Showing results for tags '42004'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 4 results
  1. Hi all! [Edit: I'll post a video and real photos later] I got some time and I made a 42004 alternate for the Rebrickable December Competition. It is a small, wheeled excavator, which is slightly based on the 8419 (like the main boom mecanism) My first intention was to keep a bucket and to give it an use (not as decoration). An excavator looks me the most common application for a bucket. I used the small bucket because I think it has the right size. I used all gears -as gears -. The features: -Steering (HoG) -Main boom raising and lowering (Worm) -2nd and 3th section movement (Worm) -Extra movement of the bucket (Manual) -Turning (Turntable) The body is a bit unfinished, but with not any leftover beam, I couldn't get it looks better. For me, just as for many other Technic builders, functionality is more important than looks. For it size and the available parts, I think it's pretty good. I had only 10 unused parts, of which 8 pins. What do you think of it, and do you have any suggestions to improve it? Greets, Fresko
  2. Hi This is my entry for Rebrickable alternate contest. Model is alternate for set 42004. I do not own that set so the rims on engines are black instead of yellow. All other parts colors are correct. Assault helicopter features: Rotating main rotor (via gear under the fuselage) 2 turbo-jet engines for extreme speed 1 heavy cannon on the front 2 SS 10 anti-tank missiles on sides of the fuselage Seat for pilot two seats in cabin for passengers/shooters Building instructions here. Photos: Hi-quality photos by Jim, later this page, here. LDD screenshot: Hope you like it. LDD-file here
  3. So I finally opened my 42004 set, and built the B model, so that I would have the mini turntable. Something immediately jumped out at me, and that was the fact that there was no mechanism to control the bucket tilt, aside from moving the thing yourself. I looked at the sizeable pile of spare parts, and thought, why couldn't I modify it to include that mechanism? This mod is incredibly easy, and as mentioned before, only uses the parts left over from building the B model. I'm actually kind of shocked that Lego did not do this originally, as it's very simple, and would not have required any additional parts. Well, enough of my blabbering, let's get to building! Start with the B model: Then, remove the following parts: the bevel gear from the steering control, the 2 L liftarm from one of the steering arms, and the bush above it, and remove the side of the bucket linkage with the axle joiner, as shown. Then, pull the following parts out of the pile of extras: A 9L beam, and a 7L axle. everything else should be easily recognizable. Now, assemble as shown in the pictures: Now, knock out the 4L axle holding the arm to the chassis: And remove the piece from between the arms. (It's a liftarm with both an axle and a pinhole.) Put that piece on the empty steering arm. Put the arm back together, and thread the 7L axle through as shown. Now attach the arm piece, which you built a couple of steps ago. ( I actually made a mistake with this, the liftarm holding the two pieces together should be facing the other way.) Now add the control knob, which should be fairly easy to make. Now put the bucket linkage back together. And you are done! So, do you like this? Edit: Booyah! 300th post!
  4. I bought the the 42004 backhoe and 42006 Material Handler while I was in town today. For the price (18 uk pounds) the backhoe has allot of useful parts including a medium sized excavator bucket,mini turntable and lots of liftarms.
