Showing results for tags '10248'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 3 results
  1. Hi guys! Today I am pleased to present new MOC - RANCHER 4x4. The basis of this model was a completely new chassis, the creation of which took me almost two months. The model is based on the support frame mounted with its two L motors, and a small battery pack. To fasten the frame of continuous two gantry axles - which significantly increases the reliability of the transmission. Servo motor is mounted directly on the front axle. As I chose the stake so beloved by all, but it is quite rare on the Tumbler wheel - 81,6x44 mm. I think this is one of the best wheels from LEGO, along with 94,3x38 from the Unimog. And I'll show you how to use it to modify the set LEGO 10248 Ferrari F40 :) Specifications and features: Four-wheel drive, portal axles uncut; Tires 81,6x44 (Tumbler) 2L motors - the drive motor; Servo motor - steering; 3xLED - lights; Small battery pack; Modular design - a body attached to the chassis by 4 points; Opened doors, hood and door body
  2. First off, I apologize if this is in the wrong forum. I thought this would be the best place for this topic since this is more of a Model Team set. Mods, please move this if you see fit to do so. Hello everyone! Today I am presenting a tiny MOD to the set 10248 Ferrari F40 to make it stanced and turn it into the drift supercar you know you always wanted! And yes, it does roll. Here are some quick pics of what I did: Tell me what you think! Anything from "I love it!" to "How could you! You ruined my favorite supercar!" is fine!
  3. TLDR: super-detailed fully-modular Creator-scale build of epic early-90s Ferrari race-car version of street car version of a race car. The F40 LM is the race car version of what was already mostly a race car. Nineteen competition-ready F40's were built by Chinetti Michelotto for Ferrari; lighter, lower, more powerful and full of racing-specific tweaks. My 10248 "Super-Mod" builds one of these legendary LMs inside the lines of TLG's design. The kit's brilliant overall shaping and clever build solutions provide a framework for revised proportions and deeper detailing. Nearly every step of the build is altered and most assemblies have been heavily redesigned. The LM-spec bodywork has an extended front splitter, fixed headlights, a top-vented front hood, taller rear wing and open mesh rear bodywork. The lengthened doors and repositioned fuel-tank pods were informed by Brickmonkey's modified build, while the gray interior firewall was removed entirely, allowing the seats to be extended back along with the stretched doors for a more properly-scaled cabin. The black trim line is now brick-built the full circumference of the car, and the chromed #56145 rims from Bricks4All have fully scratch-built BBS LM wheel inserts (see my F40 album on Flickr for some in-progress photos). My original goal of just lowering the 10248 model's ride height rapidly evolved into in a fully revamped chassis, keeping only a portion of the central floor and the clever side sills from TLG's model. The race-spec front section carries an oversize radiator, air jacks, sway bars, repositioned hydraulic reservoirs and low-mounted battery suspended on Technic beams. The redesigned rear chassis lifts the axle position and provides mounts for the sway bar and air jack details as well as vestigial rear springs and oil coolers. The engine and transmission assembly was also lengthened and lowered and features details for turbos, wastegates, exhausts, a larger intake manifold and intercoolers. Also tucked in there are the cam-drive ancillaries, oil filter, and transmission-oil line. I followed the spec of a particular F40 LM which underwent a comprehensive resto-mod; much larger intercoolers, dual wastegates and many other updates went into the build. It's all well documented here: www.build-threads.com/tag/Ferrari-F40-LM-Restoration/ Custom stickers were created for the Braille battery, Magneti Marelli digital dashboard, and labels on the master cylinder fluid reservoirs. This project was a first for me at this scale (well, since I was a kid anyway) and a blast to do. It went way, way deeper than I had intended; motivation and inspiration for what was possible came from the large-scale masterworks of Luca Rusconi, Carl Greatrix, Norton74, and Robert Alexander (also Biczzz’s Alfa, Gerald Cacas, Sir.Manperson, Alex Paschoaletto). Hope you enjoy checking it out. Original base model: 1157 pcs. As built, appx: 1270 pcs. Parts changed or added: 490 pcs (39%) (*ps, missing a good clean "finished" front 3/4 shot, have to set up another shoot and add it back here)
