Posted September 13, 2022 Maybe these could be used https://rebrickable.com/parts/3957a/antenna-1-x-4-with-rounded-top/ or they are too long? They would hold better, I suppose. Quote
2GodBDGlory Posted September 13, 2022 Posted September 13, 2022 On 9/13/2022 at 1:08 PM, rhplus said: Hello, I am thinking of putting plate 1x3 on a tread and then using 3 round plates 1x1 with holes on top. Into holes I will put the lightsabre bars Expand Something like that could work, but in my experimentation, a 1x4 plate was held significantly more securely. Quote
PassengerJet Posted September 29, 2022 Posted September 29, 2022 I'm curious if there is any demand for a technic focused virtual building tool. Perhaps it could bring a concept of physics to the virtual building experience, like lego creator for technic? Quote
Jurss Posted September 30, 2022 Posted September 30, 2022 I know that stud.io has some capability of testing structural integrity. Never have used it. More liked would be some possibility to test functionality - f.i. gearbox, if all gears are correct, some linkages (LDD has it up to some level of complexity) etc. Quote
Jayden Posted September 30, 2022 Posted September 30, 2022 On 9/30/2022 at 4:42 AM, Jurss said: I know that stud.io has some capability of testing structural integrity. Expand It's not great at testing technic from my experience. Quote
Carsten Svendsen Posted September 30, 2022 Posted September 30, 2022 Sigh, how I wish Sergio didn't die prematurely. And no source code released either.... Quote
keymaker Posted October 2, 2022 Posted October 2, 2022 Hi, is there any reliable way to connect technic part with axle hole with hole in standard 1x2 brick hole? To be precise, I wish to somehow connect this part with this part. Quote
avalon102 Posted October 3, 2022 Posted October 3, 2022 Anyone know how this MINDSTORMS robot (pictures in the link) can be modified for increased stability for the task? Right now the book is too heavy for the motors. It was moving very slowly. That's probably because of the gears, right? Could one solution be to swap the place of the 40-tooth gear and the 8-tooth gear, so that the 8-tooth one is connected to the motor? Because we'd then be using a gear ratio of 8/40 = 1/5, giving us a much stronger torque. Maybe if I swap the gears so that the small gear is driving the large gear? That thing will then be able to move mountains (but slowly), or experiment with different gears other than the 8t and 40t. 8:40 is one of the most extreme ratios one could choose in technic, possibly there are many alternatives available to us by choosing different gears. http://gears.sariel.pl/ Quote
Jurss Posted October 3, 2022 Posted October 3, 2022 On 10/3/2022 at 12:33 AM, avalon102 said: experiment with different gears Expand +1 On 10/2/2022 at 7:51 PM, keymaker said: is there any reliable way Expand Glue? :) Try some of minifig utensils, maybe something will fit https://www.bricklink.com/catalogList.asp?pg=1&catString=18&catType=P Quote
GeorgeCrecy Posted October 7, 2022 Posted October 7, 2022 (edited) Hello one and all! I am hoping for some help in trying to make a Stephenson eccentric as showcased here: Reveal hidden contents https://upload.wikimedia.org/wikipedia/commons/0/01/Stephenson_link_animation.gif I am namely needing the bottom round area replicated; something that can surround and lock around a 4x4 round brick (6222), and have an axle opening upwards. So ideally in stud size not exceeding 6x6 and 1.5 stud in width. As of yet, I haven't had much luck figuring it out and am almost to the point of looking for someone to custom print the two or four needed parts. Any ideas or designs would be highly appreciated! Edited October 7, 2022 by GeorgeCrecy Fixing wrong part mention Quote
