Showing results for tags 't-70'.
I picked this set up last year, I have tried many ways to modded the wings, this is the latest version which remained unchanged for around 6 months. The biggest problems for this set and the black/orange version is that the wings overlap, I have to fill up the each top engine nacelles with 1 x 3795 Light Bluish Gray Plate 2 x 6 , 1 x 3023 Dark Bluish Gray Plate 1 x 2. Move the existing parts around to rebuild the front wings, swapped the position of the 2 slopes (3298 and 3297). The end result is that each wing is 3 studs thick, when closed the whole wing combined is 4 studs thick. Additional parts required below, I apologise in advance if I missed any, I have tried so many different combinations overtime that I have to refer to the original building instructions to what the wings look like originally. For the nose 1 x 3069b sand blue 1 x 2 tile 1 x 807079 Light Bluish Grey 2 x 4 tile For the wings 2 x 3795 Light Bluish Gray Plate 2 x 6 2 x 3023 Dark Blueish Gray Plate 1 x 2 4 x 3024 Dark Bluish Gray Plate 1 x 1 Cannons 4 x 3713 Light Bluish Gray Technic Bush 75149 Mod by R Y, on Flickr 75149 Nose by R Y, on Flickr 75149 Wings Closed Front by R Y, on Flickr 75149 Wings Close Back by R Y, on Flickr 75149 Wings Open Front by R Y, on Flickr 75149 Wings Open Back by R Y, on Flickr 75149 Back Wing Topside by R Y, on Flickr 75149 Back Wing Underside by R Y, on Flickr 75149 Front Wing Topside by R Y, on Flickr 75149 Front Wing Underside by R Y, on Flickr
I was wondering if anyone has managed to combine 9493 and 75102 into one kind of "super x-wing". I tried but it fell apart.
This is my latest creation of Poe Damerons black X-wing from SW7. It has previously been posted here. This version is on a small stand to present it a bit better, created for a exhibition at Star Wars days in Legoland Billund earlier this year. And again, sorry for the terribly blurry pictures... I hope you still like them... Poe's Black X-wing by Kenneth, on Flickr Poe's Black X-wing by Kenneth, on Flickr Poe's Black X-wing by Kenneth, on Flickr More pictures in my Flickr account
- 1 reply
- moc
- poe dameron
(and 3 more)
Tagged with:
Today I started my next project, a model of the new T-70 x wing from star wars. I think I have the back wings figured out, here is a concept for it. Colours not final obviously. I'll continue to add to this thread as I make more progress. I decided on light gray for this. White just looks out of place to me and it doesn't appear that way even some of the time as the T-65 did depending on lighting. The wings (at least from my limited reference) are also seeming to be slightly thicker on the new ship, so I went with a snot design instead of 2 plates thick. I think that curve arch piece is the only really sufficient way to capture the curve of the wingtip with fidelity so I based the design on mounting each laser on each wing with those piece. Next, I'll tackle the front wings and engine assembly, maybe the rear fuselage.
