Showing results for tags '8285'.
Hello and welcome to the page! One of my favourite sets ever! It became a part of my collection in a veeery long and hard way several years ago. I was thinking to motorize it several times. Simply install several motors was easy deal, but I wanted a suspension also. This requires fully rebuild the chassis. So, initially I built a completely new scale RC chassis, then adapt it for 8285 outriggers, that adapt it for the 8285 crane then adapt it again for the 8285 cab. I tried to keep as much from original iconic 8285 as possible. None of the 8 PF motors is visible One BIG battery box + 2 sBricks OR two sbricks 2.0 can be used to manage al 8 channels. The only manual feature is a pneumatic polarity switcher, because it would be a 9th channel. Full suspension, rear based on 42043 Arocs set. Servo for steering 2 XL for drive M for outriggers L for pump M for winch L for crane raise L for boom extensionin Please enjoy! https://bricksafe.com/pages/Aleh/liebherr-lrb-355/rc-8285-rescue-tow-truck Truck now uses 6 soft shock abosorbers. To keep it higher it will be enough to replace first rear axle to yellow shock absorbers.
The forever project
2ndgen posted a topic in LEGO Technic, Mindstorms, Model Team and Scale Modeling
Months of collecting pieces is finally showing a bit, on the 8285 tow truck. Changing this set, as much as I can, to a white model, with black or red, thought it would be fun...... Next task, how to suspend it without it looking to high and staying with a solid front axle, struggling with this alot. Suspension is a bit of a mess, but working on it. I have kept all the original pieces seperate, I'm not sure why but my brain said I had better lol. -
Hello everybody, Since i never posted something i have build, i thought this would be something nice to post. Since another project which i'm following has took a break i thought it would be nice to use one of LPEPowers engines in an official LEGO set. :) I've tried the SYS I3 in 8285 with no succes so far. Today i had some spare time and made a fast moc-up with 8146 which works. Lightweight body and very simple chassis. No suspension or else was needed, i did build a torsional bumper, because safety first! This was the result in 3 hours: Very disappointing the V8 did not fit. :P Geared 1:3. The result was blazing fast. Now we can call the model a real nitro muscle car. :) When the video is uploaded to my Dropbox i'll post some footage here with a small teaser about a more serious project. :P Edit: Here it is: https://www.dropbox....7lsjk/Forum.wmv It seems like Dropbox is putting down the videoquality a lot. :/ Edit 2: Resized images due their too big size.
Hi everybody. I build another MOC in the last days and wanted to share the result with you. Is is nothing special, but I like it. The whole truck is exactly 100 cm long (trailer is 66 cm). The truck is motorized with power functions, it has one XL motor for driving and one M motor for steering. For a better steering I have attached a worm gear. It seems, that I only build log trucks :-) Enjoy the pictures and let me know, what you think...
Hi all, want to show to you my MOC. It is not yet final result, but it will not be much different from what you see here. The trailer will be ready soon. thank you.
- 2 replies
- semi truck
- 8258
(and 3 more)
Tagged with:
