Showing results for tags 'motion picture'.
Hi everybody, With the new Alien: Convenant movie coming to cinemas this May, I wanted to pay tribute to the original Alien motion picture (1979) by building the space ship in which this sci-fi classic is set – the USCSS Nostromo. Since there are already some beautiful Lego designs of the Nostromo ship (the “towing vehicle”), I wanted to do something different. As Alien fans will know, in the first few minutes of the movie, a massive refinery is moving silently through open space. I would try building this ore refinery! I hope you like the result and thank you for your feedback and comments. A special shout-out goes to the Arvo Brothers, who did some amazing Alien designs. Their work and our mutual passion inspired me to start this first Lego project . The Lego Model: Bricks: 3'144 Scale: 1:42000 (approx.) Length: 55 cm (22 in) Width: 40 cm (16 in) Height: 38 cm (15 in) Weight: 3.4 kg (7.5 lb) The build After doing some research; I started with new and old dark gray bricks. Halfway in the project the model looked like a dark “blob” and I decided to change the color to light gray. After I used up all my old gray bricks, I spend way too much money on buying bricks – especially small parts for the detailing. At first I thought the different coloring of the bricks would not work, but the fact it is not completely build out of new bricks fits the model well. The Challenges One of the main challenges, was the decision to having the top- and bottom section inverted. The reason for doing this, was to allow me to detail the model with round bricks both on the top as well as the bottom. It had to look like a refinery with tanks, pipes and structures. With every brick, it became more evident, the stability would be a challenge. The two biggest towers standing in the rear became quite heavy. This works in space with zero gravity, but on earth this means the model started tipping backward and looked more and more like a banana! After many, many trails and errors it finally worked in the end. I hope you out there like it! You can find all the pictures here on Flickr. Cheers, Remco
- 15 replies
- alien
- ridley scott
(and 10 more)
Tagged with:
