Showing results for tags 'deutsche bundesbahn'.
Hi all, since I read the very, very interesting thread about Torben Plagborg creations, I've been trying some new designs (some are just sketches, just to understand how things could work). Now, in this nice thread some nice 12v creations can be seen - but one captured my interest more than others. It's a little blue steamer with a black 12v motor. It seems pretty big, so I'd say it was an 8-wide experiment. In general, all the top shelves are very interesting. Starting from that little steamer, I began to think about a 12v locomotive in 8-wide. So I started designing another small steamer (I'd say a well known prototype): the great Deutsche Bundesbahn BR-80. 8-wide is not a common scale for me - I only tried it two times in my whole life, so it was a trial and error process. I tried to use parts that could have been available in the last 80s /first 90s - during the Phase II of the Gray Era and the advent of 9v era. And here it is...it recalls me a "fat" 7727/7730, with a touch of 7810... 8-wide gives some possibility also to work with odd number of studs (boiler is 5 studs wide instead of the classic 4-wide used in standard 12v steamers). I kept the standard cylinders, the ladders, rods, red buffers and magnets, which fit nicely an keep the 12v feeling alive. I used Some SNOT for the doors, using headlight bricks. Everything was already experimented at the time (e.g. the B-model wagon with horizontal sliding doors in 7735 instructions). Right side is quite symmetrical to the left one, apart some details. 12v motor looks nice, now that the body is correctly larger. Weights can sit on top of the motor - but the model could already be sufficiently heavy to have some decent traction and pulling power. I think adding lights won't be a problem nowadays, but for sure at the time (80s/90s) it could have been an additional challenge ! But...there are some issues that must be noted: The buffers overhang is quite...massive - and this SURELY will create problems with 12v switches, since the buffers will collide with the switching electric mechanism. Coupling wagons on R40 curves could be impossible...since this BR80 is longer than any other 12v locomotive or wagon not based on bogies chassis. Weight of a complete train could be excessive for the poor 12v motors. I think it has been a very fun experiment, a real "12v+" MOC...but being realistic - in my opinion it's too limited by the motor, wheels size...and 12v track geometry itself . Maybe, with 3d printed 12v wheels and a PF-based motor it could work on PF flexible track - but it would then loose 90% of its "vintage" appeal. I'd classify it as "Virtual Shelf Queen" ! Ciao! Davide
Greetings, Train Tech! About a year ago, I posted my Umbauwagen 4yg. Here is the 3-axle variant, the 3yg: The name Umbauwagen means "rebuilt coach" -- these coaches were built after World War 2 by modernizing prewar compartment coaches. More accurately, this is an AB3yg (first/second class) + B3yg (second class) pair -- these cars were nearly always found in close-coupled pairs. A few survive as single units in work trains, painted yellow. The body of the model is essentially constructed the same way as my 4yg model: studs-up construction for the main body (leveraging the train window and the 2x8x2 curved slope), SNOT construction for the doors, the details around the buffer, steps, and corridor bellows. Of course I designed new side frames, and there are a few minor details that are different such as the lights above the end doors of the pair. These cars were painted green in DB service, but as the train window does not come in green I elected to build the 3yg in a different color scheme. I believe that this livery corresponds to 3yg cars used as trailers for the ET 85 electric units -- someone with more knowledge of German railways may be able to shed more light on this. At the time I built the 4yg I also built some test models to research how feasible it would be to build the three-axle variant. However, I ran into difficulties designing the chassis and moved on building the 4-axle variant instead (which had none of these challenges). Earlier this year I circled back and spent some time looking into the problem. The first attempt was to articulate the chassis as 4+2, pivoting the body to reduce the overhang -- a technique I previously used on the tender for my model of the Gr670. However, the Umbauwagen 3yg not only has a long 3-axle wheelbase, but also has a long distance between the outer axles and the buffers: Articulating the chassis as 4+2 would allow the car to negotiate turns, however it would also derail any vehicle attached to it as the buffers swung out widely. Further iteration yielded the general outline of my eventual solution: The center and end axles are connected together with a 6-bar linkage, rather than a rigid frame, allowing the chassis to change shape when traveling through curves. It's important to note that the center axle is actually what actuates the system. As the car enters a curve, the center axle is pushed sideways to follow the curve, which in turn angles the outer axles to follow the curve as well. The track cannot apply rotational forces through a single pair of wheels on one axle, and so a similar design to this one without the center axle would not work. You can see the mechanism here: The outer axles are mounted on 2x2 round bricks riding in a 2-stud-wide channel, allowing them to turn and slide slightly towards the center of the car in turns. I experimented a bit to find the best places for the pivots and a construction that would be light and reliable. In the final model I removed the blue tiles shown in the screenshot, to avoid additional friction and binding in the mechanism. Thanks for following along! As usual, I've uploaded some additional images to a Brickshelf gallery, including some notes on and prototypes of the linkage mechanism. Thanks for reading, and let me know if you have any questions!
- 13 replies
- bricklink warrior
- interiors are overrated
- (and 7 more)
