Showing results for tags 'british railways'.
Hi all, It’s been quite a while since I contributed to the forum, nice to see it’s still so active! Ambridge & Paxley (few more photos, a track plan, and a video of the layout on this page) was a new type of display for me - an 18ft long end-to-end railway, with a station at either end, and connected by a single line. We usually run looped track which requires less effort to run during shows. It is also only 48 studs deep - I wanted to see what I could achieve with a much narrow scenery depth than I’d usually start with. The layout is based on a fictional rural branch line, with Ambridge being the terminus station and Paxley a through station (in future - it was a terminus for the purpose of its first show earlier this year). All of my station/display names are taken from villages and towns in the BBC’s “The Archers”, a long-running radio serial here in the UK. Between the station sits a small valley, home to the River Am and Ambridge Cricket Club.
Long time since I last posted on Eurobricks (University sure takes it out of you). Last Winter I finished a new MOC for display at my local LUG, and here it is making its premiere on the Eurobricks forums: British Railways 60103 (formerly LNER 4472) A3 Class Flying Scotsman Most of the model is built with parts from set 10194 Emerald Night, with a few minor additions for purely aesthetic reasons. The entire locomotive is seven studs wide and adapted to run on 9V track. In addition to the 9V train motor in the tender, a separate motor powers the locomotive, connected to the tender 9V motor. She is as troublesome as the real Scotsman, but runs like a dream when given the proper care and attention. Front view of locomotive. Locomotive side view. Tender side view, with 9V motor underneath. Tender rear view, with corridor and porthole for light Tender top view. View in locomotive cab, with modified 10194 firebox, gauges, and regulator. Inside the firebox, with a view of the motor powering the locomotive. Rear view from the windows of a pullman carriage. Feel free to post any comments or questions, and thanks for viewing! Always entertaining, always inspiring, always:
- 3 replies
- lner
- british railways
(and 2 more)
Tagged with:
Greetings Train Tech, This MoC was actually built over a year ago! I originally designed and built it for use as a "demonstrator" model for a how-to post on Power Functions steam locomotives that I haven't gotten around to writing (although the precursor post is available). While we're waiting on that, I figured I might as well post this model. Prototype History British Railways built this class of 2-6-2 tank engines for a mixed traffic role. Apparently they were very similar to the LMS Ivatt Class 2 2-6-2T, from which they were derived. While none of the class survived into preservation, The Bluebell Railway is rebuilding one of the related 2-6-0 tender locomotives into an example of this class. Engineering Details Usually when I build a MoC, I start with the prototype in mind, then work towards the model. This model began with the desire to build "a small steam locomotive to demonstrate Power Functions", which then determined the choice of prototype. The Standard/Ivatt Class 2 has a number of helpful features in this regard: Small tank engine Large bunker could hide a Power Functions receiver Side tanks can cover up other Power Functions components And indeed, that's how the locomotive is laid out: Even so, the locomotive is quite cramped -- there wasn't enough room for an M-motor based transmission, so I went back to the trusty 9V gearmotor. The output shaft of the motor is very close to the driving axle: ... and it took me a couple tries before I found a good solution: The side tanks contain a channel that allows a cable to pass through, connecting the motor and receiver: The power button is on top of the smokebox and is only held in by gravity: Thank you for reading. Full Brickshelf gallery here.
- 6 replies
- moc
- steam locomotive
- (and 6 more)
