Jim Posted December 19, 2014 Posted December 19, 2014 Technic SBrick Contest Entry Topic DEADLINE Deadline date is February 15th, 2015. Contest will be closed on Monday the 16th, so you will have the entire Sunday to build. CONTEST INFORMATION More information about the contest can be found in the general discussion topic. WHAT DO I NEED TO ENTER? Please take a careful look at the rules before posting in this topic. Each participant is obliged to create a post in this entry topic. Posts need to follow the rules stated below. Posts not following the rules will be disqualified so please read them carefully. ENTRY POST The entry post in this topic should contain: Entry name Short summary of the functions. One or more images (max 5) Video (mandatory) Link to the discussion topic IMPORTANT This topic should be used for entries only, so commenting is prohibited. Please use the general discussion topic for comments on the entries.
Tommy Styrvoky Posted January 11, 2015 Posted January 11, 2015 1. IS-2 Heavy Tank Topic Sbrick/2 IR Functions: XL motor for left track XL motor for right track L motor for turret/DShk gearbox L motor for 122mm gun elevation/depression Other functions/features: Led lights Independently sprung suspension for each road wheel Self tensioning track with idler wheel and first road wheel Gun travel lock Gearbox functions Mode 1 DShk traverse Mode 2 Turret traverse and DShk remains parallel to the hull Mode 3 Turret and DShk traverse in unison Lego IS-2 Heavy Tank (RC) by Tommy Styrvoky, on Flickr Lego IS-2 Heavy Tank (RC) by Tommy Styrvoky, on Flickr Lego IS-2 Heavy Tank (RC) by Tommy Styrvoky, on Flickr Lego IS-2 Heavy Tank (RC) by Tommy Styrvoky, on Flickr Lego IS-2 Heavy Tank (RC) by Tommy Styrvoky, on Flickr
dfs473 Posted January 18, 2015 Posted January 18, 2015 2. CASE TR 270 Functions: - 1 M Motor for left track - 1 M Motor for right track - 1 M Motor for raising the boom - 1 M Motor for opening the bucket Features: - Quick coupler for changing between fork and bucket - easily removable battery box Discussion Topic
Ode Posted January 26, 2015 Posted January 26, 2015 (edited) 3. Z-Van Based on GMC minivan used in the TV show "A-Team". This is for the newer perrils out there, when a group of underground heroes have to adapt to the new times we are living into. These days seems like zombies are overrunning the TV and all the other types of media, some one needs to put that in check. For that you may call the Z-Team ...... ....... if you can find them. The MOC has: 1 L for drive, 1 Servo for steering 1 M for rotating the turret 1 M for guns action 1 PF lights 2 IR receivers Rear wheel drive, with a fake V8 under the hood, functional engine hood, driver, passenger, and rear doors, manual or automatic side pannels. Video: Photos: Topic: http://www.eurobrick...howtopic=105141 Edited February 14, 2015 by Jim Corrected video
TheNextLegoDesinger Posted February 5, 2015 Posted February 5, 2015 (edited) 4. Speed off-road Buggy Functions: -drive by XL motor -return-to-center steering L motor -shifting speeds by M motor -winch by L motor Features: -openable rolcage -openable front hood -separate DRIVER Discussion topic: Edited February 15, 2015 by Jim Embedded video
BachAddict Posted February 6, 2015 Posted February 6, 2015 (edited) 5. Katipo Spider Discussion Topic Modeled on the venomous Katipo spider, the NZ cousin of the Black Widow! Functions: Left walking Right walking Jaws Winch The walking mechanism is based on Sariel's Octopod walker, stretched sideways to reduce the step size so the long legs work realistically. I tried making it walk on the long axle-built legs, but their length amplifies the weight too much! The model works perfectly with the Sbrick, but the Android app is not reliable enough to use for demonstration. The jaws are closed by two MiniLAs, which gives them a painfully strong bite that the spider can hang from. A winch at the back is directly driven by an XL motor for fast climbing! I could easily thread the string through the front to make it climb up more realistically, but real ones use their legs for that anyway. The red mark on the back, brown leg tips and eye layout are carefully copied from the real one. Taking on giant spiders without Sting is not recommended! Discussion Topic Edited February 15, 2015 by BachAddict
falconluan Posted February 8, 2015 Posted February 8, 2015 6. DT-54 Bulldozer Designed and produced by Soviet Union, DT-54 is a tractor for general use. It was produced during 1949-1979, and a total number of 957,900 was made. To meet the TC6 requirement, I added a blade in the front and a ripper at the back, making it into a bulldozer. Functions: 2 L motors for propulsion 1 M motor for blade 1 M motor for ripper Photos: Video: Discussion topic: http://www.eurobrick...pic=105161&st=0 Thanks for watching.
efferman Posted February 8, 2015 Posted February 8, 2015 7. ESL 19/21 Sideloader Forklift Discussion Topic It uses 3 PF-L and one Pf M for four functions. driving, steering, lifting the fork and move the sled. The Cab has a sliding door and the steering has a ackermann geometry.
gmshades Posted February 8, 2015 Posted February 8, 2015 8. Mead's Towing Discussion Topic: http://www.eurobrick...howtopic=103624 Features: 2 IR receivers 3 m motors, 1 xl motor 1st m motor - switches between 1st set and 2nd set of functions 2nd m motor - 1st Steering, 2nd Winch 3rd m motor - 1st Stabilzers, 2nd Boom extension xl motor - 1st Drive both set of rear axles and v8 motor, 2nd Boom raise/lower Automatic vehicle lift when Boom is fully lowered Tilt Cab Final pictures: And video: Enjoy!
lindr6 Posted February 8, 2015 Posted February 8, 2015 9. Dump Bed Pickup Truck Discussion Topic Functions: - 1 Servo Motor: Steering - 1 Large Motor: Rear Wheels - 1 Medium Motor: Dump Bed (small LA) - 1 Medium Motor: Switch Headlights On/Off - 2 IR receivers as I do not have an s-brick. Other Features - Limited slip rear differential - Live rear axle suspension - Perpendicular front axle with steering - Steering wheel turns with servo motor - Doors open and close manually
Eraman Posted February 9, 2015 Posted February 9, 2015 10. Mercedes Econic Garbage Truck Details: dimensions: LxWxH: 80x21x23 stud (63x17x18 cm) pieces: 4100-4200 weight: about 4 kg fake engine: 4 pistons in a row 3 axles, 1. and 3. axles are steerable in different angle, also the steering wheel is turning in the cabin 6 motorized functions with 2 M and 2 L motors and 3 gearbox. Functions: 1 L motor: changing gears 1 L motor: driving / blade sweep 1 M motor: steering / tailgate raiser 1M motor: garbage ejector / slide packer Manual function: cabin tilting Little functions and details: tilt seats, dashboard, openable grille, openable doors on both sides, etc. Photos: More photos HERE! Video: Discussion topic HERE! Thank you!
Graydingo Posted February 12, 2015 Posted February 12, 2015 (edited) 11. '66 Chevy C-10 Custom Function Summary: 4 motor functions: 1. Two L motors working together via gearbox to drive the rear wheels. 2. M motor for steering with gear reduced steering wheel. 3. M motor for Air ride pump. 4. M motor for Air ride Up/Down Switch. Other: LED Headlights Manual: Doors, hood, tailgate and removable tonnuea cover Video: Discussion Topic Edited February 16, 2015 by Graydingo
filsawgood Posted February 12, 2015 Posted February 12, 2015 (edited) 12. Extended Customized Pick-up Truck RC functions: 1) Driving (XL motor) 2) Steereng (Servo motor) 3) Winch (M motor) 4) Switch on 4x4 (M motor) Discussion topic Edited February 14, 2015 by Jim
deehtha Posted February 13, 2015 Posted February 13, 2015 13. Modified Rough Terrain Transport This vehicle is used on a remote mining facility, (on another planet even). The vehicle used to be a military transport vehicle of some sort, designed for very rugged terrain. Once the loading crane broke down, the residents of the mining colony mounted the boom of the crane horizontally to the back of the truck, so they could continue using the truck to transport supplies and equipment around the mining colony. Functions 2x L Motors for propulsion 1x Servo for steering 1x M Motor for boom extension 1x M Motor for winch Other Functions 6x6 drive steering on axles 1 and 3 steering wheel turns when wheels are steered LED Headlights LED Lights in cargo bay fake V6 Compass!! Boom extended, hook lowered. You can also see the net and chains that keep the cargo from falling out the back. You can barely see the fake V6 underneath the IR Receiver. WIP Pictures Pictures Topic
D3K Posted February 13, 2015 Posted February 13, 2015 (edited) 14. Modernized 8868 B-model The features are as follows: Motorized (RC) functions: Rear wheel drive from a vertically mounted PF L-motor Steering with correct angles on both front axles from a PF Servo motor Dumpable bed from a PF M-motor Pneumatic loop for the loading action from dual small pumps driven by a PF M-motor Independent double wishbone suspension on both front axles Rear live axle suspension with leaf springs (flex axles) Dump bed flap opens via chains when bed is dumped Openable doors Adjustable seats Discussion topic with heaps more pictures and information can be found HERE Good luck to everybody, lots of great entries so far, can't wait to see what will emerge over the weekend! EDIT: (Re)added video. Was gone for some reason Edited February 15, 2015 by D3K
jorgeopesi Posted February 14, 2015 Posted February 14, 2015 15. Komatsu WA 600-6 Functions: - M motor for raising arm - M motor for tilting bucket - XL motor for drive - M motor foir steering Details: - 6 in line working fake engine - 2 cabin doors and 5 engine doors - Pendular suspension - Functional steering wheel - 1,9 kg - Less than 2200 pieces Images Video [/url]Discusion topic http://www.eurobrick...l=komatsu&st=25
Lipko Posted February 14, 2015 Posted February 14, 2015 16. Hot Rod Wrecker Remote controlled functions: -Drive -Steering -2-speed gearbox -auto crane winch Other functions: -live axles with push-rod suspension -opening doors -cockpit steering -working gear stick Discussion topic: http://www.eurobrick...howtopic=105100 Picture gallery: http://www.brickshel...ry.cgi?f=552363 Video:
MrTekneex Posted February 14, 2015 Posted February 14, 2015 (edited) 17. Bin lifter-Satellite Waste Collection General specifications: - Number of pieces: ~2000 - Size: 46x16x16 cm - Weight: 1,8 Kg Manual functions: - Opening doors - Opening bonnet Remote controlled gearbox for operating 6 different motorized functions: - A/1 Drive (mechanical) - A/2 Outriggers (mechanical, 2 miniLA) - A/3 Steering (mechanical) - B/1 Bin lifter tipper==>loading (pneumatic function with pump cumpressor & autovalve) - B/2 Bin lifter tipper==>dumping (mechanical, 1 miniLA) - B/3 Waste collection bin tipping (mechanical, 2 miniLA) Other features: - Indipendant front suspensions - Leaf spring rear suspensions - Differential - Double rear wheels Images Video Discussion topic http://www.eurobrick...howtopic=105840 Edited February 15, 2015 by MrTekneex
KirTech LAB Posted February 14, 2015 Posted February 14, 2015 18. Arctic Equalizer I’m glad to present my [TC6] contest model – Arctic Equalizer! It’s a mix of huge bulldozer, ice-breaker and… road-roller! Dimensions: 77cm x 38cm x 55cm Weight: 6.9kg (I’ve made special handle at the top for transportation) I’ve used two V2 receivers for RC functions and constantly running powerful compressor (eight small pumps, two 9V BB, three Air Tanks). RC functions (total six motors): - Left and right tracks, two pairs of XL-motors; - Three-channel distribution gearbox (two-speed gearbox for tracks and one more switching additional function), one M-motor; - Additional function, one M-motor. Transmission: So additional motor puts in action three valves. One valve controls front blade height and two other valves controls the height of roller. Roller valves works separately due to differential gear with one overloaded output (additional gears on axle pins with friction). Video: Discussion topic: http://www.eurobrick...howtopic=105055 Hope you like it! Thanks for watching!!!
Dave21 Posted February 14, 2015 Posted February 14, 2015 19. Dumptruck 8x4 Discussion topic here. Functions are: - Driving: XL-Motor - Steering: Servo-Motor - Tilt dump bed: L-Motor - Tilt Cabin: M-Motor - Open doors - V8 Fake engine Video: http://www.brickshelf.com/gallery/Dave21/Technic/Dumptruck-8x4/dumptruck.mp4 Images (click for larger images): More pictures on my Brickshelf. Thanks for reading. Dave
LeocornoProductions Posted February 14, 2015 Posted February 14, 2015 (edited) 20. Lamborghini Huracan Hello all This is my entry for TC6, the lamborghini huracan. It originally started in life as a semi-completed chassis for my mclaren p1 mk2 moc, but was completely redesigned for a 4wd supercar chassis, and the easiest 4wd supercar I thought of building would be the new lamborghini huracan (I say easy, due to the likings of the bugatti veyron, nissan gtr, lambo aventador, audi r8 which are all 4wd.) Here are the functions: Motorized functions include: -1 XL motor for drive -1 Servo motor for steering -1 L motor for changing gears -1 M motor for raising the left rear pushrod (because the battery box creates a vast bias on the suspension) Manual functions: - opening hood - linear actuated scissor doors - adjustable aero: adjustable spoiler angle, adjustable front splitter - working front lights Specifications: - Flat 10 engine Max rpm: 121.7 (max output torque 17.4N.cm to the engine) - 1.3KG - 0.004HP - 28.2N.cm of torque to the wheels - 3.08HP per ton Also the car features a flat 10 engine, running at speeds of the XL motor. The chassis was intensely developed in a period of almost 2 months to enclose many variants of the car such as the gearbox, engine, various suspension types and such, and to stay completely rigid even when the roof and engine cover are removed. The car also has 30 degree independent suspension in the front, and pushrod suspension in the rear inspired by the lamborghini aventador. Here are some pictures of the car: Discussion Topic Video (part 1 specs): https://www.youtube....kgHiaCdR_M9EUpA Video (part 2 functions): https://www.youtube....kgHiaCdR_M9EUpA Video (part 3 The drive): https://www.youtube....kgHiaCdR_M9EUpA Sorry that the video is not good quality, it's because the video maker software I normally use for uploading ALL my youtube videos, got deleted when my laptop broke, and downloading it won't work because it corrupts my laptop. And If I eventually found a solution, I wouldn't make the competition deadlines. I hope you like it, and thank you for viewing it! Edited February 16, 2015 by LeocornoProductions Linked to single video (embedding fails for some reason)
Omikron Posted February 15, 2015 Posted February 15, 2015 (edited) 21. Secret Project Discussion topic Here This MOC uses 3 M-motors and 1 L-motor. They are connected to 2 IR receivers. 1 Battery box. 10 motorized functions: 1 Landing Gear 2 Canopy 3 Radar 4 Air Brakes 5 Roll 6 Pitch 7 Yaw 8-9 Combination of those also provide motorized thrust vectoring. 10 The slats are also moving with canards to provide more lifting power. Additional manual functions: 1 Pilot indicators 2 Gearbox 3 Joystick, pedals, ejection loop Lights: 1 Engine 2 Canopy indicators 100 studs long, 3,2 kg. Lots of white. All mechanics - click-able. Best in 720P Video for German users: Oh and by the way there are some awesome comics about the history of its creation - Awesome comics! Edited February 16, 2015 by Omikron
super-jaschka Posted February 15, 2015 Posted February 15, 2015 22. Fire Truck TLG does not produce a long time in this series, I've decided to fill this gap ... -1 L for driving and outriggers (manual switching function) -1 S for steering -1 M for turntable -1 M for boom lift -1 PF lights -2 IR receivers Topic for discussion: http://www.eurobrick...howtopic=105853
jono rocky Posted February 15, 2015 Posted February 15, 2015 23. Concrete Truck G'day everyone. Here is my entry for this [TS6] competition, a technic lego concrete truck. The discussion thread is here http://www.eurobrick...howtopic=105717. The truck can use either battery case inside the cab. Door steps swing open and close when the door is opened and shut. This model truck was loosely based on the Freightliner Argosy. Has twin steering and driven by both rear diffs to a fake V8 motor. Its functions are: L motor for drive. Servo motor for steering. L motor for rotation of drum. M motor for discharge chute raise and lower. The manual functions are: Cab tilt. Doors opening. Chute swing from side to side. Chute extensions.
Seasider Posted February 15, 2015 Posted February 15, 2015 (edited) 24. Tractor This is my first PF/Remote MOC and I'm pretty proud of it as it all works as planned. It's a litle agricultural in its design (pun intended). Enjoy ... Functions: 1 Large Motor - Drive 1 Servo Motor - Steering 1 Medium Motor - PTO On/Off 1 Medium Motor - PTO Lift Arms Raise/Lower Pictures: Controller : (From Left to Right) Drive, Steering, PTO On/Off, PTO Raise/Lower Link to WIP Thread: http://www.eurobrick...howtopic=104180 Edited February 15, 2015 by Jim Embedded video (somehow video does not embed?)
