Showing results for tags 'building technique'.
Inspired by the latest rusian S-70 okhotnik and the B-2 Spirit. stealth0 by Nom Carver, en Flickr stealth3 by Nom Carver, en Flickr stealth2 by Nom Carver, en Flickr stealth1 by Nom Carver, en Flickr stealth4 by Nom Carver, en Flickr I didn't find a convincing way to connect plates on top of each other this way so I thought I could share the solution that came up to my mind hoping to be useful for someone else. stealth7 by Nom Carver, en Flickr
I need to connect two sections of a mechanism where the axles are aligned x and +. They need to be in the same vertical axis but not necessarily the same horizontal axis. Right now I'm using one of the old 24-tooth gears with three axle holes. This works, but I'm wondering if there is a more compact technique that uses a part currently in production. I've been away from Technic building for a while and am not familiar with all the new connectors. Is there anything out there that will do this?
I am trying to imitate the cartoony look of dust being thrown up when a figure runs fast. Something like the old speedy Gonzales cartoons. I have done a bit of searching but haven't found any good lego examples of this so far. I have attached an example of what I have right now but I don't have a solid connection. Does anyone have another example of imitating this or ideas for a solid connection? Thanks
I reckon I've come up with a new building technique using a 30134 - Staircase 7x4x6 as rafters. I apologise in advance if this technique has been posted before. The advantages of using a 30134 - Staircase 7x4x6 piece in this context is allowing the roof to be structurally stronger and they also represent the wooden rafters that go diagonally across a typical roof. Attic by Adeel Zubair, on Flickr Roof Support (Rafter) Technique by Adeel Zubair, on Flickr ________________________________________________ Follow Me On... Facebook - http://www.facebook.com/Adeel-Zubair-208739829518301/ Flickr - https://www.flickr.com/photos/adeelzubair/ Instagram - http://www.instagram.com/adeel_zubair Deviantart - http://www.adeelaubair.deviantart.com Twitter - http://www.twitter.com/webhead_studios Youtube - http://www.youtube.com/user/webheadstudios LinkedIn - https://www.linkedin.com/in/adeel-zubair-b969b111b Behance - https://www.behance.net/adeelzubair Feedback and criticism is much appreciated. Adeel
- 12 replies
- moc
- building technique
(and 2 more)
Tagged with:
