Showing results for tags '42128'.
Inspired by LEGO 8292 Cherry Picker, I've created a pneumatic rendition of that model as an alternate build of LEGO 42128 Heavy Duty Tow Truck. Pneumatic Cherry Picker by Brick Random, on Flickr My Pneumatic Cherry Picker has the following functions: steering (turn the knob on top of the cab) raise arm (pneumatic) extend/retract arm (pneumatic) turn arm (lift and turn the knob on top of the cab) open doors (manual) 4 cylinder engine driven by the four rear wheels A video demonstrating the functions: The basic shape of the original model is still visible in the final build of the Pneumatic Cherry Picker. However, the internal structure is almost entirely new, as a result of changing from mechanical to pneumatic operation of the arm, adding the engine (with two differentials for the four rear wheels) and the availability of parts in 42128. Instructions The model consists of 900 parts (all from 42128 Heavy Duty Tow Truck). Building instructions (a 215 step PDF document) are available on Rebrickable: https://reb.li/m/123565 More pictures are available on Flickr: Pneumatic Cherry Picker by Brick Random
It may come as a surprise but I really don't enjoy being negative towards LEGO sets. So it came as a relief to me that 42128 seems to be one of the best Technic products in the last few years, and it's incredibly reasonably priced on top of that. Fans of trucks, of highly functional Technic sets and of pneumatics should all be very happy with it, especially seeing as you can buy two of these for the price of a single Zetros set. I only wish the colors were different and the stickers less trashy, but that may just be a matter of personal test.
My most technical and realistic model so far, the european-style Garbage Truck, fits in scale all other trucks with 49.5x20mm tires in the Technic-Theme, like the 42024 Container Truck, 42078 Mack Anthem, 42098 Car Transporter or 42112 Cement Mixer. With 1294 parts, it fits the parts count for mid-sized trucks. Instructions can be found on rebrickable. Most medium blue and dark blue parts comes from the set 42064 and 42066. If you take a look at the parts list, feel free to replace the colors and build this truck in any color scheme you want. Functions and Features: HoG steering openable cabin and doors 2-way-gearbox to select between opening the tailgate and activate the garbage press mechanism to hook the included garbage container and unload the trash all functions are operated manually, but the unloading of garbage (bottles in this case) is ready to be motorized My coolest linkage mechanism so far makes it possible to hook up the container, open the lid and unload the trash at the same time... ...as well the working garbage press Impressions: Ready for Power Functions: This model is designed to make the functions (those selected by gearbox) to be motorized. If you own a PF battery pack and M-motor, you can easily upgrade your functions of the garbage truck. There is a full instruction guide included to do that. Instructions: The PDF instructions comes on 215 pages (10 additional ones for optional motorization) with high quality images. Instructions can be found on rebrickable here Have fun with this Garbage Truck.
