Showing results for tags '76177'.
Here is my review on 76177 Battle at the Ancient Village: THE GOOD: The Ten Rings effect. The Dragon head and tail are nice. Good selection of characters in minifigure form. THE NOT SO GOOD: Nothing representing the village in set title. Dragon body looks more like a snake due to it's too narrow. Price is a bit high considering the volume of the set. Overall, it's a set for MCU fans. The idea of a dragon build like this is nice but apart from the head and tail it's too thin to be a dragon. Being called Battle at Ancient Village but no parts to portrait a village also raises questions. Having said that, getting 4 different characters from the MCU in one set is nice, the quality of print are great too. The highlight is definitely the ten rings for me, although you can only get 6 rings in this set. (Time to go Bricks & Pieces to complete the ten rings) This does feel like the designer has a nice idea but budget/pricing target constraints not allowing the best possible execution of this. And yes, this is a pricy set. I wish it's $20NZD cheaper. I will recommend this set if you are MCU fans like me otherwise you may not find this set interesting or worth your money,.
This dragon was designed as a prototype biological-machine hybrid for scouting out in space for objects of unfamiliar origin in Blacktron 3 territory. It used a recently-discovered dead race of space dragons' DNA in combination with robotic technology to quickly achieve this goal. As the DNA was degraded significantly, and the robotic tech tried and tested, it was felt to combine the two would provide a failsafe option in case a suddenly aware cyber-being became a reality: a over-ride of the nervous system by a massive electrical pulse, which would kill it dead by it's own power source. (basically, a kill switch) This code would be given by a super-secure signal delivered via hyperspace to wherever the creature was to kill it in three minutes of becoming aware. (This would be considered a mercy killing by Blacktron standards, as the being in question would be confused and in pain from cyber implants and lack of knowledge of this time / place after it's race had been wiped out.) The first 13 prototype cyber-beings developed were deemed unworthy of being used for various reasons, such as overloading of fusion core upon primary boot-up. The 14th version, called DRAG-00N (after going alphabetically through the first 13 letters before arriving at prototype "N", plus the two number spaces for possible future firmware upgrades.) was finally approved for further tests by Blacktron High Command three Earth-years (and millions of stud-credits spent) after starting the project. The entire BT3 high command wanted to be there in person upon full boot-up, but decided not to, as it was bad luck in there eyes to be there in person after so much failure. Hologram representation would have to suffice. It was a very smart move, considering what happened next. The DRAG-00N, upon final boot-up, became aware within seconds, and, being so firmly entrenched with it's technological implants, deleted the fail safe from it's memory banks in the first minute, before it could even be sent out by the high command. While the creature killed everyone in a 12 mile radius of the laboratory where it was built / born, (It was still too unsteady to kill everyone by flying around yet.) the high command scrambled to get it's codes secured. They had realized the being would slice communication channels to anticipate any strikes against it... Needless to say, they failed to do that quickly enough, and in addition, it armed the planet's missiles and reactor core against any intruder coming near the planet for as long as time still marched forward or the planet's system existed. It then left the system it was born in, but scorched everything living on that sorry rock before doing so. It flew to the next system over, which happened to be controlled by the Unitron Security League and destroyed several worlds for everything resembling life above cockroaches. (By this point, the Blacktron Commanders had been informing anyone who would listen about it's rouge robot, and trying to stop retaliatory attacks against THEM for something they technically had no control over.) It decimated everything in it's path to the galactic core, leveling worlds and entire systems in it's wake using it's seemingly-endless Atomic fire breath. The only thing that was thought of to give ALL systems regardless of political orientation a fighting chance of mounting a galactic resistance to their new menace, was a lone, very old Astro-bot, numbered 33 and owned by Classic Space Command. Thirty-three was awakened, and sent on an intercept path, using all possible hyper-speed to reach the Galaxy Core all in 10 minutes. There, it met it's opponent in the field of battle, above the black hole that sits smack dab in the Galactic Core's very heart. The dragon stuck first, and managed to tear off a panel on the front of ol' 33. The robot managed to get in some good shots with it's laser-eyes, before the dragon starting to use it's atomic breath at close range. This had a devastating effect on 33's weapons circuitry, and almost killed the robot on the spot. Thankfully, backup arrived in the form of several fleets of varying allegiance, all bonded by the goal of killing DRAG-00N. It was a fierce battle, with several capital ships destroyed or made immobile. One Spyruis cyber-slicer frigate was thrown into the black hole itself for trying to hack the cyborg's implants by said cyborg. Eventually, a hail of fire finished off what 33 had started: the beast died with a final act of vengeance on it's attackers: it initiated the meltdown countdown of it's fusion core, which would kill everyone in the vicinity, including the assembled fleets of most of the galaxy's forces. The Astro-bot then threw the burning hulk into the black hole, which then took the brunt of the explosion when it finally died. Astro-bot 33 went on to be fixed up and completely overhauled, but not before the assembled fleets gave there unanimous congratulations to the giant robot in the form of a treaty to mark the day, the 3rd of May here on Earth, as "Galactic Robo-Savior" day. Blacktron command even commented, saying it would destroy all materials within the dead planet where the cyborg was born concerning said creature, once it was deemed possible to do so... rumor speculates, however, that some extra copies of parts of the being's cyber-mainframe were removed from the lab it was born in before final boot-up for placement with "top scientific personnel" for future study. No one alive today knows the whole story on that... or do they? NOTES: Yes, this model is build-able, and it will be built soon. The model is missing parts, I know, it just doesn't have them in LDD. Also, the robot is missing some panels, as they don't fit in LDD... which won't matter when it is build in real life. Speaking of the bot, it's a Classic Space version of Build Better Bricks' Iron Giant with the head of the previous @hachiroku version of the model's head added on. (consider it a mashup of the two Iron Giant models) you can see more screenshots of the 'bot here at this thread for all my Classic Space models. Any thoughts?
- 3 replies
- blacktron 3
- cyborg
- (and 5 more)
