Showing results for tags 'trans yellow'.
Some members here had probably heard that months ago, I submitted a piece pack on Lego Ideas as a project and was rejected. However, I’m not here to discuss about if Lego Ideas decision was right or not, but to explain why I did this in the first place and how this can be sustained. On Reddit someone asked about this pack and I replied. “The idea for the petition for a Classic Space piece pack was on the believe that many Classic Space fans have over 40 years of collecting pieces and also have enough pieces to build complex designs on their own, so a piece pack would be a great gift for hardcore Classic Space fans to continue designing new Neo-Classic Space creations on their own…” Classic Space sets have at least 3 big color schemes to be known. Light gray/black/trans green, white/black/trans blue and what most fans consider the true C. S. blue/light grey/trans yellow. The white/black/trans blue is widely consider to be Futuron color scheme rather than Classic Space although it was used widely on the later years of that theme. Also, the number of trans blue pieces is larger than the trans yellow ones since it has been wider used in other Lego themes such as aquanauts, town space, and even Minecraft. Let’s face it. One of the biggest limitations for Neo Classic Space Mocs are the existing Trans yellow pieces available. You also have the space logo pieces and other limitations, but for what I’ve seen and heard. Every time a new trans yellow piece have been found on new Lego publications, the C. S. community goes nuts. For instance, how many people here know (or even care) that Lego has never made the 1x12 plate in blue color, but if I told you that minifig legs and arms in Trans Yellow color exist you’ll probably will rush to Bricklink to corroborate the last part. Die hard C.S. fans usually have a Lego Collection spanning four decades consisting of thousands of pieces. So, for them, a new window or windscreen in trans yellow is worth its weight in gold. I know you can get around the piece limitation problem by combining pieces, but a single piece windscreen solves any probable stability problems. The question is, Classic Space fans will consider a C.S. (trans yellow) Piece Pack good enough to be as good as a new Classic Space set? For me, the answer is YES! Maybe will not be as cool as a new professional Lego space set design, but it will expand my posibilities to create Classic Space MOCs.
- 22 replies
- classic space
- classic
(and 4 more)
Tagged with:
