technicmath Posted September 29, 2019 Posted September 29, 2019 The idea of @nicjasno in for a gearbox can be improved as follows. There is no need for a 24 or 28 gear with clutch: the setup can be built as (two axles) 28-24-(20 with clutch)-clutch-(16 with clutch) (16 with clutch)-clutch-(20 with clutch)-24-28. For these gear combinations, a distance of 44/16=2.75 studs is desired. By using the above configuration, there is a distance of sqrt(2^2+2^2) or approximately 2.828 studs. This can be improved by xx -> 1 x 2 technic brick with 2 holes with axle at the left xxxx -> 1 x 4 technic brick with axle at the right. Then the distance is sqrt((3*2/5)^2+2.5^2) or approximately 2.773 studs, which is much closer to the desired 2.75 studs and then the gears run much smoother. Quote
nicjasno Posted September 29, 2019 Posted September 29, 2019 Essentially making it even more compact than i planned. That is brilliant. Quote
MangaNOID Posted September 30, 2019 Posted September 30, 2019 Hey @technicmath Gentle reminder that your supposed to post in English Quote
Gray Gear Posted September 30, 2019 Posted September 30, 2019 Can you please post some pictures? I dont seem to be able to imagine what you are describing, but I am always intrested in Gearbox/transmission stuff Quote
technicmath Posted September 30, 2019 Author Posted September 30, 2019 Thank you nicjasno! Here is a picture of the concept: The old driving ring needs to be replaced by the new driving ring and the two 28 tooth gears are missing. In this 4 speed gearbox the gears are 16/28 approx 0.57 20/24 approx 0.83 24/20=1.2 28/16=1.75. Thus the ratios between the gears are 0.83/0.57 approx 1.46 1.2/0.83 approx 1.44 1.75/1.2 approx 1.46. Since sqrt(1.44)=1.2, a gearing of 1.2 will give intermediate gears to obtain an 8 speed gearbox. Thus the 4 gears of the above 4 speed gearbox are gears 1, 3, 5 and 7. By using the gearing of 1.2 in combination with this 4 speed gearbox you obtain gears 2, 4, 6 and 8. Then a 2 speed gearbox with a ratio of 1.2 between the 2 gears is needed. This can be done for example by (16 with clutch/16)x(12/24) and (20 with clutch/16)x(8/24) or (16 with clutch/20)x(24/8) and (16 with clutch/16)x(24/12) or (16 with clutch/20)x(12/24) and (16 with clutch/16)x(8/24)https://bricksafe.com/files/technicmath/gearbox/Gearbox2.png or other similar combinations. Then the 8 speed gearbox has approx these gears: gear 1: 0.57 gear 2: 0.57*1.2=0.684 gear 3: 0.83 gear 4: 0.83*1.2=0.996 gear 5: 1.2 gear 6: 1.2*1.2=1.44 gear 7: 1.75 gear 8: 1.75*1.2=2.1. In this 8 speed gearbox, the average ratio between successive gears is approx 1.2 and the ratio between the highest and lowest gear is 2.1/0.57 approx 3.68. This gives smaller gaps than in for example set 42110: 4 gears 1:5 ; 1:3 ; 1:1,67, 1:1 (according to techlug review) => average ratio between successive gears is 1.71 and ratio between highest and lowest gear is 5 set 42083: 8 gears 1:1,67 ; 1:1,25 ; 1:1 ; 1:0,8 ; 1:0,6 ; 1:0,45 ; 1:0,36 ; 1:0,29 (according to techlug review) => average ratio between successive gears is 1.28 and ratio between highest and lowest gear is 5.76. Quote
Attika Posted September 30, 2019 Posted September 30, 2019 You did the math, for sure. Sounds very promising, great concept. Quote
Gray Gear Posted September 30, 2019 Posted September 30, 2019 Wow, I dont know about the math, but is there a better way to get this distance between the gears? Using Technic Bricks, ones with different hole placements as well, does not seem very practical to me. Quote
Touc4nx Posted September 30, 2019 Posted September 30, 2019 @Gray Gear You could do that: And you don't have to do it sideways, you can make it horizontal. Quote
pleegwat Posted September 30, 2019 Posted September 30, 2019 @Touc4nxThat's just the 2*sqrt(2) distance. Quote
technicmath Posted September 30, 2019 Author Posted September 30, 2019 Thank you Attika. @Gray Gear As described in the first post, the desired distance between the gears is 2.75 studs. On a studless grid, even with considering half-stud lengths, the closest approximation that fits is a distance of 2 studs in one direction and 2 studs in a perpendicular direction as in nicjasno's original design (see link in the first post). This gives a distance of sqrt(2^2+2^2) or approximately 2.828 studs. As described in the first post, using the design with technic bricks gives a distance of sqrt((3*2/5)^2+2.5^2) or approximately 2.773 studs, which is much closer to the desired 2.75 studs. This is really worth it. You can align the 1 x 4 technic brick with a studless liftarm, then the axle going through this 1 x 4 technic brick fits in the studless grid. The axle going through the 1 x 2 technic brick with 2 holes is not aligned with the studless grid, but using for example a gear combination 20/24 you can with the same design land in the studless grid again. @Touc4nx The construction with the red perpendicular connectors gives the distance of sqrt(2^2+2^2) studs, which pleegwat already answered. Quote
nicjasno Posted September 30, 2019 Posted September 30, 2019 There need to be 3 shafts. 2 with gears and 1 with the rotational sequential switches. The 2 variants. One without modified gears and one with modified gears: Quote
TheHypaaa Posted September 30, 2019 Posted September 30, 2019 1 hour ago, nicjasno said: There need to be 3 shafts. 2 with gears and 1 with the rotational sequential switches. The 2 variants. One without modified gears and one with modified gears: Wouldn't the odd and even gears need to be seperated in order to be able to switch gears using the Bugatti shifter? Right now the sequence would be 1-3-2-4 or not? Quote
nicjasno Posted September 30, 2019 Posted September 30, 2019 13 minutes ago, TheHypaaa said: Wouldn't the odd and even gears need to be seperated in order to be able to switch gears using the Bugatti shifter? Right now the sequence would be 1-3-2-4 or not? Need to get the orange shifting gears first to see how this would work. But the order can ofc be shuffeled around to get the desired order. Quote
pleegwat Posted September 30, 2019 Posted September 30, 2019 When using rotary catches, the two sides of one selector are by necessity 180° apart, so you'd want 1 and 3 on one catch and 2 and 4 on the other. The pairing used here would be suitable if you wanted to make an 'H-shaped' manual gearbox, rather than a sequential one. Quote
Jeroen Ottens Posted September 30, 2019 Posted September 30, 2019 (edited) 2 hours ago, TheHypaaa said: Wouldn't the odd and even gears need to be seperated in order to be able to switch gears using the Bugatti shifter? Right now the sequence would be 1-3-2-4 or not? Yes they would, but if you combine this with the idea of making a 8 speed gearbox you can maybe use the other side to engage when this side is at the 'wrong' gear? I haven't tried to think it through, but there is something like half of the settings are not used on either side. BTW: A very original and smart idea to begin with! Edited September 30, 2019 by Jeroen Ottens Quote
Gray Gear Posted October 1, 2019 Posted October 1, 2019 12 hours ago, pleegwat said: @Touc4nx How do I remove a quote on mobile? Well, I am looking forward to a build utilizing this gearbox. It would find this pretty hard to incorporate in a Sportscar, as this design takes up quite a lot of vertical and horizontal space. But might be able to handle more torque than other gearboxes, so it might be good for Trucks? Quote
LegoTT Posted October 1, 2019 Posted October 1, 2019 My 2 cent there, for a 4gearboxe in a rc moc there is 300% between min and max there. By using the big side of an old diff we have a 4gearbox with 500% Quote
technicmath Posted October 2, 2019 Author Posted October 2, 2019 On 9/30/2019 at 11:14 PM, pleegwat said: When using rotary catches, the two sides of one selector are by necessity 180° apart, so you'd want 1 and 3 on one catch and 2 and 4 on the other. The pairing used here would be suitable if you wanted to make an 'H-shaped' manual gearbox, rather than a sequential one. Indeed. @LegoTT What exactly do you mean with 300% and 500% with the 24 tooth gear of an old diff? I built a sequential version of the above 4 speed gearbox. There need to be 2 additional orange changeover catches, 2 driving rings and 2 blue 20 tooth idler gears (instead of the tan 20 tooth gear in the picture). The two grey angle #2 connectors need to be replaced by the smooth axle connector for the driving ring. The distance between the two drive axles is 7*2/5=2.8 studs, which is better than the 2.828 studs, but not as good as the 2.773 studs. Note the usage of 5.5 axles. Quote
nicjasno Posted October 2, 2019 Posted October 2, 2019 I am waiting for the changeover plates before i can make my version. But just a comment... i'd use the old 2 stud driving rings, just to decrease overall length by 2 studs. Also, there's only 3 axles needed. The changeover axle being directly operated by the switching mechanism, like this: Quote
LegoTT Posted October 4, 2019 Posted October 4, 2019 On 10/2/2019 at 3:14 AM, technicmath said: What exactly do you mean with 300% and 500% with the 24 tooth gear of an old diff ? I mean if you use the new gear with a 16t like on the picture, the hight speed will be 3 time faster than the low speed. But since the topic is about low-friction gearbox, which could be useful for cars with motor, it would be better to keep the old configuration because the hight speed is 5 time faster than the low in it, it has more application. However, the old configuration is longer. Shaft 1 : 20t with driving ring, driving ring, 16t with driving ring, 12t, 8t Shaft 2 : 12t, 16t, 20t with driving ring, driving ring, 24t side of differential. The low ratio is 8/24=0.33, the hight ratio is 20/12=1.66 which is 5 time more. Quote
Zerobricks Posted October 5, 2019 Posted October 5, 2019 (edited) How about this design I came up a week ago, but forgot to post it: I simply offset the driveshafts allowing for more gear combinations without need for new clutch gears. The pulley wheels with ball pins are there to transfer power over the slight offset. The 4 gear ratios achieved are: 20:12 = 1,67 20:16 = 1,25 16:16 = 1 16:20 = 0,8 (overdrive) Because you can switch the order of gears as much as you want to, you can easily use the wave selectors. I think you can even upgrade the gearbox to work with 6 gears. Edited October 5, 2019 by Zerobricks Quote
TechnicRCRacer Posted October 22, 2019 Posted October 22, 2019 On 10/5/2019 at 9:52 AM, Zerobricks said: The pulley wheels with ball pins are there to transfer power over the slight offset. Does it work well? It doesn’t look like it will run very smooth. Quote
