Showing results for tags 'general electric'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 3 results
  1. This 7-stud wide diesel is modeled after the General Electric (GE) 44 ton switcher locomotive made between 1940 and 1956. The little diesel is bi-directional, and doesn't have much to differentiate between the "front" or "rear" expect for the air horn on one end in real life. My LEGO model lacks these, so it is totally symmetrical. You may be asking yourself: 'Why 44 tons, what's so special about that number?' I give you the answer from the Wikipedia article on this loco type: "This locomotive's specific 44-short ton weight was directly related to one of the efficiencies the new diesel locomotives offered compared to their steam counterparts: reduced labor intensity. In the late 1930s, the steam to diesel transition was in its infancy in North America, and railroad unions were trying to protect the locomotive fireman jobs that were redundant with diesel units. One measure taken to this end was the 1937 so-called '90,000 Pound Rule' : a stipulation that locomotives weighing 90,000 pounds (41,000 kg) – 45 short tons – or more required a fireman in addition to an engineer on common carrier railroads. (Industrial and military railroads had no such stipulation.) The 44-ton locomotive was born to skirt this requirement. The 45-ton rule was eventually repealed in 1963." Side view of the loco showcasing the symmetry of the model. In-universe, This diesel is painted as Brick Railway Systems loco 97 in a throwback black / red paint scheme to celebrate the railroad's 130th anniversary in 2024. (In reality, it's my fictional railroad I made up when I was a fourth grader, which is having it's 20th anniversary this year, so I've been feeling a bit nostalgic recently.) Thoughts?
  2. I haven't built a new diesel MOC in a little bit, so I decided to take a crack at a new challenge. This time, I decided to try and do a GE U36B. These were part of General Electric's 'Universal' Series, with 3600 HP and a B-B wheel arrangement, hence the name. 125 were produced between 1969 and 1974, with most of them going to Auto-Train and Seaboard Coast Line (Later CSX). As far as I can tell, most of these units were scrapped with only a few remaining examples today. And then here is my rendition of it. The livery is of my fictional railway company. I'm pretty proud of the building techniques that I used to get the front of the nose to offset like that, but it still needs a bit of work to be closer to the prototype, I think. I also tried using the regular steering wheel piece for the brake on the side of the nose, but I found it stuck out too far. Instead, I went with an old film reel piece, and I think it gets the idea across. Thankfully it came in white. Squeezing the PU hub into this locomotive was tough while keeping the entire back end as close to 4w as possible. I ended up using a technique I used previously to mount the hub inside the fuel tank. I then used sideways flags to try and hide the connections for the motors. I think it's decently well hidden, but I couldn't come up with another better solution. Also, since the Hub is so far down in the locomotive, a small section of roof lifts off and there is a technic axle you can push that hits the button on the Hub. Overall, I'm pretty happy with it. There's a few things I want to revisit and redo at some point, but for now, I'm calling it done. As always, if you would like to download the Stud.io file, here is the link to all of my MOCs I've posted on here. This one is under the file named "U36B". Legownz's Train Mocs - Bricksafe Thanks for looking!
  3. This loco was originally from the 2010 CITY set 7939 - Cargo Train and first designed in red for my brother. (who ended up not building it in real life after all) I removed the rear cab and replaced it with a personnel door for access to the train and recolored it to yellow for use by me. I then looked back on what I made, and realized it actually resembled a real engine completely on accident! It appears I made a General Electric 'Genesis' series loco, specifically a P42DC as those were the most common of the sub-types. The Genesis types weren't used by freight railroads - just passenger-only carriers like Amtrak or VIA - but this is my railroad and what I say goes! Here we see the front of the locomotive. The rear side of the loco with the crew access door at the very back. The cab front flips up to put a figure at the controls. (I removed the cab roof here to make taking the picture easier.) To read more about the Genesis locomotive types, check out this Wikipedia link. Thoughts?
