universe mode problem after downgrading
  • Please log in to reply
8 replies to this topic
#1 SNIPE
SNIPE
    Member: 16759
    Country: United Kingdom
Posted 14 July 2012 - 06:38 PM
Hi, I have decided to make a group or template of a 1x1 brick in every color that is not available in the newer color palette bu after downgrading it crashed so I deleted the Lego Digital Designer folder in Macintosh HD/users/kris/library/application support/lego company.
When I opened LDD again the folder reappeared and expectedly put in the correct config files, etc for the downgraded version and the application opened fine however when I added a line in preferences.ini (Themeaccess=LEGOUniverse) it is still showing the new palette which is:
Posted Image
The palette I want is:
Posted Image
Any suggestions?
Edited by SNIPE, 14 July 2012 - 06:39 PM.
#2 hrontos
hrontos
    Member: 19500
    Country: Slovakia
Posted 14 July 2012 - 08:09 PM
View PostSNIPE, on 14 July 2012 - 06:38 PM, said:
Any suggestions?
This style of color palette is in LDD 3 (like 3.1.3) with LEGOUniverse mode enabled. At least in Windows.
#3 SNIPE
SNIPE
    Member: 16759
Posted 14 July 2012 - 08:25 PM
I can't seem to find LDD3 for mac on windows using virtual-box it goes really wierd, black bits, and keeps flickering between things etc can not even use it.
#4 hrontos
hrontos
    Member: 19500
    Country: Slovakia
Posted 14 July 2012 - 08:30 PM
You need only that LXF file with 1x1 bricks in all colors from that palette? If yes, I will create one for you.
#5 SNIPE
SNIPE
    Member: 16759
Posted 14 July 2012 - 08:32 PM
Thanks so very much :)
#6 hrontos
hrontos
    Member: 19500
    Country: Slovakia
Posted 14 July 2012 - 09:03 PM
No problem, you are welcome. Here it is. LXF
#7 SNIPE
SNIPE
    Member: 16759
Posted 14 July 2012 - 09:11 PM
'PC black' and other colors are not there when I open the file, did you enable universal mode?
Edited by SNIPE, 14 July 2012 - 09:11 PM.
#8 hrontos
hrontos
    Member: 19500
    Country: Slovakia
Posted 14 July 2012 - 09:18 PM
Yes, I did, as you see, file was saved in Universe mode. But it offers only one black.
If you just need complete palette, download Aanchir's color reference.
#9 SNIPE
SNIPE
    Member: 16759
Posted 14 July 2012 - 09:26 PM
Ah that's the one thanks.
