Showing results for tags 'e03-001'.
Hi all, I gave another try to the new 12-wheeler chassis, and this time I could not resist to recreate another iconic locomotive. The real DB E03 is based on a CoCo wheel arrangement, so the 7740 locomotive was more accurate on this aspect. But I'm in the "Blue Era" , so I am a bit limited to the 4,5v/12v motor size and "rigidity". Therefore, my DB E03 is still a 12-wheeler, but in a BoBoBo-like arrangement. Don't tell anyone! This is my first DB E03 - I've never built one in other styles or sizes, apart the 7740. I chosed the first one produced since i liked that silver middle line separating the red and the yellow parts. It can be built also as a DB E103, removing the gray line in the middle of the body, adding a second line of lateral grilles, and changing the pantographs to the one-armed model (it was already used in the late 70s - so it fits the Blue Era). The correct wagons for this one could easily be the Rheingold ones, but in red/yellow color scheme. They should be a bit longer too. In this case, they would be also a lot heavier, I wonder if the 12v motor can pull such heavy things on highly-uneffective wheels lof the time. I hope you like it! Ciao! Davide
