Showing results for tags 'heavy mod'.
Well, it certainly wasn't easy but I managed to reverse engineer most of set 43217 - 'Up' house (seen above in spoiler) and add a back to it using just two box pictures. I added a back half and raised the build by a brick and a plate. Unfortunately, I just couldn't figure out the roof from the set or the original bay window. The former just got swapped for a brick-built roof, while the latter was removed and replaced with something simpler after much stress. The new rear half. It had it's issues trying to get everything to work. But it's good enough for me. The house folds open and even wraps around the chimney as much as possible. (The odd-size flue sticks out into the back half's space a bit) The lower floor features a living room, foyer, kitchen, and dining room while the upper floor features a bedroom. The first floor worked out well design-wise, but the second floor is an absolute mess due to all the supports / arches / beams needed to hold the roof together. Speaking of the roof, both sections aren't very pretty, but it works... at the cost of taking a whole bunch of upstairs space on the inside, as you can see. This vintage car was heavily modified from a model by BricksAA and these free MOC instructions over on Rebrickable. The car features a spare tire hanging at the back of the vehicle. The roof is removable to seat the three figures on the inside. EDIT 3/11/23: Car photos added! Thoughts?
- 12 replies
- farm house
- automobile
(and 7 more)
Tagged with:
